After adding a few debug prints and with some information from the other thread, I figure out the V4L2 subdev is not defined correctly for ov5693. This sensor only support bayer format, so we might change below code in ov5693_v4l2.c to only support bayer 10 format.
.enum_mbus_fmt = camera_common_enum_fmt,
This will avoid system hang caused by color format mismatch between VI and CSI camera.
After doing so, I can see only RG10 is listed (correct and as expected) if I pull the device supported format by ‘v4l2-ctl --list-formats’. However, I can not get any Gst pipeline running after doing this.
The format for bayer 10 in gstreamer should be something like this, but I cannot find an existing Gst plugin to accept this format. Could someone from NVIDIA show some examples about how to use Gst v4l2src to do on-board sensor capture?
'video/x-bayer, width=(int)1920, height=(int)1080, format=(string)rggb, framerate=(fraction)30/1'
