hello,
As the below link, my Ubuntu 22.04 with nvidia-driver-525 is capped at 60 FPS on a 144hz screen.
The solution proposed in the link, I already have nvidia-drm.modeset=1
hwinfo --monitor
25: None 00.0: 10002 LCD Monitor
[Created at monitor.125]
Unique ID: rdCR.DWAKdXquu1C
Parent ID: VCu0.m01TfQCzPH5
Hardware Class: monitor
Model: "AOC 2460G5"
Vendor: AOC "AOC"
Device: eisa 0x246a "2460G5"
Resolution: 720x400@70Hz
Resolution: 640x480@60Hz
Resolution: 640x480@67Hz
Resolution: 640x480@72Hz
Resolution: 640x480@75Hz
Resolution: 800x600@56Hz
Resolution: 800x600@60Hz
Resolution: 800x600@72Hz
Resolution: 800x600@75Hz
Resolution: 832x624@75Hz
Resolution: 1024x768@60Hz
Resolution: 1024x768@70Hz
Resolution: 1024x768@75Hz
Resolution: 1280x1024@75Hz
Resolution: 1920x1080@60Hz
Resolution: 1280x1024@60Hz
Year of Manufacture: 2020
Week of Manufacture: 8
Detailed Timings #0:
Horizontal: 1920 1928 1960 2026 (+8 +40 +106) +hsync
Vertical: 1080 1105 1113 1119 (+25 +33 +39) +vsync
Frequencies: 170.00 MHz, 83.91 kHz, 74.99 Hz
Detailed Timings #1:
Horizontal: 1920 2008 2052 2200 (+88 +132 +280) +hsync
Vertical: 1080 1084 1089 1125 (+4 +9 +45) +vsync
Frequencies: 148.50 MHz, 67.50 kHz, 60.00 Hz
Driver Info #0:
Max. Resolution: 1920x1080
Vert. Sync Range: 35-76 Hz
Hor. Sync Range: 83-83 kHz
Bandwidth: 170 MHz
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #10 (VGA compatible controller)
26: None 00.0: 10002 LCD Monitor
Unique ID: rdCR.6fi6_5H8y92
Parent ID: _Znp.85XKzd7sl2A
Model: "T1WD3 NV15N3D LCD Monitor"
Vendor: BOE "T1WD3 NV15N3D"
Device: eisa 0x0819
Year of Manufacture: 2018
Week of Manufacture: 32
Horizontal: 1920 1968 2000 2212 (+48 +80 +292) -hsync
Vertical: 1080 1083 1089 1140 (+3 +9 +60) +vsync
Frequencies: 121.04 MHz, 54.72 kHz, 48.00 Hz
Frequencies: 151.30 MHz, 68.40 kHz, 60.00 Hz
Attached to: #21 (VGA compatible controller)
If you need more information beyond what is in the bug-report, let me know.
nvidia-bug-report.log.gz (375.9 KB)
EDIT 22-12:
I also tried putting the variable __GL_SYNC_DISPLAY_DEVICE=eDP-1-1, but that didn’t work either.
