Monitor refresh rate bugs out after going to sleep
I am using a Alienware AW3225QF monitor that can run (on Windows) with the following settings in the Nvidia App: 3840x2160 resolution, 240hz refresh rate, 12bit color mode
However, on Linux, whenever I use HDMI 2.1, I seem to have a strange issue that happens only after the monitor has been in sleep mode for a period of time. What will happen is that my monitor gets limited to 60hz only, which only can be fixed by restarting the PC, which will fix the issue and I can select 240hz again. What I can see is that whenever this bug occurs, my monitor will say that the current signal is: 2160p 36bit
If the bug doesn’t occur, it will instead say something like “3840x2160,30bit,240hz”.
I have attached two Nvidia Bug Report files in this post, one before the bug occurs and one after the bug has occured, hoping it will show you what has changed once the bug has occured.
nvidia-bug-report.log_before-bug.gz (1.0 MB)
nvidia-bug-report.log_after_bug.gz (1021.2 KB)
Hi @VirtualBoost_v2
We have already filed a bug 5667607 internally for tracking purpose.
I will try to duplicate issue locally and will get back if required any additional information.
Hi @amrits!
Awesome, please let me know if you need any help. I have noticed that this doesn’t seem to happen when I use DisplayPort, but then my VRR seems to glitch out so I prefer using HDMI.
This is also happening to me. Willing to provide logs if needed. Running Driver Version: 580.95.05 with RTX3070. Also on HDMI.
Still an issue. Driver 590 via CachyOS.
240hz gets stuck at 60hz until I turn the monitor off and on or reboot. Happens regardless of distro, DE etc. Using Wayland on HDMI 2.1
Hi All,
Please ignore the earlier mentioned bug tracking number, it turned out to be a different bug.
I have filed a new bug 5801388 for it.
Hi @dhfragged @VirtualBoost_v2 @StarMech67
Will be really helpful if you can share nvidia bug report from repro state along display model.
Hi @amrits,
I believe that my initial attached files should cover this, my monitor is a AW3225QF. Can you confirm?
Dear @VirtualBoost_v2
I was able to find exact same display in our lab but unfortunately not able to reproduce issue.
I have tried suspend/resume operation around 5 times and kept system in suspended mode for 20-30 mins.
System - ASRock TRX40 Taichi
OS - Arch Linux with kernel 6.12.63-1-lts
GPU - NVIDIA GeForce RTX 4090
Driver 590.48.01
KDE Plasma 6.5.4
Wayland Protocol
Display Alienware AW3225QF connected via HDMI with resolution 3840 x 210 and refresh rate as 240 Hz
Could you please confirm how long you keep system in sleep mode and what is repro frequency.
Hi, If it helps, I am still experiencing this issue, albeit with a different monitor. This has been an issue for months now and I have not received any kind of feedback from my bug reports.
System/Motherboard - ROG STrix Z690-G Gaming Wifi
OS - Bazzite (latest build)
GPU - NVIDIA GeForce RTX 4090 (MSI Gaming Trio)
Driver 590.48.01
KDE Plasma 6.5.5
Wayland
Display: Samsung G93SC connected via HDMI with resolution of 5120x1440 and refresh rate as 240 Hz
If I connect the display via displayport, after the monitor sleeps, it never comes back. I have to use TTY (F4 to F2) to bring the monitor back or reboot.
I have the same problem like @dhfragged, first posted here.
In addition, the 240 Hz mode appears to be unstable. Sometimes the monitor loses connection and has to be reset to factory settings in order to work again. This problem does not occur in 120 Hz mode.
My System:
  • OS: CachyOS latest
  • GPU: NVIDIA GeForce RTX 4090
  • Driver: 590.48.01
  • KDE Plasma 6.5.5 (Wayland)
  • Display: Odyssey G9 Neo (5120x1440 and refresh rate 240 Hz), EDID here
Hi @amrits
What I do is lower the time when KDE puts the monitor into sleep to 1 minute, and then I wait for it go to sleep. Another way is just locking your PC, then press ESC on the login screen to force it go to sleep. Finally, I wait until the on/off-button starts blinking white, so I know that the monitor has gone into sleep.
After that, after I wake the monitor up again by moving the mouse, it will most of the times go into the 60hz only mode.
One thing I noticed that seems to be different is that I use a later kernel as I’m using CachyOS and not LTS. I doubt it has anything to do with the problem, but could you perhaps try with CachyOS (latest version is fine) and see if it happens then?
Hi @VirtualBoost_v2
I installed Cachy OS with kernel 6.19.2-2 but did not observe repro.
Setup - ASRock TRX40 Taichi + CachyOS + kernel 6.19.2-2-cachyos + NVIDIA GeForce RTX 4090 + 590.48.01 + Alienware AW3225QF monitor with 3840x2160 resolution and 240hz refresh rate connected via HDMI 2.1 + KDE Plasma + Wayland
Steps Tried -
  1. Make changes in power setting so that system go to sleep after a min.
  2. Upon resume, display comes up back with 240 Hz
  3. Tried above steps 10 times but did not observe repro.
  4. Enter system into sleep mode via GUI multiple but times and did not observe any issue upon resume.
Checking if any changes in monitor settings are done at your end or any specific display setting causing this issue.
Do you see this issue with previous drivers as well ?
I’m having the same issue with the same builds, except with a Samsung GS80D 4k 240hz. It seems intermittent, but most of the time if the monitor sleeps due to PC sleep, monitor off, or just turning the monitor off it will sometimes lock at 60hz with no way to return to 240 unless I reboot or unplug/replug monitor. If I can provide logs or more info please let me know. FYI this was fine until 2 weeksish ago.
