Simon, thanks for your help.
No, the camera kit has not worked before. The voltage to the board is 4.98V.
dmesg log:
sam@sam-desktop:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (simon@ubuntu) (gcc version 6.4.1 20170707 (Linaro GCC 6.4-2017.08) ) #1 SMP PREEMPT Sun Jun 30 15:19:02 CST 2019
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2b000000
[ 0.000000] OF: fdt: - ab200000 , 3da00000
[ 0.000000] OF: fdt: - 100000000 , 380000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a0697000
[ 0.000000] Found lut_mem: 00002008@a0693000
[ 0.000000] Found vpr, start=0xf0000000 size=8000000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000e4800000
[ 0.000000] On node 0 totalpages: 4095997
[ 0.000000] DMA zone: 6656 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 425981 pages, LIFO batch:31
[ 0.000000] Normal zone: 57344 pages used for memmap
[ 0.000000] Normal zone: 3670016 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc3ffe1f000 s53400 r8192 d32616 u94208
[ 0.000000] pcpu-alloc: s53400 r8192 d32616 u94208 alloc=23*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4031997
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa0697000 lut_mem=0x2008@0xa0693000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.2.2 vpr=0x8000000@0xf0000000 sdhci_tegra.en_boot_part_access=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29316(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Memory: 15995488K/16383988K available (15038K kernel code, 2914K rwdata, 6592K rodata, 8512K init, 605K bss, 322964K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f30000 ( 15040 KB)
[ 0.000000] .rodata : 0xffffff8008f30000 - 0xffffff80095b0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095b0000 - 0xffffff8009e00000 ( 8512 KB)
[ 0.000000] .data : 0xffffff8009e00000 - 0xffffff800a0d8808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a0d8808 - 0xffffff800a16fe3c ( 606 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf10000000 ( 256 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc400000000 ( 16384 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000034] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.008763] Console: colour dummy device 80x25
[ 0.012432] console [tty0] enabled
[ 0.015667] bootconsole [tegra_comb_uart0] disabled
[ 0.021044] kmemleak: Kernel memory leak detector disabled
[ 0.021135] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.021181] pid_max: default: 32768 minimum: 301
[ 0.022615] Security Framework initialized
[ 0.023505] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.023559] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.025807] ftrace: allocating 46788 entries in 183 pages
[ 0.504010] sched-energy: Sched-energy-costs installed from DT
[ 0.504519] ASID allocator initialised with 65536 entries
[ 0.547349] tegra-id: chipid=21917.
[ 0.547381] tegra-id: opt_subrevision=0.
[ 0.547456] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.547550] DTS File Name: /home/simon/R32.1/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.547624] DTB Build time: Jun 30 2019 16:03:26
[ 0.599570] CPU1: Booted secondary processor [4e0f0040]
[ 0.633427] CPU2: Booted secondary processor [4e0f0040]
[ 0.665786] CPU3: Booted secondary processor [4e0f0040]
[ 0.698210] CPU4: Booted secondary processor [4e0f0040]
[ 0.730662] CPU5: Booted secondary processor [4e0f0040]
[ 0.763334] CPU6: Booted secondary processor [4e0f0040]
[ 0.795628] CPU7: Booted secondary processor [4e0f0040]
[ 0.796254] Brought up 8 CPUs
[ 0.796601] SMP: Total of 8 processors activated.
[ 0.796658] CPU features: detected feature: Privileged Access Never
[ 0.796692] CPU features: detected feature: LSE atomic instructions
[ 0.796726] CPU features: detected feature: User Access Override
[ 0.796759] CPU features: detected feature: 32-bit EL0 Support
[ 0.802766] CPU: All CPU(s) started at EL2
[ 0.802879] alternatives: patching kernel code
[ 0.819143] devtmpfs: initialized
[ 0.883388] Initilizing CustomIPI irq domain
[ 0.884167] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.884238] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.888006] pinctrl core: initialized pinctrl subsystem
[ 0.888328] OS set in device tree is not L4T.
[ 0.888669] regulator-dummy: no parameters
[ 0.889020] Initializing plugin-manager
[ 0.889101] Plugin module not found
[ 0.889174] Plugin-manager status disabled
[ 0.890562] NET: Registered protocol family 16
[ 0.900076] pstore: using zlib compression
[ 0.901280] console [pstore-1] enabled
[ 0.901316] pstore: Registered ramoops as persistent store backend
[ 0.901359] ramoops: attached 0x200000@0xe8a00000, ecc: 0/0
[ 0.920122] cpuidle: using governor menu
[ 0.921811] bpmp: waiting for handshake
[ 0.921859] bpmp: handshake completed
[ 0.921942] bpmp: synchronizing channels
[ 0.921981] bpmp: channels synchronized
[ 0.922019] bpmp: mail init ok
[ 0.926640] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.927105] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.927148] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.927182] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.927214] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.927247] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.927283] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.927327] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.927375] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.927413] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.927448] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.932679] vdso: 2 pages (1 code @ ffffff8008f37000, 1 data @ ffffff8009e04000)
[ 0.933136] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.937831] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.938810] Registering BPMP clocks...
[ 0.938968] tegra_bpmp_clk_init: clock init ok (395 clks)
[ 0.939368] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.939833] tegra_powergate_init: DONE
[ 0.939998] DTS File Name: /home/simon/R32.1/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.940084] DTB Build time: Jun 30 2019 16:03:26
[ 0.943719] Tegra reboot handler registered.
