Hi SimonZhu.
Now I finish updating L4T 27.1 → 28.1
and finish installing jetpack 3.1
but I try to capture using camera. error occurred
I follow this step
2. After boot up, Copy Image, zImage to TX2 /boot.
3. copy 4.4.38-tegra-leopard.tgz to TX2 /lib/modules
sudo cp 4.4.38-tegra-leopard.tgz /lib/modules
cd /lib/modules
sudo tar zxvf 4.4.38-tegra-leopard.tgz
4. Copy camera_overrides.isp to TX2 /var/nvidia/nvcam/settings (if there is isp file)
sudo chmod 664 /var/nvidia/nvcam/settings/camera_overrides.isp
sudo chown root:root /var/nvidia/nvcam/settings/camera_overrides.isp
5. Reboot the TX2
6. Open a terminal and do "nvgstcapture-1.0”. You can will get live video output.
my stauts like this :
nvidia@tegra-ubuntu:/boot$ ls
dtb tegra186-quill-p3310-1000-a00-00-base.dtb
efi tegra186-quill-p3310-1000-c03-00-base.dtb
extlinux tegra186-quill-p3310-1000-c03-00-dsi-hdmi-dp.dtb
Image zImage
initrd
nvidia@tegra-ubuntu:/lib/modules$ ls
4.4.38-tegra 4.4.38-tegra-leopard 4.4.38-tegra-leopard.tgz
and I do “nvgstcapture-1.0”, I got error like this :
nvidia@tegra-ubuntu:~$ nvgstcapture-1.0
Encoder null, cannot set bitrate!
Encoder Profile = Baseline
Supported resolutions in case of CSI Camera
(2) : 640x480
(3) : 1280x720
(4) : 1920x1080
(5) : 2104x1560
(6) : 2592x1944
(7) : 2616x1472
(8) : 3840x2160
(9) : 3896x2192
(10): 4208x3120
(11): 5632x3168
(12): 5632x4224
Runtime CSI Camera Commands:
Help : 'h'
Quit : 'q'
Set Capture Mode:
mo:<val>
(1): image
(2): video
Get Capture Mode:
gmo
Set Sensor Id (0 to 10):
sid:<val> e.g., sid:2
Get Sensor Id:
gsid
Set sensor orientation:
so:<val>
(0): none
(1): Rotate counter-clockwise 90 degrees
(2): Rotate 180 degrees
(3): Rotate clockwise 90 degrees
Get sensor orientation:
gso
Set Whitebalance Mode:
wb:<val>
(0): off
(1): auto
(2): incandescent
(3): fluorescent
(4): warm-fluorescent
(5): daylight
(6): cloudy-daylight
(7): twilight
(8): shade
(9): manual
Get Whitebalance Mode:
gwb
Set Scene-Mode:
scm:<val>
(0): face-priority
(1): action
(2): portrait
(3): landscape
(4): night
(5): night-portrait
(6): theatre
(7): beach
(8): snow
(9): sunset
(10): steady-photo
(11): fireworks
(12): sports
(13): party
(14): candle-light
(15): barcode
Get Scene-Mode:
gscm
Set Color Effect Mode:
ce:<val>
(1): off
(2): mono
(3): negative
(4): solarize
(5): sepia
(6): posterize
(7): aqua
Get Color Effect Mode:
gce
Set Auto-Exposure Mode:
ae:<val>
(1): off
(2): on
(3): OnAutoFlash
(4): OnAlwaysFlash
(5): OnFlashRedEye
Get Auto-Exposure Mode:
gae
Set Flash Mode:
f:<val>
(0): off
(1): on
(2): torch
(3): auto
Get Flash Mode:
gf
Set Flicker Detection and Avoidance Mode:
fl:<val>
(0): off
(1): 50Hz
(2): 60Hz
(3): auto
Get Flicker Detection and Avoidance Mode:
gfl
Set Contrast (0 to 1):
ct:<val> e.g., ct:0.75
Get Contrast:
gct
Set Saturation (0 to 2):
st:<val> e.g., st:1.25
Get Saturation:
gst
Set Exposure Time in seconds:
ext:<val> e.g., ext:0.033
Get Exposure Time:
gext
Set Auto Exposure Lock(0/1):
ael:<val> e.g., ael:1
Get Auto Exposure Lock:
gael
Set Edge Enhancement (0 to 1):
ee:<val> e.g., ee:0.75
Get Edge Enhancement:
gee
Set ROI for AE:
It needs five values, ROI coordinates(top,left,bottom,right)
and weight in that order
aer:<val> e.g., aer:20 20 400 400 1.2
Get ROI for AE:
gaer
Set ROI for AWB:
wbr:<val> e.g., wbr:20 20 400 400 1.2
Get ROI for AWB:
gwbr
Set FPS range:
It needs two values, FPS Range (low, high) in that order
fpsr:<val> e.g., fpsr:15 30
Get FPS range:
gfpsr
Set WB Gains:
It needs four values (R, GR, GB, B) in that order
wbg:<val> e.g., wbg:1.2 2.2 0.8 1.6
Get WB Gains:
gwbg
Set TNR Strength (0 to 1):
ts:<val> e.g., ts:0.75
Get TNR Strength:
gts
Set TNR Mode:
tnr:<val>
(0): NoiseReduction_Off
(1): NoiseReduction_Fast
(2): NoiseReduction_HighQuality
Get TNR Mode:
gtnr
Capture: enter 'j' OR
followed by a timer (e.g., jx5000, capture after 5 seconds) OR
followed by multishot count (e.g., j:6, capture 6 images)
timer/multihot values are optional, capture defaults to single shot with timer=0s
Start Recording : enter '1'
