How to use Deepstream tracker when objects are similar in features and color
• Hardware Platform (Jetson / GPU) Jetson NX
• DeepStream Version 6.0
• JetPack Version (valid for Jetson only) 4.6
• TensorRT Version 8.0.1
• Issue Type( questions, new requirements, bugs) questions
I am currently using a tinyyolov4 model to perform object detection for person, hat, hivis, crane. See attached video. The issue I am having is when using the NvDCF tracker in Deepstream, the bounding box switches between the two crane objects when it moves from the top position to the bottom left shown in the following images. I have a feeling the crane objects are too similar in features and color and could be affecting the tracking ability. Also model is imperfect
I have attached my config files for the tracker.
tracker_config.yml (5.8 KB)
model_yolotiny.txt (757 Bytes)
dstest2_tracker_config.txt (551 Bytes)
Can I do anything else with the tracker config to improve this result?
Can you see the issue without tracker?
Sorry. I figured out my issue. My post-processing code was interfering with the output of the tracker hence why it was not working. I went back to the basics of running the deepstream-app in my PC using the nvcr.io/nvidia/deepstream:6.0-devel , and the tracker is working fine.
Thanks for replying.