I’m having the same issue, after resuming from sleep the refresh rate bugs out and I can no longer set it to 240Hz, only 60Hz.
Setup - Intel 13900k w/ Z790PG Riptide, Arch Linux (kernel linux-6.18.13), RTX 3090 (590.48.01), Samsung G93SC OLED (5120x1440@240Hz), HDMI 2.1 connection, GNOME Wayland (GDM) or Plasma Wayland (SDDM). Also observed on an AMD 9950X3D w/ Gigabyte X870 Gaming X Wifi 7, Arch Linux (kernel linux-6.18.13), RTX 4090 (590.48.01), on the same monitor.
The issue happens regardless of whether VRR and/or HDR are enabled or disabled, both on the monitor and on the OS.
Steps to reproduce reliably:
  1. Disable automatic suspend
  2. Let the system go to sleep (either on its own or manually)
  3. Wait. This is extremely important to reproduce the issue, it won’t happen if you wake it up straight away. I suspect there needs to be enough time for the monitor itself to go to sleep or trigger some other power saving routing, if there even is such a thing, maybe 20/30 minutes.
  4. On resume, the resolution will be (in my case) 3840x1080@120Hz, with the option to go up to 5120x1440@60Hz. I can “fix it” by disconnecting and reconnecting the monitor.
If I had to guess I’d say there’s something broken during maybe some handshake/negotiation on wake? I get a similar behavior when using DisplayPort using a multi monitor KVM switch and switching input.
Same issue here — Alienware AW3425DW (3440x1440 OLED, 240Hz) on CachyOS, NVIDIA RTX 5090, driver 595.45.04, KDE Plasma 6 Wayland.
After DPMS sleep, the monitor locks to 59.97Hz at native res and all high-refresh modes (120/175/240Hz) disappear. Only a full reboot restores them — toggling the output via software does not.
Dumping the EDID post-sleep reveals the root cause: block 2 (the third 128-byte block) becomes a corrupt copy of block 0 — it starts with the standard 00 ff ff ff ff ff ff 00 EDID header instead of
a valid extension tag. Block 0 only contains a single 3440x1440 timing at 59.97Hz. The high-refresh timings live in block 2, which is gone after wake.
On a fresh boot, block 2 is valid and all modes are present. This strongly suggests the driver is either misreading or corrupting the EDID on resume rather than the monitor sending bad data.
Workaround that works: Capture the clean EDID at boot, install it as a firmware override (/lib/firmware/edid/), and pass drm.edid_firmware=DP-1:edid/aw3425dw.bin as a kernel parameter. This forces
the driver to use the known-good EDID regardless of what it reads after wake. Just applied this — will report back after testing.
This seems like an NVIDIA driver bug on Wayland where the EDID re-read on resume is broken or partially handled. Would appreciate a proper fix on the driver side.
Update: The workaround holds — after a sleep/wake cycle, all refresh rate modes (120/175/240Hz) are back and selectable. Consider this confirmed.
One additional side effect worth mentioning: the EDID corruption triggers a full disconnect/reconnect cycle on wake, which also breaks KDE’s lock screen (kscreenlocker). PAM rejects the password immediately after wake with “Authentication attempt
too soon” — you have to wait ~10–15 seconds before typing. The EDID firmware override fixes this too since it prevents the disconnect/reconnect from happening.
On the root cause: this never happens on Windows with the same monitor and GPU, which strongly suggests the bug is in the Linux NVIDIA driver’s resume path — likely a malformed or poorly-timed DP AUX transaction when re-reading the EDID on wake,
causing the monitor to return garbage for block 2. Windows handles it correctly. The workaround forces the driver to skip that re-read entirely, which is why it works.
Summary of fix:
  1. Capture clean EDID at boot: cp /sys/class/drm/card1-DP-1/edid ~/aw3425dw.bin
  2. Install as firmware override: sudo cp ~/aw3425dw.bin /lib/firmware/edid/aw3425dw.bin
  3. Add kernel parameter: drm.edid_firmware=DP-1:edid/aw3425dw.bin
  4. Rebuild initramfs: sudo mkinitcpio -P
Additional info for the engineering team: I have a second monitor also connected via DisplayPort (LG ULTRAGEAR+, 3840x2160 OLED, 240Hz) on DP-2, and it does not exhibit this issue — high-refresh modes survive sleep/wake fine. Its 240Hz timing is
also in block 2 (DisplayID extension), so the EDID structure is similar. This suggests the bug may be specific to DP-1 or something particular to the AW3425DW’s interaction with the driver on resume.
Hi All,
I was able to repro issue and engineering team is currently investigating it.
Any ETA on a fix?
Still happening on driver 595.58.03, Fedora 44, KDE Plasma Wayland,
RTX 5090.
Monitor: Dell AW3425DW (3440x1440@240Hz, DP)
After a longer sleep, the driver fails to re-read the full EDID. It
generates a fake 128-byte fallback EDID (manufacturer “NVD”) with
only 1920x1080 modes. The real EDID is 384 bytes. The i2c bus (0x50)
returns all-XX on read attempts — the DP aux channel appears dead
until cable replug.
I’m experiencing the exact same problem on Fedora 44, and it is still happening with driver 595.71.05.
System: Fedora 44, KDE Plasma Wayland, RTX 3090, Samsung Odyssey G9.
Same issue on cachyos, 610.43.02 driver with a 5080, 360hz oled asus screen
