SDKM_logs_JetPack_4.6.3_Linux_for_Jetson_Nano_modules_2024-08-18_05-37-54.zip (54.0 KB)
Are you using the devkit or custom board for Jetson Nano?
yes
eMMC or SD module?
emmc
What’s your Jetpack version in use? (JP4.6.3?)
Have you also tried using command to flash the board?
yes, Yes, I have tried and failed
yes
這個問題是在問你用NV devkit或是custom board. 不太確定你回答Yes的意思…
please help dump serial console log during flash failure.
here is result
I wonder if my eMMC is corrupted, and if so, is there any way to fix it?
thanks!
[0033.961] Enabled early print
[0033.963] [L4T TegraBoot] (version u▒▒▒▒8/\▒t@r▒▒'!▒▒w▒▒H;]▒▒▒▒NW▒▒▒M▒P▒▒▒▒{-▒▒f▒▒▒Q▒▒▒▒ ▒Z▒?P▒▒▒N▒c▒~▒▒▒▒▒e▒)a▒▒@9 k_SrS ▒ϳ|(M˓▒▒~▒J▒▒Ջ\▒JM▒e▒▒▒R▒/.▒▒f▒[rx▒▒▒)▒<a▒▒Nˣ;؈I▒▒▒▒▒9T▒▒g▒▒▒B▒▒G▒؉▒m▒▒D ▒▒▒,▒▒|U▒▒ 2▒▒A▒ ▒߮0$ ) [0033.986] Processing in recovery mode [0033.990] A02 Bootrom Patch rev = 1023 [0033.993] Power-up reason: pmc por [0033.997] Established communication link with host [0035.013] NvTbootI2cWrite(): error code 0x00045100 Error while starting write transaction [0035.020] NvTbootI2cDeviceRead(): error code 0x00045001 Error while sending the offset to slave [0035.029] NvTbootI2c: Read failed for slave 0xac, offset 0x00 with error code 0x00045001 [0001.996] Enabled early print [0001.999] [L4T TegraBoot] (version u▒▒▒▒8/\▒t@r▒▒’!▒▒w▒▒H;]▒▒▒▒NW▒▒▒M▒P▒▒▒▒{-▒▒f▒▒▒Q▒▒▒▒ ▒Z▒?P▒▒▒N▒c▒~▒▒▒▒▒e▒)a▒▒@9
2▒▒A▒
▒߮0$ )
[0002.022] Processing in recovery mode
[0002.025] A02 Bootrom Patch rev = 1023
[0002.029] Power-up reason: software reset
[0002.033] Established communication link with host
[0003.049] NvTbootI2cWrite(): error code 0x00045100 Error while starting write transaction
[0003.057] NvTbootI2cDeviceRead(): error code 0x00045001 Error while sending the offset to slave
[0003.066] NvTbootI2c: Read failed for slave 0xac, offset 0x00 with error code 0x00045001
[0002.112] Enabled early print
[0002.115] [L4T TegraBoot] (version u▒▒▒▒8/\▒t@r▒▒'!▒▒w▒▒H;]▒▒▒▒NW▒▒▒M▒P▒▒▒▒{-▒▒f▒▒▒Q▒▒▒▒ ▒Z▒?P▒▒▒N▒c▒~▒▒▒▒▒e▒)a▒▒@9 k_SrS ▒ϳ|(M˓▒▒~▒J▒▒Ջ\▒JM▒e▒▒▒R▒/.▒▒f▒[rx▒▒▒)▒<a▒▒Nˣ;؈I▒▒▒▒▒9T▒▒g▒▒▒B▒▒G▒؉▒m▒▒D ▒▒▒,▒▒|U▒▒ 2▒▒A▒ ▒߮0$ ) [0002.138] Processing in recovery mode [0002.141] A02 Bootrom Patch rev = 1023 [0002.145] Power-up reason: software reset [0002.149] Established communication link with host [0003.164] NvTbootI2cWrite(): error code 0x00045100 Error while starting write transaction [0003.172] NvTbootI2cDeviceRead(): error code 0x00045001 Error while sending the offset to slave [0003.180] NvTbootI2c: Read failed for slave 0xac, offset 0x00 with error code 0x00045001 [0060.248] Enabled early print [0060.250] [L4T TegraBoot] (version u▒▒▒▒8/\▒t@r▒▒’!▒▒w▒▒H;]▒▒▒▒NW▒▒▒M▒P▒▒▒▒{-▒▒f▒▒▒Q▒▒▒▒ ▒Z▒?P▒▒▒N▒c▒~▒▒▒▒▒e▒)a▒▒@9
2▒▒A▒
▒߮0$ )
[0060.273] Processing in recovery mode
[0060.277] A02 Bootrom Patch rev = 1023
[0060.280] Power-up reason: software reset
[0060.284] Established communication link with host
[0061.304] Odmdata from BCT: 0x000a4000
[0061.308] DebugPort= 0x3
[0061.310] SkipQspiOnly= 0x0
[0061.363] BoardId read from EEPROM/NCT: 3448
[0061.367] BoardID = 3448, SKU = 0x2
[0061.394] NvTbootInit_Porg: Setting GPIO_A6 for HDMI …
[0061.399] max77620 setting MBLPD bit
[0061.403] No Battery Present
[0061.405] RamCode = 0
[0061.408] Platform has DDR4 type RAM
[0061.411] max77620 disabling SD1 Remote Sense
[0061.415] Setting DDR voltage to 1125mv
