I have an issue setting up multiple monitors on my machine, running RTX 4060 TI. My configuration is the following:
OS: Ubuntu 22.04.4 LTS x86_64 (running XFCE X-server)
CPU: 12th Gen Intel i7-12700F (20) @ 4.800GHz
RAM: 32GB
GPU: RTX 4060 TI (nvidia-driver-550)
I have 3 1440p monitors connected with DisplayPort cables.with default refresh rate of 76 Hz each.
If I connect 1 of the displays and if I am using the default Ubuntu provided nouveau driver → I can get 75Hz on a single monitor, but it doesn’t recognize my other 2 monitors.
If I switch to the driver above (nvidia-driver 550.54.14) - I can connect all 3 monitors, but I can’t select anything above 59HZ in my Display settings nor from the Nvidia Settings app.
The difference is noticeable and I would really like to get this fixed. Any advice is welcome.
All the best,
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
I cannot seem to upload the file. The Web UI gets stuck at Processing Upload for 30 minutes even though the file is 244KB. Is there any specific information I can paste here as text or some other way of uploading the file :( ?
Please try to unzip and upload.
nvidia-bug-report.log (3.8 MB)
Yes, it worked ! Please find attached
The decoded EDID tells this monitor is only capable of 1440p@60Hz, 75Hz only possible on resolutions 1280x1024 and lower. I don’t know how you’ve been able to overdrive the monitor with nouveau.
Block 0, Base EDID:
EDID Structure Version & Revision: 1.4
Vendor & Product Identification:
Manufacturer: BNQ
Model: 32795
Serial Number: 21573
Made in: week 33 of 2022
Basic Display Parameters & Features:
Digital display
Bits per primary color channel: 8
DisplayPort interface
Maximum image size: 53 cm x 30 cm
Gamma: 2.20
DPMS levels: Off
Supported color formats: RGB 4:4:4, YCrCb 4:4:4, YCrCb 4:2:2
First detailed timing includes the native pixel format and preferred refresh rate
Color Characteristics:
Red : 0.6601, 0.3320
Green: 0.2998, 0.6289
Blue : 0.1474, 0.0517
White: 0.3134, 0.3291
Established Timings I & II:
IBM : 720x400 70.081663 Hz 9:5 31.467 kHz 28.320000 MHz
DMT 0x04: 640x480 59.940476 Hz 4:3 31.469 kHz 25.175000 MHz
DMT 0x06: 640x480 75.000000 Hz 4:3 37.500 kHz 31.500000 MHz
DMT 0x09: 800x600 60.316541 Hz 4:3 37.879 kHz 40.000000 MHz
DMT 0x0b: 800x600 75.000000 Hz 4:3 46.875 kHz 49.500000 MHz
Apple : 832x624 74.551266 Hz 4:3 49.726 kHz 57.284000 MHz
DMT 0x10: 1024x768 60.003840 Hz 4:3 48.363 kHz 65.000000 MHz
DMT 0x12: 1024x768 75.028582 Hz 4:3 60.023 kHz 78.750000 MHz
DMT 0x24: 1280x1024 75.024675 Hz 5:4 79.976 kHz 135.000000 MHz
Apple : 1152x870 75.061550 Hz 192:145 68.681 kHz 100.000000 MHz
Standard Timings:
DMT 0x52: 1920x1080 60.000000 Hz 16:9 67.500 kHz 148.500000 MHz
DMT 0x3a: 1680x1050 59.954250 Hz 16:10 65.290 kHz 146.250000 MHz
DMT 0x53: 1600x900 60.000000 Hz 16:9 60.000 kHz 108.000000 MHz (RB)
DMT 0x23: 1280x1024 60.019740 Hz 5:4 63.981 kHz 108.000000 MHz
DMT 0x1c: 1280x800 59.810326 Hz 16:10 49.702 kHz 83.500000 MHz
DMT 0x55: 1280x720 60.000000 Hz 16:9 45.000 kHz 74.250000 MHz
Detailed Timing Descriptors:
