How to use opengl3.3 with CUDA using OpenGL Interoperability
I want to render a mesh whose vertices and surfaces are populated and constantly updated inside the GPU.
For simple rendering using opengl3.3 alone, I have brought out the data from the GPU to CPU and did the following steps:
//Initialisation and opengl version setup
bool initOpenGL() {
// init glfw and glew
// setup callback functions for handling keyboard and mouse
// create window and setup viewport
if(all_ok)
return true;
else
return false;
Here is the main():
int main(){
if (!initOpenGL())
// An error occured
std::cerr << “initialization failed” << std::endl;
return -1;
// load and compile shader logic
ShaderProgram myShader;
myShader.loadShaders("shaders/shader_name.vert", "shaders/shader_name.frag");
//Load Mesh
Mesh myMesh;
For simple demo here, I am loading wavefront file but in the problem the vertices and the surfaces changes continuously, that means the vbos and vaos would be changing in the game loop .
myMesh.loadOBJ("models/some_mesh.obj");
//load texture for texturing the wavefront object (again for demonstration purpose)
Texture2D myTexture;
texture.loadTexture("textures/some_image.png", true);
/* Setup light pos and other stuff like model  world position */
while (!glfwWindowShouldClose(gWindow)){
    //Setup model, view, projection matrices
    //setup uniforms in shaders like:
    myShader.use();
    myShader.setUniform("model", glm::mat4(1.0));
    myShader.setUniform("view", view);
    myShader.setUniform("projection", projection);
    myShader.setUniform("viewPos", viewPos);
    // DRAW mesh
    myTexture.bind(0);
    myMesh.draw(); // Renders the OBJ mesh
    myTexture.unbind(0);
The loadOBJ() which is used to populate an array containing the surface info of the mesh by parsing the wavefront .obj file:
bool Mesh::loadOBJ(const std::string &filename){
//parse obj file
// iterate over each face to construct one flat array *mVertices* containing the position, normal and texCoord info like:
mVertices = [[vec3(x,y,z), vec3(nx,ny,nx), vec2(tx,ty)], [...], [...], ...]
/* mVertices is an array of 'Vertex'. where :
    struct Vertex{
    glm::vec3 position;
    glm::vec3 normal;
    glm::vec2 texCoords;
//initialize VBOs and VAOs
glGenVertexArrays(1, &mVAO);
glGenBuffers(1, &mVBO);
glBindVertexArray(mVAO);
glBindBuffer(GL_ARRAY_BUFFER, mVBO);
glBufferData(GL_ARRAY_BUFFER, mVertices.size() * sizeof(Vertex), &mVertices[0], GL_STATIC_DRAW);
// Vertex Positions
glVertexAttribPointer(0, 3, GL_FLOAT, GL_FALSE, sizeof(Vertex), (GLvoid *)0);
glEnableVertexAttribArray(0);
// Normals attribute
glVertexAttribPointer(1, 3, GL_FLOAT, GL_FALSE, sizeof(Vertex), (GLvoid *)(3 * sizeof(GLfloat)));
glEnableVertexAttribArray(1);
// Vertex Texture Coords
glVertexAttribPointer(2, 2, GL_FLOAT, GL_FALSE, sizeof(Vertex), (GLvoid *)(6 * sizeof(GLfloat)));
glEnableVertexAttribArray(2);
// unbind to make sure other code does not change it somewhere else
glBindVertexArray(0);
Here is the draw() which is called in each game loop
glDrawArrays(GL_TRIANGLES, 0, mVertices.size());
For loading the texture :
bool Texture2D::loadTexture(const string &fileName, bool generateMipMaps)
int width, height, components;
// Use stbi image library to load our image
unsigned char *imageData = stbi_load(fileName.c_str(), &width, &height, &components, STBI_rgb_alpha);
if (imageData == NULL)
    std::cerr << "Error loading texture '" << fileName << "'" << std::endl;
    return false;
// Invert image
int widthInBytes = width * 4;
unsigned char *top = NULL;
unsigned char *bottom = NULL;
unsigned char temp = 0;
int halfHeight = height / 2;
for (int row = 0; row < halfHeight; row++)
    top = imageData + row * widthInBytes;
    bottom = imageData + (height - row - 1) * widthInBytes;
    for (int col = 0; col < widthInBytes; col++)
        temp = *top;
        *top = *bottom;
        *bottom = temp;
        top++;
        bottom++;
glGenTextures(1, &mTexture);
glBindTexture(GL_TEXTURE_2D, mTexture);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_REPEAT);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_REPEAT);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_LINEAR);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA, width, height, 0, GL_RGBA, GL_UNSIGNED_BYTE, imageData);
if (generateMipMaps)
    glGenerateMipmap(GL_TEXTURE_2D);
stbi_image_free(imageData);
glBindTexture(GL_TEXTURE_2D, 0); // unbind texture when done so we don't accidentally mess up our mTexture
return true;
and for binding texture I use
glActiveTexture(GL_TEXTURE0 + texUnit);
I have demonstrated the question using parsing of a wavefront file , but since the mesh is constantly changing, I populate the mVertices in each game loop with correct coordinates and normals. But the approach is wrong since I am bringing GPUs data back to CPU and then rendering.
How to use OpenGL Interoperability in this case.
