Why the YUV420 format dwImageCPU image is displayed with garbage ?
Dear Sir:
I am trying to read GMSL camera image into Nvmedia and post it directly to CPU without converting to RGBA. Then I convert the YUV420 format dwImageCPU image to BGR with opencv API(colorcvt), but the converted BGR image can not be displayed well(using opencv), all are garbage.
Is there something wrong with my code or driveworks do not support this way to get image ?
Dear Henryeon,
Can you double check if you are receiving data in dwImageCPU data pointers. I found some link to store YUV 420 image(c++ - YUV420 to BGR image from pixel pointers - Stack Overflow).
Dear SivaRamaKrishna:
Thank you for your reply. I have checked the three pointer in dwImageCPU, which are data[0]/data[1]/data[2]. The three pointers have data in them. But the data seems not YUV format. I dumped the 1920*1208 bytes of data[0], which should be Y value in YUV420. Some of the data seem not Y.
So I doubt the YUV data CPU received maybe not correct ?
How can I get the correct YUV data in CPU ?
177 179 186 189 186 178 169 173 179 182 182 185 186 193 204 222
240 251 255 255 255 255 255 255 253 255 255 255 255 255 255 255
255 255 255 255 255 255 255 255 255 255 255 255 255 255 255 255
255 255 255 255 255 255 255 255 255 255 255 255 255 242 192 184
189 201 222 234 236 235 234 235 240 235 203 168 166 168 171 171
175 175 177 175 178 176 176 174 177 180 187 186 188 185 192 193
186 167 151 152 171 187 194 192 194 193 195 193 194 188 199 225
237 239 240 239 238 237 240 243 242 228 217 225 236 241 243 243
243 241 241 241 241 242 243 243 242 240 239 239 242 245 245 243
241 238 239 242 246 247 245 243 239 236 239 246 249 247 245 240
223 207 205 208 209 204 199 205 210 209 207 206 207 208 206 200
198 213 236 247 249 248 244 241 241 242 244 245 248 250 247 240
236 240 246 247 234 210 198 193 195 198 203 203 206 206 203 197
202 204 204 204 217 228 232 235 239 240 240 240 222 185 163 161
165 173 182 186 206 226 230 217 185 163 161 161 174 207 237 248
238 211 180 161 157 168 197 221 233 238 241 238 233 238 244 245
246 246 245 240 240 245 248 249 249 247 236 218 207 208 212 209
199 197 206 210 210 211 212 213 212 212 212 212 207 199 202 209
211 206 198 205 224 237 243 245 245 245 243 237 235 240 245 247
247 241 229 251 255 255 255 255 255 255 255 255 255 255 255 255
255 255 255 255 255 255 255 255 255 255 238 220 208 198 190 185
191 195 193 188 187 196 212 218 211 212 227 249 251 252 255 255
255 255 235 208 198 198 199 206 211 212 194 200 250 255 255 249
202 165 161 168 177 182 179 177 224 255 255 255 255 255 255 255
255 255 255 255 255 234 193 182 179 171 158 155 219 255 255 255
255 255 238 204 197 198 205 218 232 226 220 211 207 202 195 190
190 194 189 177 173 173 174 174 173 173 177 181 180 179 175 167
158 156 155 155 153 151 155 167 174 175 172 170 169 167 166 165
163 162 163 161 155 149 145 144 141 140 140 140 140 142 149 152
150 150 151 154 155 153 150 148 150 147 141 138 139 144 158 170
167 158 157 160 168 168 161 180 235 255 255 254 214 158 137 133
132 134 137 143 154 161 166 170 171 169 169 169 169 169 171 168
163 158 153 146 143 150 163 174 176 176 178 182 182 184 186 187
189 192 192 190 186 178 168 160 158 161 163 162 165 170 167 161
160 166 168 166 164 167 172 174 175 173 169 164 159 160 165 168
173 179 179 178 177 180 182 184 186 188 189 189 188 188 187 185
183 182 182 185 185 181 175 172 184 206 214 207 184 163 164 175
187 196 195 191 186 184 183 184 185 189 188 190 183 176 168 166
180 225 255 255 255 255 255 248 197 178 180 180 177 173 175 177
179 183 214 255 255 255 255 255 255 255 255 255 255 255 238 222
211 205 200 200 203 206 204 199 193 190 187 184 185 192 196 194
199 219 246 254 255 255 243 203 180 202 251 255 255 255 255 255
7 14 2 0 7 14 2 0 7 14 2 0 7 14 2 0
7 15 2 0 7 15 2 0 7 15 2 0 7 14 2 0
86 120 61 0 112 154 84 0 122 162 93 0 126 165 98 0
113 158 80 0 110 156 78 0 112 156 80 0 114 158 83 0
132 169 106 0 137 172 112 0 142 175 118 0 147 178 125 0
118 160 87 0 120 162 89 0 123 164 92 0 125 166 96 0
173 176 181 186 183 181 176 177 179 184 189 199 209 222 237 249
253 255 255 255 255 255 255 255 255 255 255 255 255 255 255 255
255 255 255 255 255 255 255 255 255 255 255 255 255 236 189 183