[0061.419] Serial Number of Pmic Max77663: 0x2a1165
[0061.427] Entering ramdump check
[0061.430] Get RamDumpCarveOut = 0x0
[0061.433] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0061.438] Last reboot was clean, booting normally!
[0061.443] Sdram initialization is successful
[0061.447] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0061.453] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0061.459] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0061.465] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0061.471] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0061.477] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0061.483] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0061.489] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0061.505] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0061.511] Platform-DebugCarveout: 0
[0061.514] Downloaded BCT successfully
[0061.790] Downloaded Bootloader successfully
[0061.893] Downloaded rp1 successfully
[0062.000] MAX77620_GPIO5 configured
[0062.003] CPU power rail is up
[0062.006] CPU clock enabled
[0062.010] Performing RAM repair
[0062.013] Updating A64 Warmreset Address to 0x92c002e9
[0062.019] Enable APE clock/reset
[0062.022] Error in NvTbootGetTOSBinaryLength: 0x11 !
[0062.027] Loading Secure OS image failed.
[0062.031] Set NvDecSticky Bits
[0062.034] GSC2 address ff53fffc value c0edbbcc
[0062.041] GSC MC Settings done
[0062.045] Next binary entry address: 0x92c00258
[0062.049] BoardId: 3448
[0062.052] Overriding pmu board id with proc board id
[0062.057] Display board id is not available
[0062.061] Starting CPU & Halting co-processor
[0063.561]
[0063.562] Debug Init done
[0063.566] Marked DTB cacheable
[0063.568] Bootloader DTB loaded at 0x83000400
[0063.573] DeviceTree Init done
[0063.588] Pinmux applied successfully
[0063.592] gicd_base: 0x50041000
[0063.596] gicc_base: 0x50042000
[0063.599] Interrupts Init done
[0063.603] Using base:0x60005090 & irq:208 for tick-timer
[0063.609] Using base:0x60005098 for delay-timer
[0063.613] platform_init_timer: DONE
[0063.616] Timer(tick) Init done
[0063.620] osc freq = 38400 khz
[0063.625]
[0063.626] Welcome to L4T Cboot
[0063.629]
[0063.630] Cboot Version: 00.00.2018.01-t210-acb23272
[0063.635] calling constructors
[0063.638] initializing heap
[0063.640] initializing threads
[0063.643] initializing timers
[0063.646] creating bootstrap completion thread
[0063.651] top of bootstrap2()
[0063.653] CPU: ARM Cortex A57
[0063.656] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0063.661] initializing platform
[0063.702] sdmmc bdev is already initialized
[0063.706] of_register: registering tegra_udc to of_hal
[0063.711] of_register: registering inv20628-driver to of_hal
[0063.717] of_register: registering ads1015-driver to of_hal
[0063.722] of_register: registering lp8557-bl-driver to of_hal
[0063.728] of_register: registering bq2419x_charger to of_hal
[0063.733] of_register: registering bq27441_fuel_gauge to of_hal
[0063.746] gpio framework initialized
[0063.750] of_register: registering tca9539_gpio to of_hal
[0063.755] of_register: registering tca9539_gpio to of_hal
[0063.760] of_register: registering i2c_bus_driver to of_hal
[0063.766] of_register: registering i2c_bus_driver to of_hal
[0063.772] of_register: registering i2c_bus_driver to of_hal
