Hi there,
I have a task to convert NV12(yuv420sp) pixel format to RGB24, feeding into deep learning inference tasks.
Now I am using AGX Xavier with Drive OS 5.2.6.0 sdk, and refer to the sample code: NvMedia/nvmimg_2d.
The questions from my side are:
How could we know what exactly the Hardware backend is using when calling NvMedia2DBlitEx function? Is it Arm CPU or VIC?
I could convert NV12 to RGBA successfully, but I found no RGB24 or R8G8B8 surface type defined in nvmedia_surface.h. Is this converting (NV12 to RGB24) supported by nvmedia? If so, how could I define the correct target surface type.
Thank you!