188 202 225 237 239 238 238 239 244 237 200 158 150 153 155 157
160 160 161 160 160 159 157 158 161 163 166 166 166 165 175 183
174 157 147 149 163 176 180 176 175 174 173 172 171 174 195 225
237 237 237 237 236 236 239 242 239 227 221 228 235 237 238 240
240 240 240 240 241 242 242 241 239 238 237 237 241 244 242 240
238 237 238 241 244 245 243 242 239 235 239 244 246 245 243 239
222 205 203 207 208 203 198 204 209 210 209 209 209 210 208 202
200 213 235 247 248 247 243 240 239 241 243 245 247 249 246 239
235 239 245 246 230 201 184 179 181 182 185 188 190 190 187 183
186 189 188 190 206 224 231 233 237 239 240 238 219 183 162 161
161 165 168 177 202 225 231 219 186 162 160 161 174 207 235 246
237 210 178 161 157 166 193 218 230 237 241 238 234 239 245 246
246 247 244 240 240 245 247 248 249 247 236 218 207 208 212 210
200 196 205 210 210 211 212 213 212 212 212 211 205 197 200 207
209 204 197 205 224 237 244 246 246 246 243 238 237 242 245 247
248 242 229 249 255 255 255 255 255 255 255 255 255 255 255 255
255 255 255 255 255 255 255 255 255 251 232 215 204 196 188 183
188 193 190 185 185 203 227 240 242 247 255 255 255 255 255 255
255 250 222 203 198 203 213 229 242 239 218 208 243 255 255 247
199 164 158 164 171 175 172 184 243 255 255 255 255 255 255 255
255 255 255 255 255 231 190 182 178 170 157 163 227 255 255 255
255 255 232 201 195 196 198 205 213 210 208 205 203 199 193 190
190 190 182 171 170 173 174 171 169 172 178 183 181 179 175 169
163 161 158 156 154 155 160 171 175 174 171 168 167 167 166 164
162 162 161 158 154 150 148 145 143 141 140 140 140 141 147 150
148 148 150 154 155 154 150 147 147 148 145 142 142 148 162 172
167 155 150 152 160 165 162 172 216 250 254 248 201 151 133 132
133 135 137 141 150 161 167 169 167 166 167 167 167 168 169 168
164 159 153 147 146 154 167 177 178 177 178 181 182 184 184 183
184 186 186 184 179 172 163 154 153 158 161 163 168 172 169 165
165 168 169 168 165 166 170 174 175 173 170 166 161 160 162 164
170 179 183 185 184 186 184 183 185 188 189 189 187 187 187 186
185 185 185 186 185 182 177 183 206 224 224 208 180 163 168 183
197 202 198 198 197 201 203 208 213 215 214 210 196 183 169 162
164 196 247 255 255 255 255 233 193 177 176 177 174 171 171 173
176 190 234 255 255 255 255 255 255 255 255 255 255 248 226 221
216 212 208 209 210 208 200 197 199 199 191 183 183 190 189 187
188 199 218 233 250 251 231 200 179 188 228 254 255 255 255 255
71 133 27 0 74 135 30 0 78 138 34 0 81 140 38 0
72 134 28 0 74 136 30 0 77 136 34 0 80 140 37 0
82 142 39 0 143 182 114 0 143 182 114 0 139 180 110 0
81 141 38 0 140 180 110 0 141 181 112 0 137 178 108 0
71 133 27 0 74 135 30 0 77 136 33 0 78 139 36 0
70 132 26 0 74 134 30 0 77 137 33 0 79 139 36 0
83 142 39 0 133 175 102 0 142 182 114 0 135 177 105 0
81 142 38 0 125 170 92 0 143 183 115 0 134 177 104 0
181 183 186 188 187 189 192 197 202 212 224 240 251 255 255 255
255 255 255 255 255 255 255 255 255 255 255 255 255 234 187 181
189 206 230 243 244 245 247 249 250 241 198 149 135 139 139 142
143 143 142 142 141 140 137 138 141 142 140 140 138 139 159 179
166 147 144 145 151 159 161 156 148 145 142 140 140 157 192 226
240 241 240 239 238 238 241 244 237 225 226 234 236 235 236 238
239 240 241 241 242 244 243 242 240 238 237 238 241 242 240 238
237 238 239 242 243 242 241 242 240 237 241 244 243 242 241 237
220 202 201 204 205 200 195 202 208 210 211 211 212 212 210 205
202 214 235 245 246 245 243 240 240 242 245 246 247 248 245 240
237 240 245 244 226 191 167 163 163 162 163 168 167 167 166 165
166 167 165 170 192 218 231 234 237 238 239 238 219 185 165 160
159 157 159 174 203 225 231 219 186 161 159 160 175 207 234 245
235 209 176 160 157 164 185 208 223 235 241 238 235 241 248 248
248 248 246 241 243 248 249 250 250 249 239 220 207 208 212 211
202 197 205 211 212 211 212 212 212 212 212 211 205 197 200 206
207 202 197 207 226 238 244 247 247 246 243 240 241 244 247 249
250 244 234 252 255 255 255 255 255 255 255 255 255 255 255 255
255 255 255 255 255 255 255 255 255 243 222 206 196 191 185 181
184 187 183 179 197 235 255 255 255 255 255 255 255 255 255 255
255 228 203 195 197 207 237 255 255 255 255 243 239 250 249 224