[ 0.954838] iommu: Adding device 14180000.pcie to group 0
[ 0.955859] iommu: Adding device 14100000.pcie to group 1
[ 0.956880] iommu: Adding device 14140000.pcie to group 2
[ 0.957868] iommu: Adding device 141a0000.pcie to group 3
[ 0.959930] iommu: Adding device 2490000.ether_qos to group 4
[ 0.960775] iommu: Adding device 3100000.serial to group 5
[ 0.961621] iommu: Adding device 3110000.serial to group 6
[ 0.962411] iommu: Adding device 3140000.serial to group 7
[ 0.963337] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.963628] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.963727] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.963788] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.963848] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.963963] tegra-pmc: PMC Prod config success
[ 0.964302] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.964441] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.965029] iommu: Adding device 3460000.sdhci to group 8
[ 0.965886] iommu: Adding device 3400000.sdhci to group 9
[ 0.966721] iommu: Adding device 2450000.ufshci to group 10
[ 0.968109] iommu: Adding device 3160000.i2c to group 11
[ 0.968799] iommu: Adding device c240000.i2c to group 12
[ 0.969445] iommu: Adding device 3180000.i2c to group 13
[ 0.970154] iommu: Adding device 3190000.i2c to group 14
[ 0.971039] iommu: Adding device 31b0000.i2c to group 15
[ 0.971647] iommu: Adding device 31c0000.i2c to group 16
[ 0.972308] iommu: Adding device c250000.i2c to group 17
[ 0.973008] iommu: Adding device 31e0000.i2c to group 18
[ 0.974241] iommu: Adding device sound to group 19
[ 0.975035] iommu: Adding device 3510000.hda to group 20
[ 0.975941] iommu: Adding device bc00000.rtcpu to group 21
[ 0.979261] iommu: Adding device 13e10000.host1x to group 22
[ 0.979982] iommu: Adding device 13e10000.host1x:ctx0 to group 23
[ 0.980767] iommu: Adding device 13e10000.host1x:ctx1 to group 24
[ 0.981420] iommu: Adding device 13e10000.host1x:ctx2 to group 25
[ 0.982011] iommu: Adding device 13e10000.host1x:ctx3 to group 26
[ 0.982639] iommu: Adding device 13e10000.host1x:ctx4 to group 27
[ 0.983289] iommu: Adding device 13e10000.host1x:ctx5 to group 28
[ 0.983899] iommu: Adding device 13e10000.host1x:ctx6 to group 29
[ 0.984505] iommu: Adding device 13e10000.host1x:ctx7 to group 30
[ 0.985459] iommu: Adding device 15340000.vic to group 31
[ 0.986082] iommu: Adding device 15380000.nvjpg to group 32
[ 0.986578] iommu: Adding device 15500000.tsec to group 33
[ 0.987050] iommu: Adding device 15100000.tsecb to group 34
[ 0.987527] iommu: Adding device 15480000.nvdec to group 35
[ 0.988016] iommu: Adding device 15140000.nvdec1 to group 36
[ 0.988483] iommu: Adding device 154c0000.nvenc to group 37
[ 0.988977] iommu: Adding device 15a80000.nvenc1 to group 38
[ 0.989641] iommu: Adding device 15880000.nvdla0 to group 39
[ 0.990278] iommu: Adding device 158c0000.nvdla1 to group 40
[ 0.991129] iommu: Adding device 15200000.nvdisplay to group 41
[ 0.991509] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0697000(800000)
[ 0.991610] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0693000(3000)
[ 0.992978] platform 15200000.nvdisplay: IOVA linear map 0x00000000f0000000(8000000)
[ 0.993070] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.993876] iommu: Adding device 15210000.nvdisplay to group 42
[ 0.994149] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.995010] iommu: Adding device 15220000.nvdisplay to group 43
[ 0.995120] t19x-arm-smmu: Adding 15220000.nvdisplay to ISO SMMU client
[ 0.998425] iommu: Adding device 15c10000.vi to group 44
[ 0.998735] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.999515] iommu: Adding device 14800000.isp to group 45
[ 1.001079] iommu: Adding device 16000000.pva0 to group 46
[ 1.002177] iommu: Adding device 16800000.pva1 to group 47
[ 1.002880] iommu: Adding device 15810000.se to group 48
[ 1.003530] iommu: Adding device 15820000.se to group 49
[ 1.004008] iommu: Adding device 15830000.se to group 50
[ 1.004468] iommu: Adding device 15840000.se to group 51
[ 1.004977] iommu: Adding device c1a0000.aon to group 52
[ 1.007394] iommu: Adding device d000000.bpmp to group 53
[ 1.007947] bpmp: ping status is 0
[ 1.008195] bpmp d000000.bpmp: firmware tag is 1c1b2165fe52a0a54ad7caf60d40cdc3
[ 1.012184] bpmp d000000.bpmp: probe ok
[ 1.014444] tegra-reset 0.bpmp_reset: registered 186 resets.
[ 1.015324] iommu: Adding device smmu_test to group 54
[ 1.017086] mc: mapped MMIO address: 0xffffff800a540000 -> 0x2c10000
[ 1.017232] mc: mapped MMIO address: 0xffffff800a560000 -> 0x2c20000
[ 1.017363] mc: mapped MMIO address: 0xffffff800a580000 -> 0x2c30000
[ 1.017458] mc: mapped MMIO address: 0xffffff800a5a0000 -> 0x2c40000
[ 1.017550] mc: mapped MMIO address: 0xffffff800a5c0000 -> 0x2c50000
[ 1.017643] mc: mapped MMIO address: 0xffffff800a5e0000 -> 0x2b80000
[ 1.017736] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2b90000
[ 1.017826] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2ba0000
[ 1.017922] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2bb0000
[ 1.018024] mc: mapped MMIO address: 0xffffff800b030000 -> 0x1700000
[ 1.018115] mc: mapped MMIO address: 0xffffff800b050000 -> 0x1710000
[ 1.018214] mc: mapped MMIO address: 0xffffff800b070000 -> 0x1720000
[ 1.018338] mc: mapped MMIO address: 0xffffff800b090000 -> 0x1730000
[ 1.018430] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x1740000
[ 1.018528] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1750000
[ 1.018620] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1760000
[ 1.018711] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1770000
[ 1.018896] mc-err: mcerr ops are set to t19x
[ 1.028371] iommu: Adding device 2600000.dma to group 55
[ 1.037573] GPIO line 490 (pcie-reg-enable) hogged as output/high
[ 1.037796] GPIO line 289 (pcie-reg-enable) hogged as output/high