[0063.777] pmic framework initialized
[0063.781] of_register: registering max77620_pmic to of_hal
[0063.786] regulator framework initialized
[0063.790] of_register: registering tps65132_bl_driver to of_hal
[0063.796] initializing target
[0063.802] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0063.811] board ID = D78, board SKU = 2
[0063.818] fixed regulator driver initialized
[0063.839] initializing OF layer
[0063.843] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0063.862] I2C Bus Init done
[0063.865] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0063.876] I2C Bus Init done
[0063.879] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0063.890] I2C Bus Init done
[0063.892] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0063.903] I2C Bus Init done
[0063.906] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0063.917] I2C Bus Init done
[0063.920] of_children_init: Ops found for compatible string maxim,max77620
[0063.931] max77620_init using irq 118
[0063.936] register ‘maxim,max77620’ pmic
[0063.940] gpio_driver_register: register ‘max77620-gpio’ driver
[0063.946] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0063.958] I2C Bus Init done
[0063.961] Applying platform configs
[0063.969] platform-init is not present. Skipping
[0063.973] calling apps_init()
[0063.984] ReadSingle/Multi Operation failed 0xfffffff8 in sdmmc_verify_response at 323
[0063.992] verify response failed 0xfffffff8 in sdmmc_block_io at 1011
[0063.999] block I/O failed 0xfffffff8 in sdmmc_io at 1215
[0064.004] block read failed 0xfffffff8 in sdmmc_bdev_read_block at 143
[0072.614] data_txr_ready is not set to 0 and timed out
[0072.619] data is not ready for transfer 0xfffffff3 in sdmmc_send_command at 117
[0072.626] switch command send failed 0xfffffff3 in sdmmc_send_switch_command at 470
[0072.634] switch cmd send failed 0xfffffff3 in sdmmc_select_access_region at 1301
[0081.249] data line active sw timeout 0xfffffff3 in sdmmc_wait_for_data_line_ready at 1036
[0081.257] Error in command_complete 18002 int_status
[0081.262] Error in command_complete 18000 int_status
[0081.269] ReadSingle/Multi Operation failed 0xfffffff8 in sdmmc_verify_response at 323
[0081.277] verify response failed 0xfffffff8 in sdmmc_block_io at 1011
[0081.283] block I/O failed 0xfffffff8 in sdmmc_io at 1215
[0081.289] block read failed 0xfffffff8 in sdmmc_bdev_read_block at 143
[0081.295] Couldn’t find GPT header
[0081.324] Proceeding to flashing Server
[0081.328] usbdcd_reinit Initialize driver to use already enumerated device
[0081.335] nv3p_priv_usbf_open USB configuration success
[0081.542] Writing GPT partition
[0081.561] Erasing Boot device
[0081.564] device_write_gpt: Erasing boot device sdmmc3_boot
[0081.569] device_write_gpt: failed to erase sdmmc3_boot !
[0081.575] Number of bytes written -20
[0081.578] Written less bytes than expected with error 0x7
[0081.584] Write command failed for GPT partition
Do you have other carrier board to check if this is not an issue on carrier board?
If there is not, then nothing to do here, please RMA this device.
Yes, I tried to replace a baseplate, but it didn’t work, so I suspect that the core may be broken. As for RMA, my equipment has passed the warranty period, so it should not be able to RMA, it seems that this equipment cannot be repaired, thank you for your answer!