184 159 156 159 162 162 165 195 251 255 255 255 255 255 255 255
255 255 255 255 255 227 190 184 180 173 165 176 220 252 255 255
255 250 215 195 193 193 192 192 191 191 194 198 199 195 188 184
184 180 170 163 166 173 172 167 164 168 176 182 179 174 172 171
172 171 165 159 159 162 167 173 175 172 169 166 165 165 165 162
161 160 158 155 152 152 151 149 147 146 144 144 144 144 147 148
147 147 149 153 155 155 153 148 145 148 151 151 150 156 167 172
165 152 141 140 146 156 161 165 181 212 225 210 172 142 131 131
135 136 137 139 146 159 164 161 159 160 162 162 162 164 165 164
163 160 154 150 154 165 175 180 181 179 178 179 181 181 178 173
171 171 171 169 166 162 154 146 147 153 159 164 170 172 171 170
168 167 166 164 162 164 167 171 174 175 173 169 165 163 163 168
183 203 215 219 212 203 190 182 186 192 192 189 185 184 185 185
186 187 187 187 187 185 183 200 234 249 235 203 174 165 176 192
209 214 219 230 240 250 254 255 255 255 255 252 232 208 183 162
151 157 180 209 230 247 234 205 183 174 171 171 169 167 166 168
176 207 254 255 255 255 255 255 255 255 255 255 255 229 225 235
240 240 240 240 234 221 212 217 226 225 208 191 187 187 183 179
176 177 183 190 205 219 214 199 182 173 183 208 229 252 255 255
106 100 152 0 109 104 155 0 111 106 157 0 115 110 159 0
104 99 152 0 107 102 154 0 110 105 156 0 113 108 158 0
117 113 161 0 120 116 163 0 123 118 165 0 126 121 167 0
133 129 171 0 226 226 228 0 235 235 235 0 236 236 236 0
103 97 151 0 106 101 153 0 108 103 155 0 111 106 157 0
101 95 149 0 104 98 151 0 106 101 154 0 114 110 159 0
184 181 202 0 232 232 232 0 233 233 233 0 235 235 235 0
221 221 223 0 229 229 229 0 230 230 230 0 231 231 231 0
219 219 219 219 216 214 220 235 249 252 255 255 255 255 255 255
255 255 255 255 255 255 255 255 255 255 255 255 255 231 185 182
190 208 231 245 248 248 249 250 251 244 200 148 135 143 144 145
144 145 142 143 144 145 141 141 142 144 140 138 134 138 168 194
175 148 143 145 148 153 156 155 149 142 136 134 139 163 199 232
244 246 245 244 242 240 244 247 237 224 231 241 239 238 240 242
242 243 242 242 243 246 246 245 243 241 240 239 240 241 240 238
237 238 240 243 244 244 244 245 241 237 241 244 244 243 243 237
217 196 194 198 199 196 193 201 206 208 208 209 209 208 207 205
202 212 232 242 242 241 241 240 239 241 242 243 242 242 241 238
236 240 243 241 220 185 163 160 159 161 163 167 165 162 160 161
161 162 159 164 186 215 231 235 236 236 237 236 216 183 164 162
162 164 169 187 212 228 231 218 186 160 156 159 176 209 234 243
234 207 175 160 156 158 172 191 210 229 238 237 235 241 248 249
248 247 245 240 242 247 249 250 249 248 239 220 207 207 212 212
202 197 204 211 212 213 211 211 212 213 213 213 206 197 201 207
207 202 197 208 226 237 243 246 246 245 241 237 240 244 246 248
249 244 234 252 255 255 255 255 255 255 255 255 255 255 255 255
255 255 255 255 255 255 255 255 252 230 212 198 189 185 182 182
183 181 172 182 228 255 255 255 255 255 255 255 255 255 255 255
253 216 196 193 193 202 243 255 255 255 255 255 255 251 235 200
171 166 164 163 158 154 158 202 253 255 255 255 255 255 255 255
255 255 255 255 253 206 187 186 182 179 179 196 221 228 216 212
218 209 194 192 193 193 191 189 183 182 188 195 195 191 182 175
173 172 167 163 167 172 167 161 160 168 178 181 175 169 169 175
183 182 170 161 164 170 171 172 171 167 165 163 161 160 159 158
158 157 154 154 153 152 152 151 152 151 148 147 148 149 149 148
148 149 151 153 155 157 156 152 146 147 152 157 159 163 168 170
164 151 138 133 135 145 155 162 164 175 184 175 155 142 134 133
134 134 135 140 150 158 156 151 150 153 154 154 155 156 157 157
158 159 155 156 165 175 179 180 180 179 179 179 179 176 169 162
158 157 158 157 156 155 150 144 146 151 155 161 165 168 169 168
164 159 156 155 155 159 162 168 173 175 175 173 170 168 170 187
221 250 255 255 251 222 189 179 191 202 200 189 180 178 180 181
183 183 184 186 186 184 182 198 232 249 227 189 168 167 175 190
210 231 251 255 255 255 255 255 255 255 255 255 255 248 212 182
165 162 159 167 181 199 198 187 176 172 170 169 166 164 163 163
173 223 255 255 255 255 255 255 255 255 255 255 253 236 248 255
255 255 255 255 254 247 249 254 255 254 237 216 207 197 185 179
176 179 184 193 206 216 217 212 198 181 170 172 179 205 247 255