[ 1.037948] GPIO line 339 (wifi-enable) hogged as output/high
[ 1.038061] GPIO line 347 (camera-control-output-low) hogged as output/low
[ 1.038608] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 1.050463] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 1.051102] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 1.054642] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 1.054714] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 1.055952] iommu: Adding device 3550000.xudc to group 56
[ 1.057068] iommu: Adding device 3610000.xhci to group 57
[ 1.060697] arm64_ras arm64_ras: probed
[ 1.061497] ras_fhi_enable: FHI 474 enabled on CPU0
[ 1.061651] ras_fhi_enable: FHI 475 enabled on CPU1
[ 1.061810] ras_fhi_enable: FHI 476 enabled on CPU2
[ 1.061948] ras_fhi_enable: FHI 477 enabled on CPU3
[ 1.062079] ras_fhi_enable: FHI 478 enabled on CPU4
[ 1.062217] ras_fhi_enable: FHI 479 enabled on CPU5
[ 1.062340] ras_fhi_enable: FHI 480 enabled on CPU6
[ 1.062574] ras_fhi_enable: FHI 481 enabled on CPU7
[ 1.062939] carmel_ras_enable: RAS enabled on cpu0
[ 1.063454] carmel_ras_enable: RAS enabled on cpu1
[ 1.063797] carmel_ras_enable: RAS enabled on cpu2
[ 1.064181] carmel_ras_enable: RAS enabled on cpu3
[ 1.064586] carmel_ras_enable: RAS enabled on cpu4
[ 1.064985] carmel_ras_enable: RAS enabled on cpu5
[ 1.065285] carmel_ras_enable: RAS enabled on cpu6
[ 1.065587] carmel_ras_enable: RAS enabled on cpu7
[ 1.065731] carmel_ras carmel_ras: probed
[ 1.067324] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 483, noc_nonsecure_irq = 482>
[ 1.068182] tegra-cbb c600000.aon-noc: noc_secure_irq = 485, noc_nonsecure_irq = 484>
[ 1.069358] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 487, noc_nonsecure_irq = 486>
[ 1.070525] tegra-cbb be00000.rce-noc: noc_secure_irq = 489, noc_nonsecure_irq = 488>
[ 1.071594] tegra-cbb b600000.sce-noc: noc_secure_irq = 491, noc_nonsecure_irq = 490>
[ 1.072224] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 1.075941] vdd-3v3-cvb: 3300 mV
[ 1.076431] vdd-1v8-cvb: 1800 mV
[ 1.076965] vdd-1v8-sd: 1800 mV
[ 1.077483] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 1.077583] vdd-epb-1v0: 1000 mV
[ 1.078133] vdd-sdmmc1-sw: 3300 mV
[ 1.078678] avdd-cam-2v8: 2800 mV
[ 1.079219] vdd-sata-1v5: 1500 mV
[ 1.079671] vdd-1v8-slt: 1800 mV
[ 1.080263] vdd-3v3-slt: 3300 mV
[ 1.080743] vdd-fan: 5000 mV
[ 1.081311] vdd-hdmi-5v0: 5000 mV
[ 1.081854] vdd_sys_en: 1200 mV
[ 1.082480] vdd-5v-sata: 5000 mV
[ 1.083014] vdd-ac-bat: 5000 mV
[ 1.083302] vdd-5v-sata: supplied by vdd-ac-bat
[ 1.117304] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.123283] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.123748] SCSI subsystem initialized
[ 1.124142] libata version 3.00 loaded.
[ 1.124437] usbcore: registered new interface driver usbfs
[ 1.124603] usbcore: registered new interface driver hub
[ 1.124827] usbcore: registered new device driver usb
[ 1.138520] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 1.141831] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 1.153737] vdd-1v0: at 1000 mV
[ 1.161585] vdd-1v8-hs: at 1800 mV
[ 1.169657] vdd-1v8-ls: at 1800 mV
[ 1.177721] vdd-1v8-ao: at 1800 mV
[ 1.185827] vddio-ddr-1v1: at 1100 mV
[ 1.193569] vdd-rtc: at 800 mV
[ 1.194892] spmic-ldo1: at 2375 mV
[ 1.203079] vdd-ao-3v3: at 3300 mV
[ 1.211102] vddio-emmc-3v3: at 3300 mV
[ 1.212475] spmic-ldo4: at 1587 mV
[ 1.219186] vdd-usb-3v3: at 3300 mV
[ 1.227264] vddio-sdmmc1-3v3: at 3300 mV
[ 1.231262] vdd-csi-1v2: at 1200 mV
[ 1.232697] spmic-ldo8: at 1800 mV
[ 1.234332] GPIO line 246 (gpio_default) hogged as output/high
[ 1.235476] GPIO line 247 (gpio_default) hogged as output/high
[ 1.236062] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 1.239669] max77620 4-003c: max77620 probe successful
[ 1.240497] media: Linux media interface: v0.10
[ 1.240625] Linux video capture interface: v2.00
[ 1.242347] pps_core: LinuxPPS API ver. 1 registered
[ 1.242398] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.242514] PTP clock support registered
[ 1.243259] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.243416] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 1.244883] tegra_fiq_debugger_init: found FIQ source (IRQ 466)
[ 1.247421] Advanced Linux Sound Architecture Driver Initialized.
[ 1.248282] Bluetooth: Core ver 2.22
[ 1.248514] NET: Registered protocol family 31
[ 1.248560] Bluetooth: HCI device and connection manager initialized
[ 1.248633] Bluetooth: HCI socket layer initialized
[ 1.248686] Bluetooth: L2CAP socket layer initialized
[ 1.248760] Bluetooth: SCO socket layer initialized
[ 1.252234] camchar: rtcpu character device driver loaded
[ 1.254339] clocksource: Switched to clocksource arch_sys_counter
[ 1.307100] VFS: Disk quotas dquot_6.6.0
[ 1.307329] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.308312] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.310522] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.310698] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000f0000000,134217728
[ 1.310780] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.310874] nvmap_page_pool_init: Total RAM pages: 4015256
[ 1.310923] nvmap_page_pool_init: nvmap page pool size: 501907 pages (1960 MB)
[ 1.311235] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.311727] misc nvmap: created heap vpr base 0x00000000f0000000 size (131072KiB)
[ 1.313678] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.332525] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.332911] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.333293] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.333662] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.334200] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[ 1.334736] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[ 1.334971] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 1.336480] la/ptsa driver initialized.
