Undetected ultrawide resolution upon upgrade to Driver Version: 580.105.08
nvidia-bug-report.log.gz (1.1 MB)
Previously working 2560x1080 monitor now can only be set to up to 1920x1080 after driver update (580.105.08). If driver is uninstalled, the monitor will correctly default to 2560x1080 meaning this is not a problem with EDID. GPU is a GTX 1080. Problem is irrespective of compositor being used.
xrandr output for ultrawide monitor.
HDMI-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 798mm x 334mm
1920x1080 60.00*+ 59.94 50.00 29.97 60.05 60.00 50.04
1680x1050 59.95
1600x900 60.00
1280x1024 75.02 60.02
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
Please let me know if you require any additional information
I confirm this happened to me as well. After upgrade to 580.105 with HDMI it detects wrong resolution. Native is 2560x1440@59.95, after upgrade it only detects 2048x1152@60. Display port works OK. 2 monitors, same behavior. Revert to 580.95 fixed it. Monitor: PL3270Q, GPU: RTX 3060 Laptop
In release notes for 580.105 they introduced some bugfixes for HDMI resolution - it seems they added some new ones.
Same here – GTX 1050 Ti + 2560×1080 ultrawide over HDMI.
Driver 580.105.08 caps the list at 1920×1080.
Downgrade to 580.95.05 resolved it.
same behaviour regarding resolution. ‘upgraded’ to 580.105 on 10 Nov from archlinux repo
System is archlinux, kernel 6.17.7, gpu ASUS GTX980, dual monitors - HDMI , DVI.
before on 580.95 - both monitors running at 2560x1440, 60Hz
after installation of 580.105 - HDMI monitor reverts to 1920x1080 and cannot be set to 2560x1440 mode; DVI monitor unchanged.
reverted to 580.95 and original settings were restored without intervention.
I reported this regression in the evening of Nov 10, and yesterday they gave the following update:
some more info in that thread and here if you’re interested. I’ll note for me it was both HDMI and DP impacted.
Great, thanks for the info! Apologies for duplicating the post. I looked for a thread documenting it but did not find the reply in the feedback thread.
Same here after upgrading to Fedora 43, fixed by downgrading to 580.95.05
Hi folks,
I am really sorry about this regression and we have been working on a solution that you can see in the following thread.
Thanks,
Rahul Rameshbabu
@rrameshbabu
Any chance this issue could have started before 580.105.08? I’ve had a similar (maybe it’s the same) problem with every version of 580. In short, my external HDMI monitor is only able to do 1366x768 when it should be able to do 1920x1080@75. I posted about it here but have never received any response from anyone at NVIDIA.
That post was before 580.105.08 was released, but I can confirm it’s still the same problem now. I’d be happy to generate additional logs or test any distro/driver version I’m able to.
@forbyta we have identified the regression that has wide impact to have been caused by a change only introduced in 580.105.08. There could be another issue impacting you. Let me take a look through your original post.
@rrameshbabu Thank you. Please let me know if I should create a new post and if I can provide any additional information or do specific testing.
A new post would be helpful for me to not lose track of this issue. Thanks!
@rrameshbabu
Thank you for looking into this.
A solution for everyone, or just for those with newer GPUs which support the open drivers?
I see there’s a patch out for those, but I have a GTX 1080.
Yes, we are aware the patch cannot be consumed by Pascal users. In our future driver releases, we will have the fix applied.
Thanks,
Rahul Rameshbabu
It’s been weeks…
Still affected by this issue: RTX 4060, Wayland, Driver version 580.105.08 How can I get the patch that @BlackPhoenixPhoto mentioned?
Install the nvidia open source drivers.
Thanks, appreciate it.
Will the driver for the 580 series fix the issue with incorrect display frequency (60 Hz limit)?
If so, when will it be released (approximately)?
Thank you.
