Is there any sample code available to use the nveglstreamsrc(gstremer) in python?
Thanks & Regards,
Bala
Thanks & Regards,
Bala
Please share your use-case and we can suggest next. The plugin is not maintained and there may be potential issues. We would suggest not to use the plugin.
Our use case is to process the camera frames in GPU(shader) memory.
For the use-case, you can use NvBufSurface APIs to access the buffer on GPU. Please check HandleEGLImage() in the jetson_multiemdia_api samples. The samples are in
/usr/src/jetson_multimedia_api/
