I can run this cmd in my xavier:
gst-launch-1.0 rtspsrc latency=150 location=rtsp://admin:admin@192.168.1.164:554/h265/ch1/sub/av_stream ! \
rtph265depay ! h265parse ! omxh265dec ! nvoverlaysink
I’m a beginner to both deepstream and gstreamer, so the cmd above is copied from somewhere but it worked ( a video window will open and display the images)
Then I’d like to check if GPU is used and I use
tegrastats
and I get this:
RAM 4246/31919MB (lfb 5364x4MB) SWAP 0/15960MB (cached 0MB) CPU [0%@1190,0%@1190,1%@1190,1%@1190,7%@1190,7%@1190,0%@1190,2%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@45.5C GPU@46C Tdiode@47.25C PMIC@100C AUX@46C CPU@46C thermal@46C Tboard@45C
RAM 4246/31919MB (lfb 5364x4MB) SWAP 0/15960MB (cached 0MB) CPU [2%@1190,0%@1190,0%@1190,0%@1190,5%@1190,7%@1190,1%@1190,0%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@45.5C GPU@46C Tdiode@47C PMIC@100C AUX@46C CPU@46C thermal@46.2C Tboard@45C
RAM 4246/31919MB (lfb 5364x4MB) SWAP 0/15960MB (cached 0MB) CPU [2%@1190,0%@1190,1%@1190,0%@1190,5%@1190,1%@1190,0%@1190,2%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@45.5C GPU@46C Tdiode@47.25C PMIC@100C AUX@46.5C CPU@46C thermal@46.35C Tboard@45C
RAM 4246/31919MB (lfb 5364x4MB) SWAP 0/15960MB (cached 0MB) CPU [0%@1190,0%@1190,0%@1190,0%@1190,2%@1190,3%@1190,0%@1190,0%@1190] EMC_FREQ 0% GR3D_FREQ 0% AO@45.5C GPU@46.5C Tdiode@47.25C PMIC@100C AUX@46.5C CPU@46.5C thermal@46.35C Tboard@45C
the GR3D_FREQ 0% is always 0, which I don’t understand.
Then I use
htop
to check the cpu load, it’s about 3%, which seems to be lower than my c++ code of using something like cv::VideoCapture().
Here is my question: In my case, how can I verify the GPU is working to reduce CPU load?
