Unable to modify https://pypi.jetson-ai-lab.dev causing installation failure
caesar@ubuntu:~/jetson-containers$ DOCKER_BUILDKIT=0 docker build   --no-cache   --network=host   --tag whisper:r36.4.tegra-aarch64-cu126-22.04-python   --file packages/build/python/Dockerfile   --build-arg BASE_IMAGE=whisper:r36.4.tegra-aarch64-cu126-22.04-cuda_12.6   --build-arg PYTHON_VERSION="3.10"   packages/build/python
\DEPRECATED: The legacy builder is deprecated and will be removed in a future release.
            BuildKit is currently disabled; enable it by removing the DOCKER_BUILDKIT=0
            environment-variable.
Sending build context to Docker daemon  40.45kB
Step 1/6 : ARG BASE_IMAGE
Step 2/6 : FROM ${BASE_IMAGE}
 ---> 723761fe7cb9
Step 3/6 : ARG PYTHON_VERSION     TMP=/tmp/python
 ---> Running in b8181613b7cc
 ---> Removed intermediate container b8181613b7cc
 ---> 3f0d276b19f6
Step 4/6 : ENV PYTHON_VERSION=${PYTHON_VERSION}     PYTHONFAULTHANDLER=1     PYTHONUNBUFFERED=1     PYTHONIOENCODING=utf-8     PYTHONHASHSEED=random     PIP_NO_CACHE_DIR=true     PIP_CACHE_PURGE=true     PIP_ROOT_USER_ACTION=ignore     PIP_DISABLE_PIP_VERSION_CHECK=on     PIP_DEFAULT_TIMEOUT=100     PIP_WHEEL_DIR=/opt/wheels     PIP_VERBOSE=1     TWINE_NON_INTERACTIVE=1     DEBIAN_FRONTEND=noninteractive     PATH=/opt/venv/bin:$PATH
 ---> Running in f2ea28cc90ee
 ---> Removed intermediate container f2ea28cc90ee
 ---> 6daf09025e8d
Step 5/6 : COPY install.sh $TMP/
 ---> 3df309f14497
Step 6/6 : RUN $TMP/install.sh
 ---> Running in d1dc40c48993
+ apt-get update
Get:1 http://ports.ubuntu.com/ubuntu-ports jammy InRelease [270 kB]
Get:2 http://ports.ubuntu.com/ubuntu-ports jammy-updates InRelease [128 kB]
Get:3 http://ports.ubuntu.com/ubuntu-ports jammy-backports InRelease [127 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports jammy-security InRelease [129 kB]
Get:5 http://ports.ubuntu.com/ubuntu-ports jammy/multiverse arm64 Packages [224 kB]
Get:6 http://ports.ubuntu.com/ubuntu-ports jammy/restricted arm64 Packages [24.2 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports jammy/universe arm64 Packages [17.2 MB]
Get:8 http://ports.ubuntu.com/ubuntu-ports jammy/main arm64 Packages [1,758 kB]
Get:9 http://ports.ubuntu.com/ubuntu-ports jammy-updates/universe arm64 Packages [1,572 kB]
Get:10 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 Packages [3,226 kB]
Get:11 http://ports.ubuntu.com/ubuntu-ports jammy-updates/multiverse arm64 Packages [52.7 kB]
Get:12 http://ports.ubuntu.com/ubuntu-ports jammy-updates/restricted arm64 Packages [4,709 kB]
Get:13 http://ports.ubuntu.com/ubuntu-ports jammy-backports/main arm64 Packages [82.8 kB]
Get:14 http://ports.ubuntu.com/ubuntu-ports jammy-backports/universe arm64 Packages [33.3 kB]
Get:15 http://ports.ubuntu.com/ubuntu-ports jammy-security/multiverse arm64 Packages [27.2 kB]
Get:16 http://ports.ubuntu.com/ubuntu-ports jammy-security/main arm64 Packages [2,922 kB]
Get:17 http://ports.ubuntu.com/ubuntu-ports jammy-security/restricted arm64 Packages [4,524 kB]
Get:18 http://ports.ubuntu.com/ubuntu-ports jammy-security/universe arm64 Packages [1,275 kB]
Fetched 38.3 MB in 9s (4,502 kB/s)
Reading package lists...
+ apt-get install -y --no-install-recommends python3.10 python3.10-dev
Building dependency tree...
Reading state information...
python3.10 is already the newest version (3.10.12-1~22.04.10).
python3.10 set to manually installed.
The following additional packages will be installed:
  libexpat1-dev libpython3.10-dev zlib1g-dev
The following NEW packages will be installed:
  libexpat1-dev libpython3.10-dev python3.10-dev zlib1g-dev
0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
Need to get 5,467 kB of archives.
After this operation, 21.0 MB of additional disk space will be used.