[ 1.337047] NET: Registered protocol family 2
[ 1.338372] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.339249] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.340159] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.340277] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.340635] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.341424] NET: Registered protocol family 1
[ 1.342590] RPC: Registered named UNIX socket transport module.
[ 1.342644] RPC: Registered udp transport module.
[ 1.342687] RPC: Registered tcp transport module.
[ 1.342729] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.342786] PCI: CLS 0 bytes, default 64
[ 1.343003] Trying to unpack rootfs image as initramfs...
[ 1.371828] host1x 13e10000.host1x: initialized
[ 1.375052] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.382073] audit: initializing netlink subsys (disabled)
[ 1.382164] audit: type=2000 audit(0.912:1): initialized
[ 1.383386] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 1.397380] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.399392] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.400461] 9p: Installing v9fs 9p2000 file system support
[ 1.407925] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.408397] io scheduler noop registered
[ 1.408795] io scheduler cfq registered (default)
[ 1.413683] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.415179] random: fast init done
[ 1.453293] iommu: Adding device 2993000.adsp to group 58
[ 1.557508] iommu: Adding device aconnect@2a41000:adsp_audio to group 59
[ 1.558620] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.576215] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.576952] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.577620] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.582070] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.582487] misc tegra_camera_ctrl: tegra_camera_isomgr_register: some fields not in DT.
[ 1.582553] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=0, vi_iso_bw=6000000, max_bw=6000000
[ 1.586758] tsec 15500000.tsec: initialized
[ 1.589217] tsec 15100000.tsecb: initialized
[ 1.594646] nvdec 15480000.nvdec: initialized
[ 1.598395] nvdec 15140000.nvdec1: initialized
[ 1.603739] falcon 15340000.vic: initialized
[ 1.606254] falcon 15380000.nvjpg: initialized
[ 1.608469] falcon 154c0000.nvenc: initialized
[ 1.610827] falcon 15a80000.nvenc1: initialized
[ 1.614045] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.616718] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.619356] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.621886] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.624542] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.627460] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.630112] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.632818] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.637989] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.644766] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.645356] scare-pigeon 14b00000.isp-thi: initialized
[ 1.656506] pva 16000000.pva0: initialized
[ 1.689283] pva 16800000.pva1: initialized
[ 1.721028] nvdla 15880000.nvdla0: initialized
[ 1.752330] nvdla 158c0000.nvdla1: initialized
[ 1.754537] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.754610] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.754698] tegradccommon 15200000.dc_common: dma mapping done
[ 1.755553] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
[ 1.755682] generic_infoframe_type: 0x87
[ 1.755842] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.755931] tegradc 15200000.nvdisplay: Display dc.ffffff800bc20000 registered with id=0
[ 1.763676] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.763734] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 1.763780] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 1.764120] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.764173] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.765660] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.768090] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 1.768197] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.768253] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.769397] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.769905] kfuse 3830000.kfuse: initialized
[ 1.773582] tegradc 15200000.nvdisplay: probed
[ 1.779578] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.783901] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 50, base_baud = 0) is a TEGRA_UART
[ 1.785650] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 51, base_baud = 0) is a TEGRA_UART
[ 1.787091] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 52, base_baud = 0) is a TEGRA_UART
[ 4.236186] console [ttyTCU0] enabled
[ 4.236899] Console: switching to colour frame buffer device 240x67
[ 4.236924] [drm] Initialized
[ 4.249014] tegradc 15200000.nvdisplay: fb registered
[ 4.254674] gpio tegra-gpio wake71 for gpio=98(M:2)
[ 4.259945] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.265256] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.269670] brd: module loaded
[ 4.278744] loop: module loaded
[ 4.279106] tegra_profiler: version: 1.132, samples/io: 46/26
[ 4.283296] tegra_profiler: auth: init
[ 4.287499] nct1008_nct72 4-004c: starting parse dt
[ 4.287901] THERMAL EST: found 3 subdevs
[ 4.287906] THERMAL EST num_resources: 0
[ 4.287911] [THERMAL EST subdev 0]
[ 4.287919] [THERMAL EST subdev 1]
[ 4.287924] [THERMAL EST subdev 2]
[ 4.288404] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 4.288407] THERMAL EST: thz register success.
[ 4.288632] THERMAL EST: end of probe, return err: 0
[ 4.288867] Parent Clock set for DC plld3
[ 4.289898] ufs_tegra 2450000.ufshci: freq-table-hz property not specified
[ 4.289907] ufs_tegra 2450000.ufshci: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 4.290874] ufs_tegra 2450000.ufshci: wakeup init done, cdirq 456
[ 4.290884] gpio tegra-gpio-aon wake25 for gpio=32(EE:0)
[ 4.304223] scsi host0: ufshcd
[ 4.319215] hisi_sas: driver version v1.6
[ 4.323214] libphy: Fixed MDIO Bus: probed
[ 4.324709] tun: Universal TUN/TAP device driver, 1.6
[ 4.324712] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 4.325782] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.325786] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.325862] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.325865] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.325932] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.325934] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.325990] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 4.325992] Copyright(c) 1999 - 2017 Intel Corporation.