62 55 126 0 61 55 126 0 61 55 126 0 127 127 127 0
62 55 126 0 62 55 127 0 62 55 127 0 125 125 125 0
115 115 115 0 181 181 181 0 180 180 180 0 180 180 180 0
112 112 112 0 179 179 179 0 179 179 179 0 178 178 178 0
62 55 126 0 62 55 126 0 63 56 128 0 123 123 123 0
62 55 127 0 62 55 127 0 63 56 128 0 121 121 121 0
110 110 110 0 178 178 178 0 177 177 177 0 176 176 176 0
108 108 108 0 175 175 175 0 174 174 174 0 174 174 174 0
253 253 253 253 251 248 249 255 255 255 255 255 255 255 255 255
255 255 255 255 255 255 255 255 255 255 255 255 255 232 187 183
192 208 231 245 249 249 249 250 251 243 201 151 140 148 151 149
148 148 146 147 150 149 147 146 148 150 147 143 139 142 176 203
182 150 144 146 149 152 156 158 159 154 146 141 151 176 209 236
247 248 248 249 246 243 246 248 238 228 237 245 242 242 246 248
249 247 246 244 245 248 249 249 248 246 243 240 241 243 242 240
238 237 240 246 248 248 248 248 244 239 243 246 247 248 248 239
216 194 191 195 195 193 191 199 204 205 205 205 206 205 204 202
201 212 232 242 243 242 241 239 238 240 241 241 239 238 237 236
235 239 243 239 216 182 163 160 162 167 169 170 170 167 165 166
166 165 163 163 183 211 229 234 234 234 234 232 215 186 169 169
176 182 190 207 225 231 228 214 187 165 160 162 180 212 234 242
232 205 175 161 159 157 161 174 197 222 234 236 235 241 247 248
248 245 244 241 242 245 246 247 247 246 238 221 208 208 212 211
202 197 204 210 211 212 211 210 211 213 213 213 207 199 203 208
208 202 198 209 229 238 241 244 245 244 239 235 238 243 246 247
247 242 235 253 255 255 255 255 255 255 255 255 255 255 255 255
255 255 255 255 255 255 255 255 240 221 207 195 187 181 179 181
180 173 174 205 255 255 255 255 255 255 255 255 255 255 255 255
255 219 201 197 192 195 230 255 255 255 255 255 255 255 248 202
184 189 187 176 162 150 156 205 249 252 253 255 255 255 255 255
255 255 255 251 208 184 187 187 182 182 198 229 246 228 192 175
175 179 185 194 197 195 190 184 175 175 183 188 188 183 176 169
169 172 172 168 168 168 162 159 169 185 192 188 176 168 171 180
189 185 170 162 167 172 172 169 166 162 160 159 157 155 154 154
156 156 154 155 155 154 152 151 151 149 146 147 149 150 149 148
149 152 153 154 156 158 158 153 148 148 152 157 161 162 165 167
162 151 140 132 129 136 147 156 163 170 173 167 156 147 140 135
135 136 140 148 156 157 151 146 147 150 150 149 149 150 151 151
151 154 158 165 174 180 181 180 180 180 180 178 175 169 162 156
153 153 154 154 152 152 151 147 147 148 152 157 160 162 164 162
156 152 149 149 150 153 158 166 172 175 176 176 174 173 182 213
253 255 255 255 255 226 183 184 203 214 205 185 171 169 171 172
173 173 177 180 180 177 175 182 201 213 198 174 165 166 173 189
224 254 255 255 255 255 255 255 255 255 255 255 255 255 249 215
199 195 187 179 176 181 183 179 174 172 170 167 164 163 161 158
174 237 255 255 255 255 255 255 255 255 255 255 255 255 255 255
255 255 255 255 255 255 255 255 255 255 255 253 242 217 192 178
176 182 196 214 231 238 238 234 220 200 183 172 169 177 207 244
254 255 255 255 255 255 255 255 255 255 255 255 255 255 255 255
185 203 173 0 189 205 177 0 192 206 181 0 195 209 186 0
151 184 127 0 154 186 131 0 157 187 134 0 159 190 139 0
198 211 189 0 201 213 194 0 205 215 196 0 206 217 200 0
162 191 141 0 165 193 145 0 167 195 148 0 169 195 151 0
255 255 255 255 255 255 255 255 255 255 255 255 255 229 187 186
192 208 231 246 249 248 248 249 251 243 199 149 139 148 151 150
149 149 148 149 150 149 147 147 149 153 149 144 138 142 182 212
189 151 142 146 148 148 150 155 161 162 152 144 155 185 217 241
249 248 248 249 247 244 247 247 234 226 238 246 243 243 247 250
250 249 247 244 245 249 250 251 250 249 245 240 240 244 244 242
239 236 240 248 250 250 249 249 244 239 243 247 249 250 250 243
219 197 195 199 198 195 194 202 207 209 209 209 209 209 208 206
204 214 234 246 247 247 246 242 240 242 244 246 245 243 241 239
237 241 247 243 218 181 162 162 172 182 183 174 168 168 173 177
176 170 162 162 182 211 228 233 233 233 234 232 220 200 188 190
199 207 215 225 232 233 227 214 191 176 175 182 197 218 233 238
227 204 177 164 160 159 160 171 197 222 233 235 235 240 243 243
242 240 239 238 240 242 243 244 244 243 236 221 210 209 212 211
202 196 202 208 209 211 211 211 212 214 214 212 206 199 203 208