Get:1 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 libexpat1-dev arm64 2.4.7-1ubuntu0.6 [130 kB]
Get:2 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 zlib1g-dev arm64 1:1.2.11.dfsg-2ubuntu9.2 [163 kB]
Get:3 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 libpython3.10-dev arm64 3.10.12-1~22.04.10 [4,666 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 python3.10-dev arm64 3.10.12-1~22.04.10 [508 kB]
debconf: delaying package configuration, since apt-utils is not installed
Fetched 5,467 kB in 2s (2,385 kB/s)
Selecting previously unselected package libexpat1-dev:arm64.
(Reading database ... 29336 files and directories currently installed.)
Preparing to unpack .../libexpat1-dev_2.4.7-1ubuntu0.6_arm64.deb ...
Unpacking libexpat1-dev:arm64 (2.4.7-1ubuntu0.6) ...
Selecting previously unselected package zlib1g-dev:arm64.
Preparing to unpack .../zlib1g-dev_1%3a1.2.11.dfsg-2ubuntu9.2_arm64.deb ...
Unpacking zlib1g-dev:arm64 (1:1.2.11.dfsg-2ubuntu9.2) ...
Selecting previously unselected package libpython3.10-dev:arm64.
Preparing to unpack .../libpython3.10-dev_3.10.12-1~22.04.10_arm64.deb ...
Unpacking libpython3.10-dev:arm64 (3.10.12-1~22.04.10) ...
Selecting previously unselected package python3.10-dev.
Preparing to unpack .../python3.10-dev_3.10.12-1~22.04.10_arm64.deb ...
Unpacking python3.10-dev (3.10.12-1~22.04.10) ...
Setting up libexpat1-dev:arm64 (2.4.7-1ubuntu0.6) ...
Setting up zlib1g-dev:arm64 (1:1.2.11.dfsg-2ubuntu9.2) ...
Setting up libpython3.10-dev:arm64 (3.10.12-1~22.04.10) ...
Setting up python3.10-dev (3.10.12-1~22.04.10) ...
+ which python3.10
/usr/bin/python3.10
+ return_code=0
+ set -e
+ '[' 0 '!=' 0 ']'
++ lsb_release -rs
+ distro=22.04
+ '[' 22.04 = 24.04 ']'
+ '[' 22.04 = 20.04 ']'
+ '[' 22.04 = 18.04 ']'
+ curl -sS https://bootstrap.pypa.io/get-pip.py
+ python3.10
Using pip 25.2 from /tmp/python/tmpwdauhc63/pip.zip/pip (python 3.10)
Looking in indexes: https://pypi.jetson-ai-lab.dev/jp6/cu126, https://pypi.jetson-ai-lab.dev/jp6/cu126
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffffb686eef0>: Failed to establish a new connection: [Errno 113] No route to host')': /jp6/cu126/pip/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffffb686e920>: Failed to establish a new connection: [Errno 113] No route to host')': /jp6/cu126/pip/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffffb686f9d0>: Failed to establish a new connection: [Errno 113] No route to host')': /jp6/cu126/pip/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffffb686fd90>: Failed to establish a new connection: [Errno 113] No route to host')': /jp6/cu126/pip/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffffb686f520>: Failed to establish a new connection: [Errno 113] No route to host')': /jp6/cu126/pip/
ERROR: Could not find a version that satisfies the requirement pip (from versions: none)
ERROR: No matching distribution found for pip
The command '/bin/sh -c $TMP/install.sh' returned a non-zero code: 1
nano packages/cuda/cuda/config.py
pip_path = (
    f"jp{JETPACK_VERSION.major}/{short_version}" if IS_TEGRA
    else f"sbsa/{short_version}" if IS_SBSA
    else f"{DOCKER_ARCH}/{short_version}"
apt_path = pip_path if Version(LSB_RELEASE).major < 24 else f"{pip_path}/{LSB_RELEASE}"
pip_cache = package.copy()
pip_cache['name'] = f'pip_cache:{short_version}'
pip_cache['group'] = 'build'
pip_cache['dockerfile'] = 'Dockerfile.pip'
pip_cache['depends'] = []
pip_cache['test'] = []
pip_cache['build_args'] = {
    'TAR_INDEX_URL': os.environ.get('LOCAL_TAR_INDEX_URL', f"https://apt.{index_host}") + f"/{apt_path}",
    'FALLBACK_TAR_INDEX_URL': f"https://apt.{index_host}/{apt_path}",
    'MULTIARCH_URL': f"https://apt.{index_host}/multiarch",
    'DOWNLOADS_URL': f"https://apt.{index_host}/assets",
