I faced the following error while trying to create a RGB image :
Driveworks exception thrown: DW_FAILURE: Image: imageAttributesToNvMediaSurfaceType, Invalid image pixel format.
[2021-07-18 22:47:07] DW Error DW_FAILURE executing DW function:
dwImage_create(&mHandle_NVMrgb, rgbaImageProperties, mSdk)
What I have tried:
dwImageProperties rgbaImageProperties{};
// In order to stream we prepare the properties of the image
CHECK_DW_ERROR(dwSensorCamera_getImageProperties(&rgbaImageProperties, DW_CAMERA_OUTPUT_NATIVE_PROCESSED, mCamera));
rgbaImageProperties.type = DW_IMAGE_NVMEDIA;
rgbaImageProperties.memoryLayout = DW_IMAGE_MEMORY_TYPE_DEFAULT;
rgbaImageProperties.format = DW_IMAGE_FORMAT_RGB_UINT8;
//Output image for copyconverstion from YUV to RGBA
CHECK_DW_ERROR(dwImage_create(&mHandle_NVMrgb, rgbaImageProperties, mSdk));
//copyConvertion to DW_IMAGE_FORMAT_RGB_UINT8
CHECK_DW_ERROR(dwImage_copyConvert(mHandle_NVMrgb, mHandle_NVM, mSdk));
The error is happening at dwImage_create,
My goal here is to convert the native YUV420-uint8 image to a RGB format or BGR format.
When I try with rgbaImageProperties.format = DW_IMAGE_FORMAT_RGBA_UINT8; the CopyConversion works fine, but I dont want RGBA.
Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