208 204 199 209 228 239 242 243 244 243 239 235 238 243 246 247
246 241 230 251 255 255 255 255 255 255 255 255 255 255 255 255
255 255 255 255 255 255 255 253 231 218 207 197 189 183 180 180
176 177 199 246 255 255 255 255 255 255 255 255 255 255 255 255
255 217 193 194 191 191 215 252 255 255 255 255 255 255 254 225
221 230 222 203 176 154 154 184 210 208 205 224 253 255 255 255
254 243 225 192 173 177 183 184 180 183 213 251 255 248 216 194
184 187 197 207 206 199 187 176 168 168 177 183 180 174 169 167
169 174 173 170 167 165 162 171 198 223 225 208 184 170 171 178
184 180 167 161 166 170 168 164 160 157 156 155 153 151 151 152
156 158 158 158 156 154 150 147 145 143 143 146 146 145 144 143
146 150 152 154 156 157 155 152 148 149 150 152 154 156 161 165
163 154 146 139 133 135 143 154 169 180 181 175 163 153 142 136
136 141 149 156 158 155 150 145 147 150 149 147 148 148 148 147
147 151 162 174 179 181 181 181 181 182 180 174 168 163 157 154
154 157 157 157 154 152 149 146 146 148 154 159 159 157 156 154
151 150 149 149 149 151 155 163 169 174 177 177 175 175 186 228
255 255 255 255 255 208 177 194 217 220 198 172 161 159 158 157
159 162 166 169 169 169 168 168 170 173 168 160 160 163 167 189
236 255 255 255 255 255 255 255 255 255 255 255 255 255 255 254
243 237 227 218 205 193 182 175 169 168 167 165 164 164 159 154
169 222 255 255 255 255 255 255 255 255 255 255 255 255 255 255
255 255 255 255 255 255 255 255 255 255 255 255 255 243 202 176
171 178 192 217 240 251 254 253 245 222 197 179 169 170 183 208
225 227 216 210 217 232 250 255 255 255 255 255 255 255 255 255
204 215 197 0 59 108 25 0 51 98 17 0 40 72 17 0
253 253 252 0 153 176 135 0 54 104 17 0 48 88 19 0
160 168 154 0 253 254 253 0 255 255 255 0 255 255 255 0
192 200 186 0 148 155 142 0 133 140 127 0 175 180 172 0
255 255 255 0 253 253 252 0 148 172 132 0 124 150 105 0
255 255 255 0 255 255 255 0 252 252 251 0 246 247 245 0
219 224 215 0 38 65 19 0 30 58 10 0 30 58 10 0
150 166 138 0 51 88 25 0 49 93 17 0 51 97 18 0
255 255 255 255 255 255 255 255 255 255 255 255 255 229 190 187
193 209 232 246 248 248 248 249 251 241 196 147 138 146 149 150
150 149 149 150 150 149 148 147 148 151 149 146 140 144 183 215
191 151 141 145 146 146 146 151 158 162 157 148 159 190 222 244
250 249 248 248 246 246 247 243 231 227 240 247 245 243 247 249
250 249 248 245 246 249 251 251 252 250 247 240 240 243 243 243
240 237 240 249 250 250 250 249 245 240 244 248 249 249 250 244
222 204 203 205 203 199 198 205 212 215 216 216 216 217 216 213
209 218 238 248 249 250 249 245 241 243 247 250 250 248 246 243
239 243 250 247 222 182 160 164 186 203 202 183 166 165 180 192
191 180 164 161 183 213 229 232 233 235 236 235 231 221 214 216
223 229 235 238 237 234 230 220 203 196 201 210 220 228 235 237
229 211 189 174 170 169 175 188 209 227 234 235 235 238 239 238
238 236 235 236 239 240 241 243 244 242 235 221 211 208 209 208
200 195 200 204 207 209 210 211 212 214 214 212 205 198 202 207
208 204 200 209 229 240 242 242 242 241 238 237 240 242 244 246
245 239 230 252 255 255 255 255 255 255 255 255 255 255 255 255
255 255 255 255 255 255 255 251 229 218 209 200 193 188 185 181
183 203 244 255 255 255 255 255 255 255 255 253 234 253 255 255
255 217 187 188 190 189 196 215 235 254 255 255 255 255 255 253
255 255 253 232 194 161 155 164 175 173 168 172 195 231 248 244
218 193 174 165 170 176 179 182 180 182 209 251 255 255 245 223
212 213 224 230 223 209 192 179 170 169 175 178 175 170 166 164
167 170 171 168 168 168 176 198 239 255 255 237 197 170 167 171
172 169 163 162 165 165 162 158 155 154 154 153 152 152 152 153
157 161 162 160 154 149 146 142 140 139 141 143 142 139 139 141
144 148 151 155 159 157 153 150 148 147 146 145 147 150 157 164
165 160 155 147 141 139 148 163 179 188 185 178 168 157 144 135
137 147 155 157 154 150 148 147 147 148 147 146 148 147 146 147
147 152 166 178 181 179 179 179 180 181 178 169 160 155 153 154
156 158 159 158 156 152 147 145 146 151 158 160 157 153 150 148
147 149 150 151 152 152 152 156 164 172 177 177 174 172 179 223
255 255 255 255 246 188 170 190 213 205 179 161 156 153 148 148
152 157 158 157 156 158 160 159 156 154 152 152 155 156 156 175
