As the title says above, regardless of what distro or linux kernel or desktop environment I use, I cannot set my refresh rate to it’s maximum (on drivers later than the 550 version) that the monitor allows which is 100hz, I can only set it to 75 otherwise it loses signal. This is the nvidia log I created while using the 570 beta driver downloaded from the Nvidia site itself.
nvidia-bug-report.log.gz (896.1 KB)
Here is the output I receive from Xrandr while using the 550 version driver:
Screen 0: minimum 8 x 8, current 2560 x 1440, maximum 32767 x 32767
HDMI-0 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 598mm x 336mm
2560x1440 59.95 + 99.95* 75.00
1920x1080 60.00 59.94 50.00
1680x1050 59.95
1440x900 59.89
1280x1024 75.02 60.02
1280x960 60.00
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
Here is my system information:
System:
Kernel: 6.11.0-1013-oem arch: x86_64 bits: 64 compiler: gcc v: 13.3.0 clocksource: tsc
Desktop: Cinnamon v: 6.4.6 tk: GTK v: 3.24.41 wm: Muffin v: 6.4.1 vt: 7 dm: LightDM v: 1.30.0
Distro: Linux Mint 22.1 Xia base: Ubuntu 24.04 noble
Machine:
Type: Desktop System: Micro-Star product: MS-7C96 v: 2.0 serial:
Mobo: Micro-Star model: A520M PRO-VH (MS-7C96) v: 2.0 serial:
uuid: UEFI: American Megatrends LLC. v: A.D0 date: 03/21/2024
Battery:
Device-1: ps-controller-battery-48:18:8d:32:57:34 model: N/A serial: N/A charge: N/A status: full
CPU:
Info: 8-core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP smt: enabled arch: Zen 3+ rev: 0
cache: L1: 512 KiB L2: 4 MiB L3: 32 MiB
Speed (MHz): avg: 2002 high: 3612 min/max: 550/3801 boost: disabled cores: 1: 550 2: 550 3: 550
4: 550 5: 3520 6: 3447 7: 3393 8: 3612 9: 3394 10: 550 11: 550 12: 3287 13: 3600 14: 550 15: 3382
16: 550 bogomips: 121601
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: Micro-Star MSI driver: nvidia
v: 550.144.03 arch: Ampere pcie: speed: 8 GT/s lanes: 16 ports: active: none off: HDMI-A-1
empty: DP-1,DP-2,DP-3 bus-ID: 23:00.0 chip-ID: 10de:2504 class-ID: 0300
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X: loaded: nouveau
unloaded: fbdev,modesetting,vesa failed: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x333mm (23.70x13.11") s-diag: 688mm (27.09")
Monitor-1: HDMI-0 res: 2560x1440 dpi: 109 size: 598x336mm (23.54x13.23") diag: 686mm (27.01")
modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2 drv: swrast gbm:
drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.144.03 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
Audio:
Device-1: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel pcie: speed: 8 GT/s lanes: 16 bus-ID: 23:00.1 chip-ID: 10de:228e class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: speed: 16 GT/s lanes: 16 bus-ID: 25:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Generic USB Audio driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 bus-ID: 1-7:3 chip-ID: 001f:0b21 class-ID: 0300 serial:
Device-4: Sony DualSense wireless controller (PS5) driver: playstation,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-8:6 chip-ID: 054c:0ce6 class-ID: 0300
API: ALSA v: k6.11.0-1013-oem status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse status: active
2: wireplumber status: active 3: pipewire-alsa type: plugin
Network:
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
RTL8111/8168/8411 driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: f000
bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 100 Mbps duplex: full mac:
Device-2: Sony DualSense wireless controller (PS5) driver: playstation,snd-usb-audio,usbhid
Bluetooth:
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 bus-ID: 1-5:2 chip-ID: 0a12:0001 class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address:
Drives:
Local Storage: total: 3.66 TiB used: 3.09 TiB (84.3%)
ID-1: /dev/sda vendor: Western Digital model: WD20EZRZ-00Z5HB0 size: 1.82 TiB speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: fw-rev: 0A80 scheme: GPT
ID-2: /dev/sdb vendor: Samsung model: HD103SI size: 931.51 GiB speed: 3.0 Gb/s tech: N/A
serial: fw-rev: 1118 scheme: MBR
ID-3: /dev/sdc vendor: Hikvision model: HS-SSD-E100 1024G size: 953.87 GiB speed: 6.0 Gb/s
tech: SSD serial: fw-rev: 108 scheme: GPT
Partition:
ID-1: / size: 80 GiB used: 38.3 GiB (47.9%) fs: btrfs dev: /dev/sdc4
ID-2: /boot size: 2.88 GiB used: 287.6 MiB (9.7%) fs: ext4 dev: /dev/sdc3
ID-3: /boot/efi size: 2 GiB used: 37.1 MiB (1.8%) fs: vfat dev: /dev/sdc1
ID-4: /home size: 601.32 GiB used: 538.46 GiB (89.5%) fs: ext4 dev: /dev/sdc2
Swap:
Alert: No swap data was found.
USB:
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 9 rev: 2.0 speed: 480 Mb/s lanes: 1
chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 1-5:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s lanes: 1 chip-ID: 0a12:0001 class-ID: e001
Device-2: 1-7:3 info: Generic USB Audio type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s lanes: 1
power: 100mA chip-ID: 001f:0b21 class-ID: 0300 serial:
Device-3: 1-8:6 info: Sony DualSense wireless controller (PS5) type: audio,HID
driver: playstation,snd-usb-audio,usbhid interfaces: 4 rev: 2.0 speed: 480 Mb/s lanes: 1
power: 500mA chip-ID: 054c:0ce6 class-ID: 0300
Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1 speed: 10 Gb/s lanes: 1 chip-ID: 1d6b:0003
class-ID: 0900
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0 speed: 480 Mb/s lanes: 1
Device-1: 3-2:4 info: ROCCAT HORDE AIMO type: keyboard,HID driver: hid-generic,usbhid
interfaces: 4 rev: 2.0 speed: 12 Mb/s lanes: 1 power: 500mA chip-ID: 1e7d:303e class-ID: 0300
Device-2: 3-3:3 info: Holtek USB Gaming Mouse type: mouse,keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s lanes: 1 power: 100mA
chip-ID: 04d9:a259 class-ID: 0300
Hub-4: 4-0:1 info: super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s lanes: 1 chip-ID: 1d6b:0003
class-ID: 0900
Sensors:
System Temperatures: cpu: 53.2 C mobo: N/A gpu: nvidia temp: 46 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 30%
Repos:
Packages: 2613 pm: dpkg pkgs: 2571 pm: flatpak pkgs: 42
No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/cappelikan-ppa-noble.list
Memory: total: 16 GiB available: 15.54 GiB used: 7.53 GiB (48.4%)
Processes: 405 Power: uptime: 1h 54m states: freeze,mem,disk suspend: deep wakeups: 0
hibernate: platform Init: systemd v: 255 target: graphical (5) default: graphical
Compilers: gcc: 13.3.0 Client: Cinnamon v: 6.4.6 inxi: 3.3.34
If any other logs are needed, feel free to ask. Any help with this issue would be greatly appreciated as this problem causes issues downstream where I lose signal on reaching the login screen if the display are set to 100hz on distros that run the latest drivers.
