External HDMI Monitor loses signal with high refresh rates under KDE Wayland
Description
Similar to Geforce RTX 3060 Can't set refresh rate to maximum, monitor loses signal on driver versions above 550, the monitor reports “No Singal” when its refresh rate is set to any higher than 60Hz.
The monitor model is KTC H24T09P, its maximum refresh rate is 1920x1080@165, and when using Windows this issue does not appear.
Under KDE Wayland I have 50, 60, 120, 144 and 165Hz available for setting, but only 60 and 50Hz work, no significant frame drop is observed currently under these two refresh rates.
Windows reports this monitor is on the NVIDIA dGPU, by executing ls /sys/class/drm/ under linux it seems that the situation is the same (Where DP is on iGPU, and HDMI is on dGPU):
owo » ls /sys/class/drm/
card0       card0-DP-2   card1        card1-HDMI-A-1  renderD129
card0-DP-1  card0-eDP-1  card1-eDP-2  renderD128      version
System Spec (If it helps):
Operating System: Arch Linux
KDE Plasma Version: 6.3.3
KDE Frameworks Version: 6.12.0
Qt Version: 6.8.3
Kernel Version: 6.14.0-3-cachyos (64-bit)
Graphics Platform: Wayland
Processors: 20 × 12th Gen Intel® Core™ i7-12700H
Memory: 31.0 GiB of RAM
Graphics Processor 1: NVIDIA GeForce RTX 3060 Laptop GPU
Graphics Processor 2: Intel® Iris® Xe Graphics
Manufacturer: Dell Inc.
Product Name: Dell G15 5520
Outputs from edid-decode for this monitor: edid-decode-output.txt (6.2 KB)
nvidia-bug-report: nvidia-bug-report.log.gz (1.8 MB)
System log: journal.txt (354.8 KB)
This seems related to this issue: [Bug] External monitor fails to wake up from powersave mode if refresh rate is higher than 30Hz - #27 by evorster
