Cant set 120hz on Ubuntu 25.04. The option does not show in screen display settings.
Setup:
- Graphics card: NVIDIA GeForce RTX 4060 Ti
- Nvidia driver 580.95.05
- OS: Ubuntu 25.04
- Monitor: Dell U4025QW using Display Port
In previous NVIDIA driver, I was able to modify the refresh rate to 120HZ via Nvidia Settings but the screen would appear black and rollback the change.
AFAIK, the screen and graphics card both support this?
nvidia-bug-report.log (1.3 MB)
Hi, would you mind retesting with 580.119.02?
Installed 580.119.02. Attached new bug report.
NOTE: Cannot seem to force 120hz through UI or nvidia-settings.
nvidia-bug-report.log (2.1 MB)
@rrameshbabu any ideas on this one?
Sorry for replying so late. This somehow missed my inbox.
Block 0, Base EDID:
EDID Structure Version & Revision: 1.4
Vendor & Product Identification:
Manufacturer: DEL
Model: 17168
Serial Number: 808988748 (0x3038304c)
Made in: week 26 of 2024
Basic Display Parameters & Features:
Digital display
Bits per primary color channel: 10
DisplayPort interface
Maximum image size: 93 cm x 39 cm
Gamma: 2.20
DPMS levels: Off
Supported color formats: RGB 4:4:4, YCrCb 4:4:4, YCrCb 4:2:2
First detailed timing includes the native pixel format and preferred refresh rate
Display supports continuous frequencies
Color Characteristics:
Red : 0.6904, 0.3095
Green: 0.2402, 0.6923
Blue : 0.1425, 0.0566
White: 0.3134, 0.3291
Established Timings I & II:
IBM : 720x400 70.081663 Hz 9:5 31.467 kHz 28.320000 MHz
DMT 0x04: 640x480 59.940476 Hz 4:3 31.469 kHz 25.175000 MHz
DMT 0x06: 640x480 75.000000 Hz 4:3 37.500 kHz 31.500000 MHz
DMT 0x09: 800x600 60.316541 Hz 4:3 37.879 kHz 40.000000 MHz
DMT 0x0b: 800x600 75.000000 Hz 4:3 46.875 kHz 49.500000 MHz
DMT 0x10: 1024x768 60.003840 Hz 4:3 48.363 kHz 65.000000 MHz
DMT 0x12: 1024x768 75.028582 Hz 4:3 60.023 kHz 78.750000 MHz
DMT 0x24: 1280x1024 75.024675 Hz 5:4 79.976 kHz 135.000000 MHz
Standard Timings:
DMT 0x15: 1152x864 75.000000 Hz 4:3 67.500 kHz 108.000000 MHz
DMT 0x1c: 1280x800 59.810326 Hz 16:10 49.702 kHz 83.500000 MHz
DMT 0x23: 1280x1024 60.019740 Hz 5:4 63.981 kHz 108.000000 MHz
DMT 0x33: 1600x1200 60.000000 Hz 4:3 75.000 kHz 162.000000 MHz
DMT 0x3a: 1680x1050 59.954250 Hz 16:10 65.290 kHz 146.250000 MHz
DMT 0x52: 1920x1080 60.000000 Hz 16:9 67.500 kHz 148.500000 MHz
DMT 0x45: 1920x1200 59.884600 Hz 16:10 74.556 kHz 193.250000 MHz
DMT 0x54: 2048x1152 60.000000 Hz 16:9 72.000 kHz 162.000000 MHz (RB)
Detailed Timing Descriptors:
DTD 1: 2560x1080 60.001588 Hz 64:27 66.662 kHz 181.320000 MHz (929 mm x 392 mm)
Hfront 48 Hsync 32 Hback 80 Hpol P
Vfront 3 Vsync 10 Vback 18 Vpol N
Display Product Serial Number: '5SM5M04'
Display Product Name: 'DELL U4025QW'
Display Range Limits:
Monitor ranges (Range Limits Only): 48-120 Hz V, 280-280 kHz H, max dotclock 1500 MHz
Extension blocks: 2
Checksum: 0x2c
Block 1, CTA-861 Extension Block:
Revision: 3
Underscans IT Video Formats by default
Basic audio support
Supports YCbCr 4:4:4
Supports YCbCr 4:2:2
Native detailed modes: 1
Video Data Block:
VIC 193: 5120x2160 120.000000 Hz 64:27 270.000 kHz 1485.000000 MHz
VIC 126: 5120x2160 60.000000 Hz 64:27 135.000 kHz 742.500000 MHz
VIC 123: 5120x2160 30.000000 Hz 64:27 66.000 kHz 396.000000 MHz
VIC 102: 4096x2160 60.000000 Hz 256:135 135.000 kHz 594.000000 MHz
VIC 97: 3840x2160 60.000000 Hz 16:9 135.000 kHz 594.000000 MHz
VIC 96: 3840x2160 50.000000 Hz 16:9 112.500 kHz 594.000000 MHz