[ 4.327688] eqos 2490000.ether_qos: no PHY interrupt found
[ 4.331430] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b cb 9f 2f
[ 4.331684] libphy: dwc_phy: probed
[ 4.334636] PPP generic driver version 2.4.2
[ 4.334901] PPP BSD Compression module registered
[ 4.334905] PPP Deflate Compression module registered
[ 4.334934] PPP MPPE Compression module registered
[ 4.334940] NET: Registered protocol family 24
[ 4.335050] usbcore: registered new interface driver r8152
[ 4.335131] usbcore: registered new interface driver asix
[ 4.335262] usbcore: registered new interface driver ax88179_178a
[ 4.335378] usbcore: registered new interface driver cdc_ether
[ 4.335496] usbcore: registered new interface driver net1080
[ 4.335611] usbcore: registered new interface driver cdc_subset
[ 4.335729] usbcore: registered new interface driver zaurus
[ 4.335865] usbcore: registered new interface driver cdc_ncm
[ 4.336252] VFIO - User Level meta-driver version: 0.3
[ 4.338057] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.338080] ehci-pci: EHCI PCI platform driver
[ 4.338199] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.338211] ohci-pci: OHCI PCI platform driver
[ 4.338364] ohci-platform: OHCI generic platform driver
[ 4.345859] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 4.345865] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[ 4.348714] tegradc 15200000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 4.349048] Could not get extcon-dev /xhci@3610000:id(0)
[ 4.349410] tegradc 15200000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 4.349423] tegradc 15200000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 4.350088] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 4.350091] Extcon AUX2(HDMI) enable
[ 4.350856] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 4.351343] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 4.352580] usbcore: registered new interface driver uas
[ 4.352665] usbcore: registered new interface driver usb-storage
[ 4.352775] usbcore: registered new interface driver usbserial
[ 4.356751] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 4.356849] Could not get extcon-dev /xudc@3550000:vbus(0)
[ 4.359954] ucsi_ccg 1-0008: FW1 Version: gn v12.05, [Base 3.1.2.1487]
[ 4.359964] ucsi_ccg 1-0008: FW2 Version: gn v12.05, [Base 3.1.2.1487]
[ 4.361083] ucsi_ccg 1-0008: fw_mode: 2
[ 4.361088] ucsi_ccg 1-0008: fw1_invalid: 0
[ 4.361092] ucsi_ccg 1-0008: fw2_invalid: 0
[ 4.361098] ucsi_ccg 1-0008: silicon_id: 0x1f00
[ 4.361315] ucsi_ccg 1-0008: typec-port0 extcon dev created
[ 4.361509] ucsi_ccg 1-0008: typec-port1 extcon dev created
[ 4.361659] ucsi_ccg 1-0008: typec-pd extcon dev created
[ 4.361836] gpio tegra-gpio-aon wake48 for gpio=10(BB:2)
[ 4.367554] ucsi_ccg 1-0008: HPI Command Success.
[ 4.370088] ucsi_ccg 1-0008: HPI Command Success.
[ 4.370108] ucsi_ccg 1-0008: ucsi_ccg_init: complete
[ 4.370962] mousedev: PS/2 mouse device common for all mice
[ 4.371091] usbcore: registered new interface driver xpad
[ 4.505964] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 4.508161] Wake73 for irq=42
[ 4.509633] rtc rtc1: alarm rtc device
[ 4.509691] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 4.509722] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.509931] i2c /dev entries driver
[ 4.512624] pca954x 2-0070: vcc-pullup regulator not found
[ 4.512652] pca954x 2-0070: pca954x_probe: forcing device bus number, start 30.
[ 4.512658] pca954x 2-0070: device detect skipped.
[ 4.513400] i2c i2c-2: Added multiplexed i2c bus 30
[ 4.514304] i2c i2c-2: Added multiplexed i2c bus 31
[ 4.515042] i2c i2c-2: Added multiplexed i2c bus 32
[ 4.515670] i2c i2c-2: Added multiplexed i2c bus 33
[ 4.515680] pca954x 2-0070: registered 4 multiplexed busses for I2C switch pca9546
[ 4.517720] pca9570 30-0024: pca9570_icr_move, forward val=5
[ 4.805004] tegradc 15200000.nvdisplay: blank - powerdown
[ 4.805023] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 4.805031] nct1008_nct72 4-004c: success parsing dt
[ 4.805177] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 4.837830] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 4.838712] nct1008_nct72 4-004c: EXT shutdown limit 109
[ 4.849470] extcon-disp-state external-connection:disp-state: cable 48 state 0
[ 4.849474] Extcon AUX2(HDMI) disable
[ 4.872095] nct1008_nct72 4-004c: initial LOC temp: 44000
[ 4.876381] nct1008_nct72 4-004c: initial EXT temp: 46000
[ 4.876830] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 4.878568] nct1008_nct72 4-004c: hi_b:-10, lo_b:128
[ 4.878582] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 4.880839] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 4.906698] tegradc 15200000.nvdisplay: unblank
[ 4.908883] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.909178] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.926139] Parent Clock set for DC plld3
[ 4.931827] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 4.933419] tegradc 15200000.nvdisplay: hdmi: get RGB quant from EDID.
[ 4.933434] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 4.937551] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 4.937555] Extcon AUX2(HDMI) enable
[ 5.624261] pca9570 30-0024: pca9570_probe: success
[ 5.624478] pca9570 31-0024: pca9570_icr_move, forward val=5
[ 6.732936] pca9570 31-0024: pca9570_probe: success
[ 6.733194] pca9570 32-0024: pca9570_icr_move, forward val=5
[ 6.843530] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 6.843806] pca9570 32-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 6.844054] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 6.844311] pca9570 32-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 6.954579] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 6.954811] pca9570 32-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 6.955043] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 6.955294] pca9570 32-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[ 7.065651] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 7.065880] pca9570 32-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 7.066108] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 7.066412] pca9570 32-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 7.103595] extcon-disp-state external-connection:disp-state: cable 40 state 1
[ 7.110678] Extcon HDMI: HPD enabled
[ 7.114376] tegradc 15200000.nvdisplay: hdmi: plugged
[ 7.176720] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 7.180091] pca9570 32-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 7.183395] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 7.186696] pca9570 32-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[ 7.300073] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 7.303494] pca9570 32-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 7.307046] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 7.311779] pca9570 32-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 7.425161] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 7.428516] pca9570 32-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 7.431991] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 7.435311] pca9570 32-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[ 7.548766] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 7.552127] pca9570 32-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 7.555560] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 7.558990] pca9570 32-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 7.672453] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 7.675935] pca9570 32-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 7.679442] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 7.682905] pca9570 32-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[ 7.797813] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 7.801337] pca9570 32-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 7.804846] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 7.808310] pca9570 32-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 7.921828] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 7.925292] pca9570 32-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 7.928792] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 7.932209] pca9570 32-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[ 7.935532] pca9570 32-0024: pca9570_icr_move:i2c write failed
