I’ve downloaded the sdk file and found that there was a folder called Lib. However, the .so file in Lib is built for x86_64. Now, I want to use the sdk in Tx2. So I have to build the .so file from scratch. I want to know where the source files are ?
Thanks in advance.
Thanks for your reply. Very helpful !
I’ve tried the above method. I can use omxh264dec in GStreamer now. But the other way, multimedia API is a little bit complex. I’ve got another two questions about multimedia API.
I cannot use the sample in multimedia API to decode rtsp stream. The sample I use is “02_video_dec_cuda”. The version of L4T is 32.1. I notice that this api is based on V4L2. so I guess rtsp is not supported by the multimedia API, am I right ?
The effectiveness produced by multimedia API is higher than that by omxh264dec, am I right ? If I decode the same avi video file, multimedia API is faster, right ?
Regards,
- I suppose you should mux/demux RTSP container to raw H264/H265 (manually (follow RFC3550) or with library (like live555 or ffmpeg)) to use low level API.
- GStreamer is easier but sometimes unusable in some scenarios (usually due to latency with excessive buffering).
Ask again @ https://devtalk.nvidia.com/default/board/188/
