In the drive AGX orin platform, the result of converting the camera image to yuv is incorrect
Software Version
DRIVE OS 6.0.6
Target Operating System
Linux
Hardware Platform
In the drive AGX orin platform, the result of converting the camera image to yuv is incorrect,My code looks like this:
1、Create memory for image, and create a streamer
        dwImageProperties cpuProp{};
        cpuProp.type         = DW_IMAGE_CUDA;
        cpuProp.width        = 640;
        cpuProp.height       = 480;
        cpuProp.format       = DW_IMAGE_FORMAT_YUV420_UINT8_PLANAR;
        cpuProp.memoryLayout = DW_IMAGE_MEMORY_TYPE_DEFAULT; // not necessary to specify if init with {}
        dwStatus status = dwImage_create(&m_yuvCPU, cpuProp, m_context);
        if (status != DW_SUCCESS)
            logError("Cannot create m_yuvCPU: %s\n", dwGetStatusName(status));
            return false;
        status = dwImageStreamer_initialize(&m_streamerCUDA2CPU, &cpuProp, DW_IMAGE_CPU, m_context);
            logError("Cannot init image streamer m_streamerCUDA2CPU: %s\n", dwGetStatusName(status));
            return false;
2、Convert image:
CHECK_DW_ERROR(dwSensorCamera_getImage(&m_imageRGBA, DW_CAMERA_OUTPUT_CUDA_RGBA_UINT8, m_frame));
// format convert the RGB into YUV
status = dwImage_copyConvert(m_yuvCPU, m_imageRGBA, m_context);
	std::stringstream err;
	err << "Cannot format convert: " << dwGetStatusName(status);
	throw std::runtime_error(err.str().c_str());
3、post image to cpu,and save:
// post the cpu image. This will push the the image through the stream for type conversion.
status = dwImageStreamer_producerSend(m_yuvCPU, m_streamerCUDA2CPU);
    err << "Cannot post m_yuvCPU in m_streamerCUDA2CPU: " << dwGetStatusName(status);
dwImageHandle_t cpuImageYuv;
// receive a yuv that we can save
status = dwImageStreamer_consumerReceive(&cpuImageYuv, 1000, m_streamerCUDA2CPU);
    err << "Cannot return yuv image to m_streamerCUDA2CPU: " << dwGetStatusName(status);
// get an image from the frame
dwImageCPU* imgCPU;
CHECK_DW_ERROR(dwImage_getCPU(&imgCPU, cpuImageYuv));
FILE* fp;
fp = fopen("/home/nvidia/test_trans.yuv", "wb");
if (!fp)
    std::cout << "fopen error!" << std::endl;
    return;
fwrite(imgCPU->data[0], imgCPU->prop.width*imgCPU->prop.height*2, 1, fp);
// fwrite(imgCUDA->dptr[0], imgCUDA->pitch*imgCUDA->prop.height, 1, fp);
std::cout << "width: " << imgCPU->prop.width << std::endl;
std::cout << "height: " << imgCPU->prop.height << std::endl;
// fwrite(pImageCpu, imgCUDA->prop.width*imgCUDA->prop.height, 1, fp);
fclose(fp);
status = dwImageStreamer_consumerReturn(&cpuImageYuv, m_streamerCUDA2CPU);
    err << "Cannot return YUV image to m_streamerCUDA2CPU: " << dwGetStatusName(status);
status = dwImageStreamer_producerReturn(nullptr, 1000, m_streamerCUDA2CPU);
if ((status != DW_SUCCESS))
After executing the above code, the file test_trans.yuv is obtained. After viewing this file, it is found to be in the 8bpp format, and the desired result is not obtained. The yuv file I want is in yuv 420 format
test_trans.yuv (600 KB)
This is the yuv file I got. But it’s not what I expected.
Dear @TomFord,
Could you check the supported YUV image formats at https://developer.nvidia.com/docs/drive/drive-os/6.0.6/public/driveworks-nvsdk/group__image__group.html#gab7343d2f61d8450ef8451d4ec73d087c
