How to use Nav2 and Nvblox with realsense camera
I am using Isaac ROS 4.0 with a D455 camera on x86_64. I only have the RealSense camera available, and I want to use Nav2 with Nvblox to generate navigation path. Sorry, I am not familiar with these tools.
My Nvblox setup works correctly on its own. However, when I try to integrate Nav2, I modified the
/isaac_ros_nvblox/blob/main/nvblox_examples/nvblox_examples_bringup/launch/realsense_example.launch.py
by adding
    actions.append(
        lu.include(
            'nvblox_examples_bringup',
            'launch/navigation/nvblox_carter_navigation.launch.py',
            launch_arguments={
                'container_name': NVBLOX_CONTAINER_NAME,
                'mode': args.mode,
            condition=IfCondition(lu.is_true(args.navigation))))
and set ‘use_sim_time = False’ in nvblox_examples/nvblox_examples_bringup/launch/navigation/nvblox_carter_navigation.launch.py
Then run ros2 launch nvblox_examples_bringup realsense_example.launch.py
I set a navigation goal, but nothing is echoed, and no error messages appear.
log.txt (106.8 KB)
I think there have some issues with my current approach, but I am not sure how to fix them. Any guidance or suggestions would be greatly appreciated.
Thank you very much for your help!
Robert
And i have another try.
I modify the nvblox_examples/nvblox_examples_bringup/launch/navigation/nvblox_carter_navigation.launch.py
from typing import List
import isaac_ros_launch_utils.all_types as lut
import isaac_ros_launch_utils as lu
from nvblox_ros_python_utils.nvblox_launch_utils import NvbloxMode
from nvblox_ros_python_utils.nvblox_constants import NVBLOX_CONTAINER_NAME
from launch import LaunchDescription
from launch_ros.actions import Node
def add_nvblox_carter_navigation(args: lu.ArgumentContainer) -> List[lut.Action]:
    actions = []
    # Enabling nav2
    actions.append(
        lu.set_parameter(
            namespace='/local_costmap/local_costmap',
            parameter='plugins',
            value=['nvblox_layer', 'inflation_layer'],
    actions.append(
        lu.set_parameter(
            namespace='/global_costmap/global_costmap',
    # Nav2 parameter file
    nav_params_path = lu.get_path(
        'config/navigation/carter_nav2_new.yaml'
    actions.append(lut.SetParametersFromFile(str(nav_params_path)))
    actions.append(lut.SetParameter('use_sim_time', False))
    # Select nvblox map slice topic
    mode = NvbloxMode[args.mode]
    if mode is NvbloxMode.static:
        costmap_topic_name = '/nvblox_node/static_map_slice'
    elif mode in [NvbloxMode.dynamic, NvbloxMode.people_segmentation]:
        costmap_topic_name = '/nvblox_node/combined_map_slice'
    else:
        raise RuntimeError(f'Navigation mode {mode} not supported')
    actions.append(
        lu.set_parameter(
            parameter='nvblox_layer.nvblox_map_slice_topic',
            value=costmap_topic_name,
    actions.append(
        lu.set_parameter(
    # Nav2 nodes (NON-composable)
    actions.extend([
        Node(
            package='nav2_controller',
            executable='controller_server',
            name='controller_server',
            output='screen',
            parameters=[nav_params_path],
        Node(
            package='nav2_planner',
            executable='planner_server',
            name='planner_server',
            output='screen',
        Node(
            package='nav2_bt_navigator',
            executable='bt_navigator',
            name='bt_navigator',
            output='screen',
        Node(
                package='nav2_behaviors',
                executable='behavior_server',
                name='behavior_server',
                output='screen',
        Node(
            package='nav2_lifecycle_manager',
            executable='lifecycle_manager',
            name='lifecycle_manager_navigation',
            output='screen',
            parameters=[{
                'autostart': True,
                'node_names': [
                    'planner_server',
                    'bt_navigator',
                    'behavior_server',
    return actions
def generate_launch_description() -> LaunchDescription:
    args = lu.ArgumentContainer()
    args.add_arg('mode')
    args.add_arg('container_name', NVBLOX_CONTAINER_NAME)
    args.add_opaque_function(add_nvblox_carter_navigation)
    return LaunchDescription(args.get_launch_actions())
And yaml
# Behavior Tree Navigator
bt_navigator:
  ros__parameters:
    use_sim_time: False
    global_frame: map
    robot_base_frame: base_link
    odom_topic: /odom
    bt_loop_duration: 10
    default_server_timeout: 20
    navigators: ["navigate_to_pose", "navigate_through_poses"]
    navigate_to_pose:
      plugin: "nav2_bt_navigator::NavigateToPoseNavigator"
    navigate_through_poses:
      plugin: "nav2_bt_navigator::NavigateThroughPosesNavigator"
# Controller Server
controller_server:
  ros__parameters:
    use_sim_time: False