[ 7.938994] pca9570: probe of 32-0024 failed with error -121
[ 7.942528] pca9570 33-0024: pca9570_icr_move, forward val=5
[ 8.056129] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 8.060537] pca9570 33-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 8.064260] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 8.067890] pca9570 33-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 8.181531] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 8.185138] pca9570 33-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 8.188713] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 8.192310] pca9570 33-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[ 8.305976] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 8.309636] pca9570 33-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 8.313332] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 8.316972] pca9570 33-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 8.430632] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 8.434212] pca9570 33-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 8.438875] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 8.442678] pca9570 33-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[ 8.556374] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 8.560083] pca9570 33-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 8.563831] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 8.567576] pca9570 33-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 8.681434] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 8.685564] pca9570 33-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 8.689442] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 8.693204] pca9570 33-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[ 8.807145] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 8.811187] pca9570 33-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 8.815054] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 8.820186] pca9570 33-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 8.934063] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 8.937926] pca9570 33-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 8.941741] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 8.945528] pca9570 33-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[ 9.059359] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 9.063185] pca9570 33-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 9.067027] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 9.070839] pca9570 33-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 9.184701] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 9.188537] pca9570 33-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 9.192361] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 9.197464] pca9570 33-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[ 9.201037] pca9570 33-0024: pca9570_icr_move:i2c write failed
[ 9.204792] pca9570: probe of 33-0024 failed with error -121
[ 9.208872] imx377 30-001a: probing v4l2 sensor
[ 9.213181] imx377 30-001a: tegracam sensor driver:imx377_v2.0.6
[ 9.267659] imx377 30-001a: Detected IMX377 sensor
[ 9.271204] imx377 31-001a: probing v4l2 sensor
[ 9.275127] imx377 31-001a: tegracam sensor driver:imx377_v2.0.6
[ 9.329528] imx377 31-001a: Detected IMX377 sensor
[ 9.333033] imx377 32-001a: probing v4l2 sensor
[ 9.336888] imx377 32-001a: tegracam sensor driver:imx377_v2.0.6
[ 9.391197] imx377 32-001a: Detected IMX377 sensor
[ 9.394644] imx377 33-001a: probing v4l2 sensor
[ 9.398967] imx377 33-001a: tegracam sensor driver:imx377_v2.0.6
[ 9.453756] imx377 33-001a: Detected IMX377 sensor
[ 9.457691] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 9.466410] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 9.470189] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 2 not supported
[ 9.476769] tegra-thermal-throttle bthrot_cdev: clk:cpu max:2265600000, min:115200000 steps:28
[ 9.534322] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1377000000, min:114750000 steps:13
[ 9.537647] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 9.540897] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 9.544288] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:56 cutoff:0
[ 9.547556] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 9.550744] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 9.554236] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:52 cutoff:1
[ 9.558787] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 9.561864] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 9.565332] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:56 cutoff:0
[ 9.568535] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 9.571610] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 9.575154] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 9.578294] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 9.581328] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 9.584783] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:52 cutoff:1
[ 9.588530] FAN dev name: pwm-fan
[ 9.591519] FAN:gpio request success.
[ 9.594265] FAN: can't find tach_gpio
[ 9.597075] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 9.603199] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 9.609485] pwm_fan_driver pwm-fan: tach period: 1000
[ 9.614916] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 9.622187] pwm_fan_driver pwm-fan: index 1: pwm=77, rpm=1000, rru=2, rrd=2, state:2
[ 9.629849] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 9.637601] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 9.644992] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 9.652820] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 9.660814] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 9.668731] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 9.676301] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 9.684307] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[code]
[ 9.693525] device-mapper: uevent: version 1.0.3
[ 9.697848] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 9.709598] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 9.713991] cpuidle: Initializing cpuidle driver
[ 9.718560] sdhci: Secure Digital Host Controller Interface driver
[ 9.723550] sdhci: Copyright© Pierre Ossman
[ 9.727991] sdhci-pltfm: SDHCI platform and OF driver helper
[ 9.735188] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 9.742783] CMDQ: cmdq_platfm_init successful
[ 9.746170] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 9.753735] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 9.759078] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 251