    'PIP_INDEX_REPO': os.environ.get('LOCAL_PIP_INDEX_URL', os.environ.get('LOCAL_PIP_INDEX_REPO', f"https://pypi.{index_host}">
    'PIP_TRUSTED_HOSTS': f"{os.environ.get('PIP_UPLOAD_HOST', index_host)}",
    'PIP_EXTRA_INDEX_URL': os.environ.get('PIP_EXTRA_INDEX_URL', f"https://pypi.{index_host}/{pip_path}"),
    'PIP_UPLOAD_REPO': os.environ.get('PIP_UPLOAD_REPO', f"http://{os.environ.get('PIP_UPLOAD_HOST', 'localhost')}/{pip_path}"),
    'PIP_UPLOAD_USER': os.environ.get('PIP_UPLOAD_USER', f"jp{JETPACK_VERSION.major}" if SYSTEM_ARM else 'amd64'),
    'PIP_UPLOAD_PASS': os.environ.get('PIP_UPLOAD_PASS', 'none'),
    'SCP_UPLOAD_URL': os.environ.get('SCP_UPLOAD_URL', f"{os.environ.get('SCP_UPLOAD_HOST', 'localhost:/dist')}/{apt_path}"),
nano packages/build/python/install.sh
# path 1:  Python 3.8-3.10 for JP5/6
# path 2:  Python 3.6 for JP4
# path 3:  Python 3.12 for 24.04
distro=$(lsb_release -rs)
if [ $distro = "24.04" ]; then
   apt-get install -y --no-install-recommends python3-venv
   python3 -m venv --system-site-packages /opt/venv
   source /opt/venv/bin/activate
   curl -sS https://bootstrap.pypa.io/get-pip.py | python${PYTHON_VERSION}
elif [ $distro = "20.04" ]; then
   curl -sS https://bootstrap.pypa.io/pip/3.8/get-pip.py | python3.8
elif [ $distro = "18.04" ]; then
   curl -sS https://bootstrap.pypa.io/pip/3.6/get-pip.py | python3.6
else
fi
nano .env
# These override the default BSP versions and
# change the architecture and OS to build for:
# L4T_VERSION="36.4.0"
# CUDA_VERSION="12.9"
# LSB_RELEASE="24.04"
# WEBPAGE URL for the Jetson Containers repository
# INDEX_HOST='jetson-ai-lab.io' OR jetson-ai-lab.io
# PIP_UPLOAD_REPO
# PIP_UPLOAD_USER
# PIP_UPLOAD_PASS
# SCP_UPLOAD_URL
# SCP_UPLOAD_USER
# SCP_UPLOAD_PASS
## LOCAL HOST CONFIGURATION
# Local PYPI Repository Configuration
# LOCAL_PIP_INDEX_REPO=http://localhost:8080
# PIP_UPLOAD_HOST=localhost:8080
# PIP_UPLOAD_USER=pypi
# PIP_UPLOAD_PASS=pypi
# Local APT Repository Configuration
# NOTE: The host should have the SCP_UPLOAD_USER created with SCP_UPLOAD_PASS creadentials
# LOCAL_TAR_INDEX_URL=http://localhost:8000
# SCP_UPLOAD_HOST=localhost:/dist/apt
# SCP_UPLOAD_USER=jetson
# SCP_UPLOAD_PASS=jetson
After modifying these documents, the download path did not change.
Usually this sounds like website is down error
The instructions are in the README.MD, but I followed the methods found online and still couldn’t change the address.
./jetson-containers/README.md
> [!WARNING]
> [pypi.jetson-ai-lab.dev](https://pypi.jetson-ai-lab.dev) is down. We are improving security and performance. Meanwhile please use [pypi.jetson-ai-lab.io](https://pypi.jetson-ai-lab.io) by setting the enviroment variable `INDEX_HOST=jetson-ai-lab.io` in [.env](https://github.com/dusty-nv/jetson-containers/blob/1ca7d43e6b8a02e1eba10ed298673cd2e518872a/.env#L34) file.
The server is intermittently online and offline. We are checking it to improve the stability.
Understood, but how can I solve the problem now?
Please use this link:
jp6/cu126 index
I have modified the corresponding document, but it does not work.
nano .env
Please refer to my code.
Could you put the commands and log in ``` like:
Put commands and log here
So that we can understand it clearly. The first command is not in a readable format. Would be great if you can update it. We can then follow the steps to replicate the error on developer kit.
It seems like the URL is not updated. Please try this again:
GitHub - dusty-nv/jetson-containers: Machine Learning Containers for NVIDIA Jetson and JetPack-L4T
Warning
pypi.jetson-ai-lab.dev is down. We are improving security and performance. Meanwhile please use pypi.jetson-ai-lab.io by setting the enviroment variable INDEX_HOST=jetson-ai-lab.io in .env file.
Please confirm you set INDEX_HOST correctly.