DTD 1: 2560x1440 59.950550 Hz 16:9 88.787 kHz 241.500000 MHz (527 mm x 296 mm)
Hfront 48 Hsync 32 Hback 80 Hpol P
Vfront 3 Vsync 5 Vback 33 Vpol N
Display Product Serial Number: 'L8N01392019'
Display Range Limits:
Monitor ranges (CVT): 50-76 Hz V, 30-89 kHz H, max dotclock 270 MHz
CVT version 1.1
Max active pixels per line: 1920
Supported aspect ratios: 4:3 16:9 16:10 5:4 15:9
Preferred aspect ratio: 16:9
Supports CVT standard blanking
Supports CVT reduced blanking
Supported display scaling:
Horizontal shrink
Horizontal stretch
Vertical shrink
Vertical stretch
Preferred vertical refresh: 60 Hz
Display Product Name: 'BenQ LCD'
Extension blocks: 1
Checksum: 0x7c
Block 1, CTA-861 Extension Block:
Revision: 3
Basic audio support
Supports YCbCr 4:4:4
Supports YCbCr 4:2:2
Native detailed modes: 1
Video Data Block:
VIC 16: 1920x1080 60.000000 Hz 16:9 67.500 kHz 148.500000 MHz (native)
VIC 31: 1920x1080 50.000000 Hz 16:9 56.250 kHz 148.500000 MHz
VIC 5: 1920x1080i 60.000000 Hz 16:9 33.750 kHz 74.250000 MHz
VIC 20: 1920x1080i 50.000000 Hz 16:9 28.125 kHz 74.250000 MHz
VIC 4: 1280x720 60.000000 Hz 16:9 45.000 kHz 74.250000 MHz
VIC 19: 1280x720 50.000000 Hz 16:9 37.500 kHz 74.250000 MHz
VIC 3: 720x480 59.940060 Hz 16:9 31.469 kHz 27.000000 MHz
VIC 18: 720x576 50.000000 Hz 16:9 31.250 kHz 27.000000 MHz
VIC 2: 720x480 59.940060 Hz 4:3 31.469 kHz 27.000000 MHz
VIC 17: 720x576 50.000000 Hz 4:3 31.250 kHz 27.000000 MHz
VIC 1: 640x480 59.940476 Hz 4:3 31.469 kHz 25.175000 MHz
VIC 7: 1440x480i 59.940060 Hz 16:9 15.734 kHz 27.000000 MHz
VIC 22: 1440x576i 50.000000 Hz 16:9 15.625 kHz 27.000000 MHz
VIC 21: 1440x576i 50.000000 Hz 4:3 15.625 kHz 27.000000 MHz
VIC 6: 1440x480i 59.940060 Hz 4:3 15.734 kHz 27.000000 MHz
Audio Data Block:
Linear PCM:
Max channels: 2
Supported sample rates (kHz): 96 48 44.1 32
Supported sample sizes (bits): 24 20 16
Speaker Allocation Data Block:
FL/FR - Front Left/Right
Vendor-Specific Data Block (ASUS), OUI 00-0C-6E:
10 00 '..'
DTD 2: 720x480 59.940060 Hz 3:2 31.469 kHz 27.000000 MHz (527 mm x 296 mm)
Hfront 16 Hsync 62 Hback 60 Hpol N
Vfront 9 Vsync 6 Vback 30 Vpol N
DTD 3: 1280x720 60.000000 Hz 16:9 45.000 kHz 74.250000 MHz (527 mm x 296 mm)
Hfront 110 Hsync 40 Hback 220 Hpol P
Vfront 5 Vsync 5 Vback 20 Vpol P
DTD 4: 1280x720 50.000000 Hz 16:9 37.500 kHz 74.250000 MHz (527 mm x 296 mm)
Hfront 440 Hsync 40 Hback 220 Hpol P
DTD 5: 720x576 50.000000 Hz 5:4 31.250 kHz 27.000000 MHz (527 mm x 296 mm)
Hfront 12 Hsync 64 Hback 68 Hpol N
Vfront 5 Vsync 5 Vback 39 Vpol N
Not only that !
I’ve been able to run the monitor at 75Hz with MacOs as well (tested on Macbook Pro M2 (16inch) and Macbook Pro 2021 13 inch). I bought 3 identical monitors because I am really happy with colors, refresh_rate, viewing angles etc…
This is probably the crux of the issue…
BenQ also says it’s a 60Hz Monitor, no dice.
why would nouveau allow me to use 74HZ then o.O or MacOS’s drivers. in Amazon it says it’s 76Hz.
Anyway, thank you for your help, I will try to get a screenshot and upload when I get a chance.
Is there a solution for this?
Does Nvidia have a plan to provide a solution anytime soon?
