Hi Nvidia,
I am currently testing UEFI HTTP Boot on Orin NX.
Previously, I followed this guide, and was able to successfully boot the system via PXE Boot.
However, HTTP Boot is currently failing.
I can start grub> via HTTP Boot, but there are no further actions after that.
Since most of the forum discussions about HTTP Boot focus on boot order,
I would like to ask if there are any reference links or documents specifically about HTTP Boot?
Hi Wilson_Lin,
Are you using the devkit or custom board for Orin NX?
It seems we don’t have detailed document about the steps to setup HTTP boot.
I think the most configurations should be done from your host rather than Jetson device.
Have you also referred to Flashing for NFS as Root for the rootfs?
Hi @KevinFFF ,
Thanks reply.
I’m used the custom board that base on xavier carrier board.
I used the NFS for the rootfs.
The http boot is worked now. But the https boot is failed.
Does Jetson Orin UEFI support https boot?
Update the Info.
I have add cert file in Tls Auth Configuration. But I can’t download NBP file (grub efi file) for https URL.
But I can download grub file by curl command.
$ curl --cacert apache.crt https://192.168.0.214/jetson-boot/grubnetaa64.efi -O
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 1497k 100 1497k 0 0 118M 0 --:--:-- --:--:-- --:--:-- 121M
Sorry that we don’t verify this use case so that I can give you limited support for this use case. It seems https boot should have additional configuration from server like SSL/TLS certificate.
For Jetson device, maybe you can configure them from UEFI menu.
(i.e. ESC → Device Manager → Secure Boot Configuration → Secure Boot Mode: Cutom Mode) You might need to configure Custom Secure Boot Options → DB Options with the CA certificate for https boot.
Are you trying to enable Grub?
Did not you have to make usb connection between jetson & host ?
Hi @wolfcoder90 ,
Why did https boot need to connect usb between jetson & host?
Hi Kevin,
I check my CA cert again, it’s wrong.
Now the https boot pass.
Thanks a lot.
