Can't get higher refresh rate of my monitor on Wayland
I recently noticed that my monitor was no longer at a 75Hz refresh rate, only 60Hz at 1920x1080. I thought it was some problem with the Hyprland configuration, but everything was ok. I went into KDE Plasma to see if the problem persisted, and yes, it continued in the same way.
I went to my Windows in dual boot and saw that it was also at 1920x1080@75Hz, so I enabled my integrated GPU to see if it could use the 75Hz of my monitor in Arch Linux, and it worked. With that, I concluded that it is a problem with Nvidia, and I thought it had to do with the new version of the 580.105.08 driver, but it wasn’t that. I have a screenshot with a fastfetch taken a few days after the driver was released, and my monitor was at 75Hz. I don’t know what kind of update caused my refresh rate to become like this, but I searched for some solutions on the internet, but none solved the problem.
This is my machine specs:
CPU: AMD Ryzen 5 8500G (12) @ 5.08 GHz
GPU: NVIDIA GeForce RTX 3060 Lite Hash Rate
And here’s my hyprctl monitors output:
Monitor HDMI-A-1 (ID 0):
	1920x1080@60.00000 at 0x0
	description: LG Electronics LG FULL HD 0x00035EAE
	make: LG Electronics
	model: LG FULL HD
	physical size (mm): 480x270
	serial: 0x00035EAE
	active workspace: 2 (2)
	special workspace: 0 ()
	reserved: 0 40 0 0
	scale: 1.00
	transform: 0
	focused: yes
	dpmsStatus: 1
	vrr: false
	solitary: 0
	solitaryBlockedBy: windowed mode,missing candidate
	activelyTearing: false
	tearingBlockedBy: next frame is not torn,user settings,missing candidate
	directScanoutTo: 0
	directScanoutBlockedBy: user settings,missing candidate
	disabled: false
	currentFormat: XRGB8888
	mirrorOf: none
	availableModes: 1920x1080@60.00Hz 1920x1080@59.94Hz 1920x1080@50.00Hz 1680x1050@59.95Hz 1400x1050@59.98Hz 1600x900@60.00Hz 1280x1024@75.03Hz 1280x1024@60.02Hz 1440x900@59.89Hz 1280x800@59.81Hz 1152x864@75.00Hz 1280x720@60.00Hz 1280x720@59.94Hz 1280x720@50.00Hz 1024x768@75.03Hz 1024x768@60.00Hz 800x600@75.00Hz 800x600@60.32Hz 720x576@50.00Hz 720x480@59.94Hz 640x480@75.00Hz 640x480@59.94Hz 640x480@59.93Hz
	colorManagementPreset: srgb
	sdrBrightness: 1.00
	sdrSaturation: 1.00
	sdrMinLuminance: 0.20
	sdrMaxLuminance: 80
I have this exact same problem. Nothing really else to add though if someone wants me to run some commands to debug this I’d be happy to :)
I just updated and I have the same problem. With nvidia driver version 580.105.05 my screen works perfectly but when I have the 580.105.08 drivers, 75Hz isn’t an option anymore. does anyone know how to fix that ?
and for info, screen : iiyama PLE2283H
GPU : NVIDIA GeForce GTX 1650
The fact that the problem occurred in older driver versions explains why the 75Hz refresh rate previously worked even on version 580.105, but now it doesn’t. I tried to find the 580.105.05 package on archive.archlinux.org to test it on my system, but unfortunately they only have version 580.105.08 :/
thanks
@fhilipecrash Are you sure you don’t mean 580.95.05? I don’t think there ever was 580.105.05 only 580.105.08. See here.
You might try looking for 580.95.05 on archive.archlinux.org.
We released 580.119.02.