211 249 255 255 255 255 255 255 255 255 255 255 255 255 255 255
255 255 255 255 250 222 193 173 165 163 164 165 165 164 161 155
158 184 220 246 250 252 254 255 255 255 255 255 255 255 255 255
255 255 255 255 255 255 255 255 255 255 255 255 255 255 218 184
177 180 186 206 236 254 255 255 254 237 206 181 174 172 174 182
189 191 185 178 176 181 194 216 237 254 255 255 255 255 255 255
151 147 185 0 153 150 187 0 156 152 188 0 158 154 190 0
243 243 243 0 242 242 242 0 242 242 242 0 241 241 241 0
159 156 191 0 161 158 192 0 162 158 192 0 162 159 193 0
241 241 241 0 240 240 240 0 239 239 239 0 238 238 238 0
240 240 240 0 240 240 240 0 239 239 239 0 239 239 239 0
237 237 237 0 237 237 237 0 236 236 236 0 236 236 236 0
239 239 239 0 238 238 238 0 237 237 237 0 236 236 236 0
236 236 236 0 235 235 235 0 235 235 235 0 234 234 234 0
255 255 255 255 255 255 255 255 255 255 255 255 255 227 190 188
193 209 231 245 249 248 248 249 251 242 196 147 137 146 150 152
151 151 151 152 150 149 148 148 150 155 155 152 146 149 190 224
197 151 138 143 147 150 150 151 155 159 157 153 163 193 222 244
250 249 248 247 246 247 247 240 227 226 240 247 244 244 247 249
250 250 248 246 247 250 251 251 251 251 247 241 240 242 242 243
241 239 241 248 250 250 250 250 246 240 244 249 249 249 250 244
223 206 206 208 205 201 200 208 215 218 219 219 219 220 220 217
212 220 239 249 250 250 249 246 243 244 248 250 250 249 248 244
240 244 251 249 222 179 155 164 196 219 214 189 165 165 186 205
206 190 165 158 184 216 231 234 235 237 238 238 237 234 230 233
237 240 243 244 240 235 234 231 223 221 225 231 234 235 239 242
239 228 211 197 192 190 197 208 223 235 239 239 237 239 241 240
240 239 238 237 237 239 240 242 243 242 234 217 204 201 201 200
194 191 195 200 202 205 207 208 207 209 209 208 201 194 197 202
204 202 198 207 227 239 240 240 239 238 236 237 238 239 241 243
243 237 227 250 255 255 255 255 255 255 255 255 255 255 255 255
255 255 255 255 255 255 255 245 218 211 206 201 194 188 184 186
205 245 255 255 255 255 255 255 255 255 255 230 235 255 255 255
255 211 185 182 181 182 178 177 176 194 231 253 255 255 255 255
255 255 255 252 205 165 157 163 170 174 171 171 173 187 203 206
193 180 170 171 174 177 180 184 183 180 193 229 252 255 252 246
242 246 253 254 250 237 219 202 186 174 172 174 173 171 165 161
163 167 167 165 167 177 198 231 255 255 255 255 208 167 159 162
163 161 159 161 163 160 156 155 153 153 154 155 155 157 157 155
155 158 160 159 151 145 142 141 139 138 139 139 137 135 138 141
145 150 153 157 160 158 153 149 147 145 141 140 141 147 154 161
163 162 158 154 149 147 160 181 195 195 184 177 173 164 150 141
144 152 154 151 146 143 144 145 145 145 144 144 144 144 146 150
150 155 166 177 179 177
Dear Henryeon,
I think you are trying to convert a dwImageNvMedia to dwImageCPU, if so can you check dwImagePixelFormat(file:///usr/local/driveworks-0.6/doc/nvdwx_html/group__image__group.html#ga40e445bbc92b6c60197dd57fc9ca602d) in image properties to confirm it is YUV420.
Please check YUV values in dwImageNvMedia and dwImageCPU to confirm both are same.
All the data structures in Nvmedia are of abstract type. NvMediaImage does not directly expose the pointer to the image data. One way to get the Image data contents is to use NvMediaImageLock, NvMediaImageGetBits API. You can check the code of NvMedia img_cap sample to know the usage.
Yes, I am trying to post dwImageNvMedia to dwImageCPU without convert YUV to RGBA. I have confirmed the received pixel format in dwImageCPU is YUV420. Also , I have dumped both dwImageNvmedia(with NvMediaImageLock API) and the dwImageCPU to files. I compared the two files and found that the Y values are same, the U and V values are different.
And I try to write dwImageCPU image data to jpg file(using link (c++ - YUV420 to BGR image from pixel pointers - Stack Overflow). The jpg file is also with garbage.
So ,maybe the dwImageCPU image data not correct ?
I assume you are considering W/2*H/2 size for both U and V arrays. Image Streamer does not change any information in the image. It just changes the Image handle from NvMedia to CPU. Can you double check the ImageStreamer parameters? What if you use directly DwImageNvMedia buffers and save as output?