Stop Recording : enter '0'
Video snapshot : enter '2' (While recording video)
Set Preview Resolution:
pcr:<val> e.g., pcr:3
(2) : 640x480
(3) : 1280x720
(4) : 1920x1080
(5) : 2104x1560
(6) : 2592x1944
(7) : 2616x1472
(8) : 3840x2160
(9) : 3896x2192
(10): 4208x3120
(11): 5632x3168
(12): 5632x4224
Note - For preview resolutions 4208x3120 and more use option --svs=nveglglessink
Get Preview Resolution:
gpcr
Set Image Resolution:
icr:<val> e.g., icr:3
(2) : 640x480
(3) : 1280x720
(4) : 1920x1080
(5) : 2104x1560
(6) : 2592x1944
(7) : 2616x1472
(8) : 3840x2160
(9) : 3896x2192
(10): 4208x3120
(11): 5632x3168
(12): 5632x4224
Get Image Capture Resolution:
gicr
Set Video Resolution:
vcr:<val> e.g., vcr:3
(2) : 640x480
(3) : 1280x720
(4) : 1920x1080
(5) : 2104x1560
(6) : 2592x1944
(7) : 2616x1472
(8) : 3840x2160
(9) : 3896x2192
Get Video Capture Resolution:
gvcr
Runtime encoder configuration options:
Set Encoding Bit-rate(in bytes):
br:<val> e.g., br:4000000
Get Encoding Bit-rate(in bytes):
gbr
Set Encoding Profile(only for H.264):
ep:<val> e.g., ep:1
(0): Baseline
(1): Main
(2): High
Get Encoding Profile(only for H.264):
gep
Force IDR Frame on video Encoder(only for H.264):
Enter 'f'
bitrate = 4000000
Socket read error. Camera Daemon stopped functioning.....
gst_nvcamera_open() failed ret=0
** (nvgstcapture-1.0:9950): CRITICAL **: <create_capture_pipeline:4565> can't set camera to playing
** (nvgstcapture-1.0:9950): CRITICAL **: <main:5367> Capture Pipeline creation failed
** Message: <main:5374> Capture completed
** Message: <main:5424> Camera application will now exit
I have two camera, I conntect on J1 and J2.
additionally, I try to setup argus software.
------Setup Argus software
Download the files from link below.
https://www.dropbox.com/s/0t6388fsiocuvz7/argus_R28.1.tgz?dl=0
1. sudo apt-get update
2. sudo apt-get install cmake libgtk-3-dev libjpeg-dev libgles2-mesa-dev libgstreamer1.0-dev
3. tar zxvf argus_R28.1.tgz
4. cd argus
5. mkdir build && cd build
6. cmake ..
7. make
8. sudo make install
9. Do "argus_camera --device=0”, “argus_camera --device=1” and “argus_camera --device=2”to get the video output. Video0 is J1 camera, video1 is J2 camera, and video3 is J3 camera.
but this occurred error too like this :
nvidia@tegra-ubuntu:~$ argus_camera --device=0
Executing Argus Sample Application (argus_camera)
Argus Version: 0.96.2 (multi-process)
Error generated. /home/nvidia/Downloads/argus/apps/camera/modules/Dispatcher.cpp, initialize:848 No cameras available
Error generated. /home/nvidia/Downloads/argus/apps/camera/modules/Dispatcher.cpp, Dispatcher:801 (propagating)
(NvCameraUtils) Error InvalidState: Mutex already initialized (in Mutex.cpp, function initialize(), line 41)
(Argus) Error InvalidState: (propagating from src/rpc/socket/client/ClientSocketManager.cpp, function open(), line 54)
(Argus) Error InvalidState: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function openSocketConnection(), line 205)
(Argus) Error InvalidState: Cannot create camera provider (in src/rpc/socket/client/SocketClientDispatch.cpp, function createCameraProvider(), line 129)
Error generated. /home/nvidia/Downloads/argus/apps/camera/modules/Dispatcher.cpp, initialize:840 Failed to create CameraProvider
Error generated. /home/nvidia/Downloads/argus/apps/camera/modules/Dispatcher.cpp, getInstance:824 Initalization failed
(Argus) Error InvalidState: Receive thread is not running cannot send. (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 94)
(Argus) Error InvalidState: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 101)
terminate called after throwing an instance of 'std::logic_error'
what(): basic_string::_M_construct null not valid
Aborted (core dumped)
how can I fix this error?
please let me know.
also, I wonder camera connect well…
can I check camera connecting well using ‘v4l2’?
→ I install v4l2-utils and I do ‘v4l2-ctl --list-devices’
it has occurred :
Failed to open /dev/video0: No such file or directory
thank you