[ 9.767931] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 9.771502] tegra-se-nvhost 15810000.se: initialized
[ 9.776269] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 9.781988] tegra-se-nvhost 15820000.se: initialized
[ 9.787235] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 9.790483] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 9.802432] tegra-se-nvhost 15830000.se: initialized
[ 9.807419] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 9.810530] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 9.810614] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 9.827527] tegra-se-nvhost 15840000.se: initialized
[ 9.832735] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 9.838263] hidraw: raw HID events driver © Jiri Kosina
[ 9.844892] usbcore: registered new interface driver usbhid
[ 9.849108] usbhid: USB HID core driver
[ 9.858447] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 9.861714] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 9.867097] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 9.872187] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 9.872536] denver_knobs_init:MTS_VERSION:44201972
[ 9.872694] tegra19x_actmon d230000.actmon: in actmon_register()…
[ 9.891011] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 9.899464] t19x_cache tegra-cache: probed
[ 9.902000] mmc0: periodic cache flush enabled
[ 9.902011] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 9.902498] mmcblk0: mmc0:0001 HBG4a2 29.1 GiB
[ 9.902755] mmcblk0boot0: mmc0:0001 HBG4a2 partition 1 8.00 MiB
[ 9.902994] mmcblk0boot1: mmc0:0001 HBG4a2 partition 2 8.00 MiB
[ 9.903199] mmcblk0rpmb: mmc0:0001 HBG4a2 partition 3 4.00 MiB
[ 9.906020] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33 p34 p35 p36 p37
[ 9.956545] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 9.958202] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 9.967787] nvpmodel: initialized successfully
[ 9.970915] tegra-hda 3510000.hda: Override SDO lines to 4
[ 9.971881] usbcore: registered new interface driver snd-usb-audio
[ 10.001338] input: tegra-hda-galen-t194 HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 10.002972] input: tegra-hda-galen-t194 HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 10.004484] input: tegra-hda-galen-t194 HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 10.008187] input: tegra-hda-galen-t194 HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 11.751962] gpio tegra-gpio wake12 for gpio=149(S:5)
[ 11.843661] OPE platform probe
[ 11.845161] OPE platform probe successful
[ 11.978959] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 11.980478] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 11.981868] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 11.983284] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 11.984657] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 11.986011] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 11.987421] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 11.988799] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 11.990161] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 11.991539] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 11.992890] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 11.994244] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 11.995626] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 11.996958] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 11.998304] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 11.999652] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 12.000947] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 12.002227] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 12.003516] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 12.004773] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 12.046959] input: tegra-snd-t19x-mobile-rt565x Headset Jack as /devices/sound/sound/card1/input4
[ 12.049625] u32 classifier
[ 12.050773] Actions configured
[ 12.051951] Initializing XFRM netlink socket
[ 12.053712] NET: Registered protocol family 10
[ 12.055634] NET: Registered protocol family 17
[ 12.056732] NET: Registered protocol family 15
[ 12.057851] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 12.059214] Bluetooth: RFCOMM socket layer initialized
[ 12.060372] Bluetooth: RFCOMM ver 1.11
[ 12.061459] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 12.066771] Bluetooth: HIDP socket layer initialized
[ 12.072039] 9pnet: Installing 9P2000 support
[ 12.076178] Key type dns_resolver registered
[ 12.081109] Registered cp15_barrier emulation handler
[ 12.085951] Registered setend emulation handler
[ 12.092296] registered taskstats version 1
[ 12.095160] tegra-pcie-dw 14180000.pcie: Setting init speed to max speed
[ 12.102535] OF: PCI: host bridge /pcie@14180000 ranges:
[ 12.106766] OF: PCI: IO 0x38100000…0x381fffff -> 0x38100000
[ 12.112840] OF: PCI: MEM 0x38200000…0x39ffffff -> 0x38200000
[ 12.118530] OF: PCI: MEM 0x1800000000…0x1bffffffff -> 0x1800000000
[ 12.638865] tegra-pcie-dw 14180000.pcie: link is down
[ 12.640186] tegra-pcie-dw 14180000.pcie: PCI host bridge to bus 0000:00
[ 12.641265] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 12.642314] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[ 12.643469] pci_bus 0000:00: root bus resource [mem 0x38200000-0x39ffffff]
[ 12.644548] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1bffffffff pref]
[ 12.645645] pci 0000:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 12.645814] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 12.646070] iommu: Adding device 0000:00:00.0 to group 60
[ 12.647375] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 12.648412] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 12.649753] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 12.650882] pcie_pme 0000:00:00.0:pcie001: service driver pcie_pme loaded
[ 12.651001] aer 0000:00:00.0:pcie002: service driver aer loaded
[ 12.651191] pcie_pme 0000:00:00.0:pcie001: unloading service driver pcie_pme
[ 12.651232] aer 0000:00:00.0:pcie002: unloading service driver aer
[ 12.651306] pci_bus 0000:01: busn_res: [bus 01-ff] is released
[ 12.651371] iommu: Removing device 0000:00:00.0 from group 60
[ 12.652519] pci_bus 0000:00: busn_res: [bus 00-ff] is released
[ 12.652781] tegra-pcie-dw 14180000.pcie: PCIe link is not up…!
[ 12.654572] tegra-pcie-dw 14100000.pcie: Setting init speed to max speed
[ 12.656453] OF: PCI: host bridge /pcie@14100000 ranges:
[ 12.657482] OF: PCI: IO 0x30100000…0x301fffff -> 0x30100000
[ 12.658552] OF: PCI: MEM 0x30200000…0x31ffffff -> 0x30200000
[ 12.659615] OF: PCI: MEM 0x1200000000…0x123fffffff -> 0x1200000000
[ 12.766433] tegra-pcie-dw 14100000.pcie: link is up
[ 12.767708] tegra-pcie-dw 14100000.pcie: PCI host bridge to bus 0001:00
[ 12.768732] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 12.769735] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 12.770873] pci_bus 0001:00: root bus resource [mem 0x30200000-0x31ffffff]
[ 12.771910] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x123fffffff pref]
[ 12.772972] pci 0001:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 12.773131] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[ 12.773360] iommu: Adding device 0001:00:00.0 to group 60
[ 12.774700] pci 0001:01:00.0: [1b4b:9171] type 00 class 0x010601
[ 12.774809] pci 0001:01:00.0: reg 0x10: [io 0x8000-0x8007]
[ 12.774884] pci 0001:01:00.0: reg 0x14: [io 0x8040-0x8043]
[ 12.774946] pci 0001:01:00.0: reg 0x18: [io 0x8100-0x8107]
[ 12.775007] pci 0001:01:00.0: reg 0x1c: [io 0x8140-0x8143]
