jetson-container build jupyterlab fails on pypi.jetson-ai-lab.io HTTP status server error (503 Service Temporarily Unavailable) for url.
The pull request fails from inside the docker image, but direct access is fine.
Using Python 3.10.19 environment at: /opt/venv
Resolved 99 packages in 16.09s
Downloading widgetsnbextension (2.1MiB)
Downloading babel (9.7MiB)
Downloaded widgetsnbextension
Downloading notebook (13.8MiB)
× Failed to download `pyzmq==27.1.0`
├─▶ Request failed after 3 retries
├─▶ Failed to fetch:
│ `https://pypi.jetson-ai-lab.io/root/pypi/+f/bf7/b38f9fd7b81cb/pyzmq-27.1.0-cp310-cp310-manylinux_2_26_aarch64.manylinux_2_28_aarch64.whl`
╰─▶ HTTP status server error (503 Service Temporarily Unavailable) for url
(https://pypi.jetson-ai-lab.io/root/pypi/+f/bf7/b38f9fd7b81cb/pyzmq-27.1.0-cp310-cp310-manylinux_2_26_aarch64.manylinux_2_28_aarch64.whl)
help: `pyzmq` (v27.1.0) was included because `jupyterlab` (v4.5.1) depends
on `jupyter-server` (v2.17.0) which depends on `pyzmq`
The command '/bin/bash -c uv pip install jupyter "jupyterlab${JUPYTERLAB_VERSION_SPEC}" && uv pip install jupyterlab_widgets' returned a non-zero code: 1
