Dear All,
I am using Microsoft Visual Studio 2015 for creating C++ extensions for Python. Normally, when my extension in C++ does not contain CUDA codes, then I create a setup.py files like the one below (taken from microsoft website [url]Write C++ extensions for Python - Visual Studio (Windows) | Microsoft Docs):
from distutils.core import setup, Extension, DEBUG
sfc_module = Extension(‘superfastcode’, sources = [‘module.cpp’])
setup(name = ‘superfastcode’, version = ‘1.0’,
description = ‘Python Package with superfastcode C++ extension’,
ext_modules = [sfc_module]
I run this code from console with the command: pip install .
Now I want to know what modifications are needed if the C++ extension also has CUDA files. I have already included CUDA in the build dependencies of the project . But using simply the code above gives the following error: Cannot open include file: ‘cuda.h’: No such file or directory error: command ‘C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\BIN\x86_amd64\cl.exe’ failed with exit status 2
I would greatly appreciate any help from the group on this matter.
Thank you.
Best,
Sanat