I post my code of getting dwImageCPU, is there something wrong with it ?
SensorIONvmedia::SensorIONvmedia(dwContextHandle_t context, Camera *camera, int cameraWidth, int cameraHeight)
: m_numSiblings(camera->numSiblings)
, m_sensor(camera->sensor)
, m_nvm2Cpu(DW_NULL_HANDLE)
, m_frameHandle(camera->numSiblings)
, m_frameNvmYuv(camera->numSiblings)
, m_frameCpuYuv(camera->numSiblings)
dwStatus result = DW_FAILURE;
result = dwContext_getNvMediaDevice(&m_nvmedia, context);
if (result != DW_SUCCESS)
    throw std::runtime_error(std::string("Error intializing nvmedia: ") + dwGetStatusName(result));
m_sensor = camera->sensor;
dwImageProperties cameraImageProperties;
dwSensorCamera_getImageProperties(&cameraImageProperties, DW_CAMERA_PROCESSED_IMAGE, m_sensor);
dwImageProperties displayImageProperties = cameraImageProperties;
displayImageProperties.type = DW_IMAGE_NVMEDIA;
result = dwImageStreamer_initialize(&m_nvm2Cpu, &displayImageProperties, DW_IMAGE_CPU, context);
if (result != DW_SUCCESS) {
    throw std::runtime_error(std::string("Cannot init image streamer nvm-cpu: ") + dwGetStatusName(result));
SensorIONvmedia::~SensorIONvmedia(){
if (m_nvm2Cpu != DW_NULL_HANDLE)
dwImageStreamer_release(&m_nvm2Cpu);
dwStatus SensorIONvmedia::getFrame(uint32_t siblingIdx){
// try different image types
result = dwSensorCamera_readFrame(&m_frameHandle[siblingIdx], siblingIdx, 1000000, m_sensor);
m_frameHandle[siblingIdx] = nullptr;
return result;
result = dwSensorCamera_getImageNvMedia(&m_frameNvmYuv[siblingIdx], DW_CAMERA_PROCESSED_IMAGE, m_frameHandle[siblingIdx]);
    m_frameNvmYuv[siblingIdx] = nullptr;
    return result;
// Send the YUV frame
result = dwImageStreamer_postNvMedia(m_frameNvmYuv[siblingIdx], m_nvm2Cpu); /*added*/
    std::cerr << "cannot post NvMedia YUV frame " << dwGetStatusName(result);
return DW_SUCCESS;
dwImageCPU *SensorIONvmedia::getCpuYuv(uint32_t siblingIdx){
if(!m_frameCpuYuv[siblingIdx])
dwStatus result = dwImageStreamer_receiveCPU(&m_frameCpuYuv[siblingIdx],60000,m_nvm2Cpu);
if(result != DW_SUCCESS)
std::cerr << "can not received CPU frame: " << dwGetStatusName(result);
m_frameCpuYuv[siblingIdx] = nullptr;
return m_frameCpuYuv[siblingIdx];
void SensorIONvmedia::releaseCpuYuvFrame(uint32_t siblingIdx){
if(m_frameCpuYuv[siblingIdx])
dwImageStreamer_returnReceivedCPU(m_frameCpuYuv[siblingIdx],m_nvm2Cpu);
void SensorIONvmedia::releaseFrame(uint32_t siblingIdx){
dwTime_t WAIT_TIME = 33000;
// any image returned back, we put back into the pool
    dwImageNvMedia *retimg = nullptr;
    dwStatus result = dwImageStreamer_waitPostedNvMedia(&retimg, WAIT_TIME, m_nvm2Cpu);
    if (result == DW_TIME_OUT) {
        IERROR << "Warning: waitPosted (nvmedia cpu) timed out\n";
    } else if (result != DW_SUCCESS) {
        IERROR << " ERROR waitPostedNvMedia GL: " << dwGetStatusName(result);
    } else {
        //m_rgbaImagePool.push_back(retimg);
if (m_frameHandle[siblingIdx]){
    dwSensorCamera_returnFrame(&m_frameHandle[siblingIdx]);
In my case, I create one streamer every CSI port, not every camera. Does this matter ?
Hi Henryeon,
I don’t notice any issue in the snippet. You said you have already checked pixelFormat and plain count values. Can you just check with a single camera first and let us know the observation
The log I captured is as below. I just open one camera. The pixle format seems YUV420, but the image data is not that format because I dumped the data and save as a jpg file. What is the really format ?
