I will contact the vendor right away. Thank you for your help. I would never have figured this out on my own.
Related topics
| Refresh rates seemed to be capped at 40fps on laptop display, even after setting it to 165hz in settings | 13 | 2162 | May 5, 2021 | |
| Cant get 4K 120hz using NVIDIA GeForce RTX 4060 Ti on Ubuntu 25.04 | 6 | 474 | April 6, 2026 | |
| Cant change refresh rate on my laptop screen on Ubuntu | 1 | 2327 | August 11, 2025 | |
| Ubuntu can't set further 60hz refresh rate, RTX 3070ti-ubuntu 22.10 | 2 | 1917 | March 31, 2023 | |
| Highest refresh rate missing on lower resolutions | 4 | 2843 | August 19, 2021 | |
| Ubuntu with Nvidia drivers capped at 60 FPS on a 144hz screen (single monitor) - not capped with nouveau drivers | 5 | 10824 | July 2, 2021 | |
| Monitor Refresh Rate Ubuntu MATE 22 | 19 | 2820 | May 18, 2023 | |
| [BUG REPORT] Can't select highest refreshrate in NVIDIA Settings my monitor supports (240Hz) since 535 | 1 | 2514 | October 28, 2023 | |
| Laptop refresh rate won't set correctly, stuck at 40Hz when set to 165hz | 7 | 1808 | October 15, 2021 | |
| Ubuntu with Nvidia drivers capped at 60 FPS on a 144hz screen (dual monitor) | 8 | 5985 | December 23, 2022 |