[ 12.775068] pci 0001:01:00.0: reg 0x20: [io 0x800000-0x80000f]
[ 12.775129] pci 0001:01:00.0: reg 0x24: [mem 0x00900000-0x009001ff]
[ 12.775190] pci 0001:01:00.0: reg 0x30: [mem 0xd0000000-0xd000ffff pref]
[ 12.775522] pci 0001:01:00.0: PME# supported from D3hot
[ 12.775766] iommu: Adding device 0001:01:00.0 to group 61
[ 12.787125] pci 0001:00:00.0: BAR 14: assigned [mem 0x30200000-0x302fffff]
[ 12.788205] pci 0001:00:00.0: BAR 13: assigned [io 0x100000-0x100fff]
[ 12.789254] pci 0001:01:00.0: BAR 6: assigned [mem 0x30200000-0x3020ffff pref]
[ 12.790364] pci 0001:01:00.0: BAR 5: assigned [mem 0x30210000-0x302101ff]
[ 12.791492] pci 0001:01:00.0: BAR 4: assigned [io 0x100000-0x10000f]
[ 12.792646] pci 0001:01:00.0: BAR 0: assigned [io 0x100010-0x100017]
[ 12.793775] pci 0001:01:00.0: BAR 2: assigned [io 0x100018-0x10001f]
[ 12.794930] pci 0001:01:00.0: BAR 1: assigned [io 0x100020-0x100023]
[ 12.796053] pci 0001:01:00.0: BAR 3: assigned [io 0x100024-0x100027]
[ 12.797189] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 12.798237] pci 0001:00:00.0: bridge window [io 0x100000-0x100fff]
[ 12.800072] pci 0001:00:00.0: bridge window [mem 0x30200000-0x302fffff]
[ 12.806742] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 12.815569] pci 0001:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 12.824281] pcieport 0001:00:00.0: Signaling PME through PCIe PME interrupt
[ 12.830942] pci 0001:01:00.0: Signaling PME through PCIe PME interrupt
[ 12.837413] pcie_pme 0001:00:00.0:pcie001: service driver pcie_pme loaded
[ 12.837539] aer 0001:00:00.0:pcie002: service driver aer loaded
[ 12.837994] ahci 0001:01:00.0: version 3.0
[ 12.838575] ahci 0001:01:00.0: AHCI 0001.0000 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 12.845457] ahci 0001:01:00.0: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[ 12.854254] scsi host1: ahci
[ 12.856512] ata1: SATA max UDMA/133 abar m512@0x30210000 port 0x30210100 irq 560
[ 12.864113] tegra-pcie-dw 14140000.pcie: Setting init speed to max speed
[ 12.871534] OF: PCI: host bridge /pcie@14140000 ranges:
[ 12.875948] OF: PCI: IO 0x34100000…0x341fffff -> 0x34100000
[ 12.881701] OF: PCI: MEM 0x34200000…0x35ffffff -> 0x34200000
[ 12.887824] OF: PCI: MEM 0x1280000000…0x12bfffffff -> 0x1280000000
[ 13.177762] ata1: SATA link down (SStatus 0 SControl 300)
[ 13.406922] tegra-pcie-dw 14140000.pcie: link is down
[ 13.408389] tegra-pcie-dw 14140000.pcie: PCI host bridge to bus 0003:00
[ 13.409605] pci_bus 0003:00: root bus resource [bus 00-ff]
[ 13.410820] pci_bus 0003:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[ 13.412097] pci_bus 0003:00: root bus resource [mem 0x34200000-0x35ffffff]
[ 13.413301] pci_bus 0003:00: root bus resource [mem 0x1280000000-0x12bfffffff pref]
[ 13.414548] pci 0003:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 13.414713] pci 0003:00:00.0: PME# supported from D0 D3hot D3cold
[ 13.414927] iommu: Adding device 0003:00:00.0 to group 62
[ 13.416373] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[ 13.417674] pci 0003:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 13.419207] pcieport 0003:00:00.0: Signaling PME through PCIe PME interrupt
[ 13.420449] pcie_pme 0003:00:00.0:pcie001: service driver pcie_pme loaded
[ 13.420570] aer 0003:00:00.0:pcie002: service driver aer loaded
[ 13.420766] pcie_pme 0003:00:00.0:pcie001: unloading service driver pcie_pme
[ 13.420813] aer 0003:00:00.0:pcie002: unloading service driver aer
[ 13.420882] pci_bus 0003:01: busn_res: [bus 01-ff] is released
[ 13.420973] iommu: Removing device 0003:00:00.0 from group 62
[ 13.422225] pci_bus 0003:00: busn_res: [bus 00-ff] is released
[ 13.422514] tegra-pcie-dw 14140000.pcie: PCIe link is not up…!
[ 13.424310] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 13.426708] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 13.427949] OF: PCI: IO 0x3a100000…0x3a1fffff -> 0x3a100000
[ 13.429222] OF: PCI: MEM 0x3a200000…0x3bffffff -> 0x3a200000
[ 13.430464] OF: PCI: MEM 0x1c00000000…0x1fffffffff -> 0x1c00000000
[ 13.942846] tegra-pcie-dw 141a0000.pcie: link is down
[ 13.944307] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 13.945543] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 13.946782] pci_bus 0005:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[ 13.948103] pci_bus 0005:00: root bus resource [mem 0x3a200000-0x3bffffff]
[ 13.949338] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1fffffffff pref]
[ 13.950668] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 13.950862] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 13.951072] iommu: Adding device 0005:00:00.0 to group 62
[ 13.952666] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 13.953916] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 13.955470] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 13.956724] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 13.956837] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 13.956979] pcie_pme 0005:00:00.0:pcie001: unloading service driver pcie_pme
[ 13.957043] aer 0005:00:00.0:pcie002: unloading service driver aer
[ 13.957141] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 13.957227] iommu: Removing device 0005:00:00.0 from group 62
[ 13.958514] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 13.958794] tegra-pcie-dw 141a0000.pcie: PCIe link is not up…!
[ 13.973220] tegra-cbb 14040000.cv-noc: noc_secure_irq = 95, noc_nonsecure_irq = 94>
[ 13.980058] tegra194-isp5 14800000.isp: initialized
[ 13.989624] tegra194-vi5 15c10000.vi: initialized
[ 13.996809] tegra194-vi5 15c10000.vi: subdev imx377 30-001a bound
[ 13.998070] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–4 bound
[ 13.999968] tegra194-vi5 15c10000.vi: subdev imx377 31-001a bound
[ 14.001196] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–3 bound
[ 14.003105] tegra194-vi5 15c10000.vi: subdev imx377 32-001a bound
[ 14.004329] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–2 bound
[ 14.006222] tegra194-vi5 15c10000.vi: subdev imx377 33-001a bound
[ 14.007521] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–1 bound
[ 14.011209] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 14.012563] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 14.012941] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 14.012943] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[ 14.015488] tegra-xusb 3610000.xhci: extcon 0: ffffffc3eafbb000 id
[ 14.016061] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 14.016085] tegra-xudc-new 3550000.xudc: device count: 1
[ 14.016178] tegra-xusb 3610000.xhci: Direct firmware load for tegra19x_xusb_firmware failed with error -2
[ 14.016180] tegra-xusb 3610000.xhci: Falling back to user helper
[ 14.017089] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 14.017094] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 14.017755] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 14.017963] tegra-xudc-new 3550000.xudc: entering ELPG
[ 14.018186] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 14.089777] tegradc 15210000.nvdisplay: DT parsed successfully
[ 14.091650] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 14.091993] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 14.092216] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 14.092387] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 14.092772] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 14.092838] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 14.093022] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (68)
[ 14.093024] tegra186-cam-r