Received CPU image at 1536732204399765 type: 0 width: 1920 height: 1208 pxlFormat: 6000 pxlType: 64 planeCount: 3
Received CPU image at 1536732204433105 type: 0 width: 1920 height: 1208 pxlFormat: 6000 pxlType: 64 planeCount: 3
Received CPU image at 1536732204466435 type: 0 width: 1920 height: 1208 pxlFormat: 6000 pxlType: 64 planeCount: 3
Received CPU image at 1536732204499774 type: 0 width: 1920 height: 1208 pxlFormat: 6000 pxlType: 64 planeCount: 3
Received CPU image at 1536732204533144 type: 0 width: 1920 height: 1208 pxlFormat: 6000 pxlType: 64 planeCount: 3
Received CPU image at 1536732204566450 type: 0 width: 1920 height: 1208 pxlFormat: 6000 pxlType: 64 planeCount: 3
Received CPU image at 1536732204599793 type: 0 width: 1920 height: 1208 pxlFormat: 6000 pxlType: 64 planeCount: 3
Received CPU image at 1536732204633137 type: 0 width: 1920 height: 1208 pxlFormat: 6000 pxlType: 64 planeCount: 3
Received CPU image at 1536732204666454 type: 0 width: 1920 height: 1208 pxlFormat: 6000 pxlType: 64 planeCount: 3
Received CPU image at 1536732204699797 type: 0 width: 1920 height: 1208 pxlFormat: 6000 pxlType: 64 planeCount: 3
Received CPU image at 1536732204733139 type: 0 width: 1920 height: 1208 pxlFormat: 6000 pxlType: 64 planeCount: 3
Received CPU image at 1536732204766481 type: 0 width: 1920 height: 1208 pxlFormat: 6000 pxlType: 64 planeCount: 3
Received CPU image at 1536732204799838 type: 0 width: 1920 height: 1208 pxlFormat: 6000 pxlType: 64 planeCount: 3
Received CPU image at 1536732204833141 type: 0 width: 1920 height: 1208 pxlFormat: 6000 pxlType: 64 planeCount: 3
Received CPU image at 1536732204866498 type: 0 width: 1920 height: 1208 pxlFormat: 6000 pxlType: 64 planeCount: 3
Received CPU image at 1536732204899826 type: 0 width: 1920 height: 1208 pxlFormat: 6000 pxlType: 64 planeCount: 3
Received CPU image at 1536732204933170 type: 0 width: 1920 height: 1208 pxlFormat: 6000 pxlType: 64 planeCount: 3
Received CPU image at 1536732204966512 type: 0 width: 1920 height: 1208 pxlFormat: 6000 pxlType: 64 planeCount: 3
pxlFormat: 6000 means DW_IMAGE_YUV420 (Refer file:///usr/local/driveworks-0.6/doc/nvdwx_html/Image_8h_source.html)
pxlType: 64 means DW_TYPE_UINT8(Refer file:///usr/local/driveworks-0.6/doc/nvdwx_html/Types_8h_source.html). Make sure you are reading just 1 byte for each entry.
When you read the dwNvMediaImage data buffers and store it as jpeg image, do you see the expected image?
Sorry I don’t quite understand what this mean.
In my code, I copied the data[0] of dwImageCPU with size of width*height bytes to opencv mat data. (Because I think data[0] should to a whole picture of gray color.) Then convert mat data to RGB format and show mata data using imgshow() API. The image showing with garbage.
I also use another method to verify the data with link (c++ - YUV420 to BGR image from pixel pointers - Stack Overflow). That is writing data[0] with size widthheight to ypixel.bin ,writting data[1] with size widthheight/2 to upixel.bin, writing data[2] with size width*height/2 to vpixel.bin. Then use this three files to make YUV data to bgr. Then dump bgr data to jpeg file. The file displayed with all garbage.
In your opinion, how to use data in dwImageCPU ?
Dear Henryon,
Are you considering pitch value when reading image and creating Y U V files?
Can you share the piece of code to show reading dwImageCPU data array and storing it to file?
I have no idea to use the pitch value, could you give some advice ?
The following is my code piece:
       /*read dwImageCPU*/
        while(1) {
            for(int portIdx=0; portIdx<camera.number; portidx++){
                for(size_t j = 0; j < camera_sensor_[portIdx].numSiblings; j++){
                    if(cpu_frame_[portIdx] != nullptr){
                        sensorIO_[portIdx]->releaseCpuRgbaFrame(j);
                        sensorIO_[portIdx]->releaseFrame(j);
                        cpu_frame_[portIdx] = nullptr;
                    status = sensorIO_[portIdx]->getFrame(j);
                    if(status == DW_SUCCESS){
                        cpu_frame_[portIdx] = sensorIO_[portIdx]->getCpuRgba(j);
                    else{
                        std::cerr << "readFrame failed: " << dwGetStatusName(status);
                        continue;
        /*write YUV data to files*/
        int idx = cpu_frame_[0]->prop.width*cpu_frame_[0]->prop.height;
            std::ofstream file_y;
            file_y.open("/home/nvidia/Desktop/cpu_y.bin");
            for(int i=0; i<idx; i++)
                file_y << cpu_frame_[0]->data[0][i];
            std::ofstream file_u;
            file_u.open("/home/nvidia/Desktop/cpu_u.bin");
            for(int i=0; i<idx/4; i++)
                file_u << cpu_frame_[0]->data[1][i];
            std::ofstream file_v;
            file_v.open("/home/nvidia/Desktop/cpu_v.bin");
                file_v << cpu_frame_[0]->data[2][i];
It is super confusing. The name of the function suggesting a RGBA frame and you need YUV frame. I think the problem is not using pitch while reading pixel value.
Suppose you have a dwImageCPU with YUV420 pixelformat. So it will have 3 planes with data buffers.
To read each plane buffer correctly, check the following way.
for(int i=0; i < height; i ++)
  for (int j =0; j < width ; j++)
      read data[plane_num][i*pitch[plane_num]+j]
If this does not help, I need to look at your complete code to figure out the issue. Please file a bug with complete code as Driveworks sample.
