AGX Xavier
• DeepStream Version
6.0
4.6
• TensorRT Version
8.0.1.6
The hardware decoder creates segments with no PPS.
Follwing settings are provides
g_object_set (G_OBJECT (bin->encoder), “profile”, profile, NULL); [THIS IS 0]
g_object_set (G_OBJECT (bin->encoder), “iframeinterval”, config->iframeinterval, NULL); [THIS IS 4]
g_object_set (G_OBJECT (bin->encoder), “bitrate”, bitrate, NULL); [This is 2000000]
g_object_set (G_OBJECT (bin->encoder), “force-idr”, 1, NULL);
ffmpeg -i outxxx.ts will give follwoing error:
[h264 @ 0x558b9d0b90] non-existing PPS 0 referenced
Last message repeated 1 times
[h264 @ 0x558b9d0b90] decode_slice_header error
[h264 @ 0x558b9d0b90] no frame!
I dont get this problem if I use SW encoder.
Is there a configuration to use HW encoder that works?
the fps of camera is 30. I set profile =0, idrinterval=5, force-idr is ON, Insert-sps-pps is on. iframeinterval is also 5. But I still get broken segments