VIC 95: 3840x2160 30.000000 Hz 16:9 67.500 kHz 297.000000 MHz
VIC 94: 3840x2160 25.000000 Hz 16:9 56.250 kHz 297.000000 MHz
VIC 93: 3840x2160 24.000000 Hz 16:9 54.000 kHz 297.000000 MHz
VIC 16: 1920x1080 60.000000 Hz 16:9 67.500 kHz 148.500000 MHz
VIC 31: 1920x1080 50.000000 Hz 16:9 56.250 kHz 148.500000 MHz
VIC 4: 1280x720 60.000000 Hz 16:9 45.000 kHz 74.250000 MHz
VIC 19: 1280x720 50.000000 Hz 16:9 37.500 kHz 74.250000 MHz
VIC 18: 720x576 50.000000 Hz 16:9 31.250 kHz 27.000000 MHz
VIC 17: 720x576 50.000000 Hz 4:3 31.250 kHz 27.000000 MHz
VIC 3: 720x480 59.940060 Hz 16:9 31.469 kHz 27.000000 MHz
VIC 2: 720x480 59.940060 Hz 4:3 31.469 kHz 27.000000 MHz
VIC 1: 640x480 59.940476 Hz 4:3 31.469 kHz 25.175000 MHz
Audio Data Block:
Linear PCM:
Max channels: 2
Supported sample rates (kHz): 48 44.1 32
Supported sample sizes (bits): 24 20 16
Speaker Allocation Data Block:
FL/FR - Front Left/Right
DTD 2: 3840x2160 60.000000 Hz 16:9 133.320 kHz 533.280000 MHz (929 mm x 392 mm)
Vfront 3 Vsync 5 Vback 54 Vpol N
DTD 3: 2560x1440 59.950550 Hz 16:9 88.787 kHz 241.500000 MHz (929 mm x 392 mm)
Vfront 3 Vsync 5 Vback 33 Vpol N
Checksum: 0x94 Unused space in Extension Block: 60 bytes
Block 2, DisplayID Extension Block:
Version: 1.2
Extension Count: 0
Display Product Type: Standalone display device
Display Parameters Data Block (0x01):
Image size: 929.3 mm x 392.0 mm
Display native pixel format: 5120x2160
Feature support flags:
Power management (DPM)
Gamma: 2.20
Aspect ratio: 2.37
Dynamic bpc native: 10
Dynamic bpc overall: 10
Video Timing Modes Type 1 - Detailed Timings Data Block:
DTD: 5120x2160 60.000034 Hz 64:27 133.320 kHz 703.930000 MHz (aspect 64:27, no 3D stereo, preferred)
Vfront 3 Vsync 10 Vback 49 Vpol N
DTD: 5120x2160 120.000000 Hz 64:27 270.000 kHz 1485.000000 MHz (aspect 64:27, no 3D stereo)
Hfront 164 Hsync 88 Hback 128 Hpol P
Vfront 8 Vsync 10 Vback 72 Vpol P
DTD: 5120x2160 30.000484 Hz 64:27 65.731 kHz 347.060000 MHz (aspect 64:27, no 3D stereo)
Checksum: 0x4c
Checksum: 0x90
The above is the decoded EDID from the logs. I do not see a 4k 120Hz mode but I do see a 5k 120Hz mode.
It also looks like nouveau is not blacklisted and the X11 nouveau driver is driving your display, rather than the NVIDIA driver.
[ 32.561] (II) NOUVEAU driver Date: Sat Jan 23 12:24:42 2021 -0500
[ 32.561] (II) NOUVEAU driver for NVIDIA chipset families :
[ 32.561] RIVA TNT (NV04)
[ 32.561] RIVA TNT2 (NV05)
[ 32.561] GeForce 256 (NV10)
[ 32.561] GeForce 2 (NV11, NV15)
[ 32.561] GeForce 4MX (NV17, NV18)
[ 32.561] GeForce 3 (NV20)
[ 32.561] GeForce 4Ti (NV25, NV28)
[ 32.561] GeForce FX (NV3x)
[ 32.561] GeForce 6 (NV4x)
[ 32.561] GeForce 7 (G7x)
[ 32.561] GeForce 8 (G8x)
[ 32.561] GeForce 9 (G9x)
[ 32.561] GeForce GTX 2xx/3xx (GT2xx)
[ 32.561] GeForce GTX 4xx/5xx (GFxxx)
[ 32.561] GeForce GTX 6xx/7xx (GKxxx)
[ 32.562] GeForce GTX 9xx (GMxxx)
[ 32.562] GeForce GTX 10xx (GPxxx)
You will need to blacklist the nouveau kernel module from loading for the NVIDIA GPU to behave correctly. This log capture may not be accurate though/maybe taken in a bad state. What desktop environment are you using and is it X11 or Wayland based? Thanks in advance.
Thanks @rrameshbabu, disabling the nouveau driver fixed the issue. Can now run 5K @120Hz.
Ah, so it was the nouveau driver. I edited my answer because the logs were quite messy for me to confirm.
