I encountered the following error when launching Jupyter Lab on the DGX Dashboard
Collecting polars==1.33.1 (from -r /home/xiaohong/jupyterlab/requirements.txt (line 27)) Downloading polars-1.33.1-cp39-abi3-manylinux_2_24_aarch64.whl.metadata (15 kB) ERROR: Ignored the following versions that require a different python version: 1.21.2 Requires-Python >=3.7,<3.11; 1.21.3 Requires-Python >=3.7,<3.11; 1.21.4 Requires-Python >=3.7,<3.11; 1.21.5 Requires-Python >=3.7,<3.11; 1.21.6 Requires-Python >=3.7,<3.11 ERROR: Could not find a version that satisfies the requirement dask==2025.9.1 (from versions: none) ERROR: No matching distribution found for dask==2025.9.1 d a version that satisfies the requirement dask==2025.9.1 (from versions: none) ERROR: No matching distribution found for dask==2025.9.1
Which python versions do you have installed on your system? Seems like an incompatibility with Python version above 3.10
