I have an HP Victus 15 Laptop running with Ubuntu 20.04.6 on dual boot. Laptop has RTX 4050 and AMD iGPU. I have installed nvidia-driver nvidia-driver-560
using sudo ubuntu-drivers autoinstall
. I also did sudo apt update
and sudo apt upgrade
before installing. Once I reboot, the login screen is not displaying. I had to open a terminal and run the bug report. I have also checked that secure boot is disabled.
nvidia-bug-report.log.gz (341.5 KB)
When I run lshw -c display
lshw -c display
WARNING: you should run this program as super-user.
*-display
description: VGA compatible controller
product: NVIDIA Corporation
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: iomemory:7c0-7bf iomemory:7e0-7df irq:79 memory:fb000000-fbffffff memory:7c00000000-7dffffffff memory:7e00000000-7e01ffffff ioport:f000(size=128) memory:fc000000-fc07ffff
*-display UNCLAIMED
product: Advanced Micro Devices, Inc. [AMD/ATI]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:06:00.0
version: c6
width: 64 bits
clock: 33MHz
configuration: latency=0
resources: iomemory:7e0-7df memory:7e10000000-7e1fffffff memory:fc200000-fc3fffff ioport:c000(size=256) memory:fc700000-fc77ffff
nvidia-smi
shows that the driver was correctly installed, but it is not running an Xorg session.
| NVIDIA-SMI 560.35.03 Driver Version: 560.35.03 CUDA Version: 12.6 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4050 ... Off | 00000000:01:00.0 Off | N/A |
| N/A 45C P3 11W / 60W | 2MiB / 6141MiB | 6% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