    controller_frequency: 20.0
    controller_plugins: ["FollowPath"]
    FollowPath:
      plugin: "nav2_mppi_controller::MPPIController"
      time_steps: 56
      model_dt: 0.05
      batch_size: 2000
      vx_std: 0.2
      wz_std: 0.4
      vx_max: 0.5
      vx_min: -0.35
      wz_max: 1.9
      iteration_count: 1
      prune_distance: 1.7
      transform_tolerance: 0.1
      critics: ["ObstaclesCritic", "GoalCritic", "PathAlignCritic", "PathFollowCritic"]
      ObstaclesCritic:
        enabled: true
        cost_power: 1
        repulsion_weight: 4.0
        critical_weight: 20.0
        consider_footprint: True
        collision_cost: 10000.0
        collision_margin_distance: 0.1
        near_goal_distance: 0.5
      GoalCritic:
        enabled: true
        cost_power: 1
        cost_weight: 5.0
      PathAlignCritic:
        enabled: true
        cost_power: 1
        cost_weight: 14.0
        max_path_occupancy_ratio: 0.05
        trajectory_point_step: 4
        threshold_to_consider: 0.5
        offset_from_furthest: 20
        use_path_orientations: false
      PathFollowCritic:
        enabled: true
        cost_power: 1
        cost_weight: 5.0
        offset_from_furthest: 5
        threshold_to_consider: 1.4
    progress_checker_plugins: ["progress_checker"]
    progress_checker:
      plugin: "nav2_controller::SimpleProgressChecker"
      required_movement_radius: 0.5
      movement_time_allowance: 10.0
    goal_checker_plugins: ["stopped"]
    stopped:
      plugin: "nav2_controller::StoppedGoalChecker"
      xy_goal_tolerance: 0.25
      yaw_goal_tolerance: 0.25
      trans_stopped_velocity: 0.1
      rot_stopped_velocity: 0.1
# Local Costmap (nvblox + camera)
local_costmap:
  local_costmap:
    ros__parameters:
      use_sim_time: False
      global_frame: odom
      rolling_window: true
      width: 6
      height: 6
      resolution: 0.05
      footprint: "[ [0.14, 0.25], [0.14, -0.25], [-0.607, -0.25], [-0.607, 0.25] ]"
      plugins: ['nvblox_layer', 'inflation_layer']
      nvblox_layer:
        plugin: "nvblox::nav2::NvbloxCostmapLayer"
        enabled: True
        nav2_costmap_global_frame: odom
        nvblox_map_slice_topic: "/nvblox_node/static_map_slice"
        convert_to_binary_costmap: True
      inflation_layer:
        plugin: "nav2_costmap_2d::InflationLayer"
        enabled: True
        cost_scaling_factor: 10.0
        inflation_radius: 0.8
      always_send_full_costmap: True
# Global Costmap (nvblox + static map)
global_costmap:
  global_costmap:
    ros__parameters:
      use_sim_time: False
      global_frame: map
      resolution: 0.05
      width: 60
      height: 60
      origin_x: -30.0
      origin_y: -30.0
      track_unknown_space: False
      nvblox_layer:
        enabled: True
        nav2_costmap_global_frame: map
        nvblox_map_slice_topic: "/nvblox_node/combined_map_slice"
      inflation_layer:
        enabled: True
behavior_server:
  ros__parameters:
    use_sim_time: False
    cycle_frequency: 10.0
    behavior_plugins: ["spin", "backup", "drive_on_heading", "wait"]
    spin:
      plugin: "nav2_behaviors::Spin"
    backup:
      plugin: "nav2_behaviors::BackUp"
    wait:
      plugin: "nav2_behaviors::Wait"
    drive_on_heading:
      plugin: "nav2_behaviors::DriveOnHeading"
    global_frame: odom
# Map Server
map_server:
  ros__parameters:
    use_sim_time: False
    yaml_filename: " "
# Planner Server
planner_server:
  ros__parameters:
    use_sim_time: False
    expected_planner_frequency: 1.0
    planner_plugins: ["GridBased"]
    GridBased:
      plugin: "nav2_smac_planner::SmacPlannerHybrid"
      downsample_costmap: false
      downsampling_factor: 1
      tolerance: 0.25
      allow_unknown: true
      max_iterations: 1000000
      max_on_approach_iterations: 1000
      max_planning_time: 5.0
      motion_model_for_search: "REEDS_SHEPP"
      analytic_expansion_ratio: 3.5
      analytic_expansion_max_length: 1.5
      minimum_turning_radius: 0.20
      reverse_penalty: 2.0
      change_penalty: 0.0
      non_straight_penalty: 1.2
      cost_penalty: 3.0
      retrospective_penalty: 0.015
      lookup_table_size: 20.0
      cache_obstacle_heuristic: false
      debug_visualizations: false
      use_quadratic_cost_penalty: False
      downsample_obstacle_heuristic: True
      allow_primitive_interpolation: False
      smooth_path: True
      smoother:
        w_smooth: 0.3
        w_data: 0.2
        tolerance: 1.0e-10
        do_refinement: true
        refinement_num: 2
# Smoother Server
smoother_server:
  ros__parameters:
    use_sim_time: False
    smoother_plugins: ["simple_smoother"]
    simple_smoother:
      plugin: "nav2_smoother::SimpleSmoother"
      tolerance: 1.0e-10
      max_its: 1000
      do_refinement: True
And run
ros2 launch nvblox_examples_bringup nvblox_carter_navigation.launch.py mode:=static
I get the path, but the costmap does not publish , but the path does not consider obstacles
