First of all anyone who knows how to solve this please email-me
Im trying to convert a VBOs code, that works on the CPU perfectly. In this version I don’t use vertex mapping but I also have that version.
This only works for the vertex and colors data in CUDA.
The cuda and CPU code follows.
Sugestions why it doens’t work (and improvements to the cuda and CPU always welcomed)?
static GLsizeiptr WorldPositionSize = 4 * 2 * sizeof(GLfloat);
static GLfloat WorldPositionData[] =
0.0f, 0.0f,
0.0f, 1.0f,
1.0f, 1.0f,
1.0f, 0.0f
static GLsizeiptr WorldTexcoordsSize = 4 * 2 * sizeof(GLfloat);
static GLfloat WorldTexcoordsData[] =
1.0f, 1.0f,
1.0f, 0.0f,
0.0f, 0.0f,
0.0f, 1.0f
static GLsizeiptr WorldColorSize = 4 * 4 * sizeof(GLfloat);
static GLfloat WorldColorData[] =
1.0f, 1.0f, 1.0f, 1.0f,
static const GLsizei WorldVertexCount = 4;
static const int BufferSize = 3;
static GLuint Buffer[3];
enum
POSITION_OBJECT = 0,
COLOR_OBJECT = 1,
TEXCOORD_OBJECT = 2
void draw_world(void) {
glPushMatrix();
glBindTexture(GL_TEXTURE_2D, world_texture); //bind our texture to our shape
_draw_vbo(WorldPositionSize, WorldColorSize, WorldTexcoordsSize,
WorldPositionData, WorldColorData , WorldTexcoordsData, WorldVertexCount, GL_QUADS);
glPopMatrix();
void _draw_vbo(GLsizeiptr PositionSize, GLsizeiptr ColorSize, GLsizeiptr TexcoordSize,
GLfloat* PositionData, GLfloat* ColorData , GLfloat* TexcoordData,
GLsizei VertexCount, GLenum DrawPrimitive) {
// bind VBO in order to use
glBindBuffer(GL_ARRAY_BUFFER, Buffer);
// upload data to VBO
glBufferData(GL_ARRAY_BUFFER, ColorSize, ColorData, GL_STREAM_DRAW);
glColorPointer(4, GL_FLOAT, 0, 0);
glBindBuffer(GL_ARRAY_BUFFER, Buffer[POSITION_OBJECT]);
glBufferData(GL_ARRAY_BUFFER, PositionSize, PositionData, GL_STREAM_DRAW);
glVertexPointer(2, GL_FLOAT, 0, 0);
glBindBuffer(GL_ARRAY_BUFFER, Buffer[TEXCOORD_OBJECT]);
glBufferData(GL_ARRAY_BUFFER, TexcoordSize, TexcoordData, GL_STREAM_DRAW);
glTexCoordPointer(2, GL_FLOAT, 0, 0);
glEnableClientState(GL_VERTEX_ARRAY);
glEnableClientState(GL_COLOR_ARRAY);
glEnableClientState(GL_TEXTURE_COORD_ARRAY);
glDrawArrays(DrawPrimitive, 0, VertexCount);
glDisableClientState(GL_TEXTURE_COORD_ARRAY);
glDisableClientState(GL_COLOR_ARRAY);
glDisableClientState(GL_VERTEX_ARRAY);
int load_texture(const char *filename, int width, int height)
GLuint texture;
unsigned char *data;
FILE * file;
//The following code will read in our RAW file
fopen_s(&file, filename, "rb");
if(file == NULL )
return 0;
data =(unsigned char *)malloc(width * height * 3);
fread(data, width * height * 3, 1, file);
fclose(file);
glGenTextures(1, &texture); //generate the texture with the loaded data
glBindTexture(GL_TEXTURE_2D, texture); //bind the texture to it's array
glTexEnvf(GL_TEXTURE_ENV, GL_TEXTURE_ENV_MODE, GL_MODULATE); //set texture environment parameters
// when texture area is small, bilinear filter the closest mipmap
glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_LINEAR_MIPMAP_NEAREST);
// when texture area is large, bilinear filter the first mipmap
glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
//the texture wraps over at the edges(repeat)
glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_REPEAT);
glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_REPEAT);
// build our texture mipmaps
gluBuild2DMipmaps(GL_TEXTURE_2D, 3, width, height, GL_RGB, GL_UNSIGNED_BYTE, data);
free(data); //free the texture
return texture; //return whether it was successfull
//free a given texture
void free_texture(GLuint texture )
glDeleteTextures(1, &texture);
extern "C" void _draw_world(_GRID *g) {
unsigned int worldVertexCount = 4;
unsigned int worldColorSize = worldVertexCount * sizeof(float4);
unsigned int worldPositionSize = worldVertexCount * sizeof(float4);
glBufferData(GL_ARRAY_BUFFER, worldPositionSize, 0, GL_STREAM_DRAW);
glBindBuffer(GL_ARRAY_BUFFER, 0);
// register buffer object with CUDA
CUDA_SAFE_CALL(cudaGLRegisterBufferObject(Buffer[POSITION_OBJECT]));
CUT_CHECK_ERROR("cudaGLRegisterBufferObject execution failed");
// bind VBO data to set up
glBufferData(GL_ARRAY_BUFFER, worldColorSize, 0, GL_STREAM_DRAW);
CUDA_SAFE_CALL(cudaGLRegisterBufferObject(Buffer));
CUDA_SAFE_CALL(cudaGLRegisterBufferObject(Buffer[TEXCOORD_OBJECT]));
// map OpenGL buffer object for writing from CUDA
CUDA_SAFE_CALL(cudaGLMapBufferObject((void**)&vbo_pos, Buffer[POSITION_OBJECT]));
CUT_CHECK_ERROR("cudaGLMapBufferObject execution failed");
CUDA_SAFE_CALL(cudaGLMapBufferObject((void**)&vbo_clr, Buffer));
CUDA_SAFE_CALL(cudaGLMapBufferObject((void**)&vbo_tex, Buffer[TEXCOORD_OBJECT]));
clr = make_float4(1.0f, 1.0f, 1.0f, 1.0f);
_set_world_vbo_data<<<1, 4>>>(vbo_pos, vbo_clr, vbo_pos, clr);
// check if kernel execution generated an error
CUT_CHECK_ERROR("Kernel _set_world_vbo_data execution failed");
// unmap buffer object
CUDA_SAFE_CALL(cudaGLUnmapBufferObject(Buffer[POSITION_OBJECT]));
CUT_CHECK_ERROR("cudaGLUnmapBufferObject execution failed");
CUDA_SAFE_CALL(cudaGLUnmapBufferObject(Buffer));
CUDA_SAFE_CALL(cudaGLUnmapBufferObject(Buffer[TEXCOORD_OBJECT]));
// bind to VBO position pointer
glVertexPointer(4, GL_FLOAT, 0, 0);
// bind to VBO color pointer
// bind to VBO texcoord pointer
glTexCoordPointer(4, GL_FLOAT, 0, 0);
// register/map/and set pointers on vbo data
//_set_vbo_CUDA(g, worldPositionSize, worldColorSize, worldPositionSize, 0, 0, 1.0f);
// draw vbos
glPushMatrix();
glEnable(GL_TEXTURE_2D); //enable texturing
_draw_vbo(GL_QUADS, worldVertexCount);
glDisable(GL_TEXTURE_2D);
glPopMatrix();
// unregister vbos in cuda
_unregister_vbo_CUDA();
extern "C" void _unregister_vbo_CUDA(void)
// unregister buffer object with CUDA
CUDA_SAFE_CALL(cudaGLUnregisterBufferObject(Buffer[POSITION_OBJECT]));
CUT_CHECK_ERROR("cudaGLUnregisterBufferObject execution failed");
CUDA_SAFE_CALL(cudaGLUnregisterBufferObject(Buffer));
CUDA_SAFE_CALL(cudaGLUnregisterBufferObject(Buffer[TEXCOORD_OBJECT]));
extern "C" void _draw_vbo(GLenum DrawPrimitive, GLsizei VertexCount)
GLuint texture;
FILE * file;
if(file == NULL )
return 0;
fclose(file);
