I used the jetson nano B01 and designed carrier board for this with the usb hub chip from [GENESYS].
The USB3.0 is normal,It can use the usb mobile hard disk,but the usb2.0 has some problem. It can’t use it, but sometimes it is ok with the small probability.
the firmware is 4.4DP, thank you.
[ 1.802456] usbcore: registered new interface driver usbhid
[ 1.802459] usbhid: USB HID core driver
[ 1.813660] usbcore: registered new interface driver snd-usb-audio
[ 1.937451] vdd-usb-vbus: disabling
[ 1.937454] vdd-usb-vbus2: disabling
[ 1.937555] vdd-usb-hub-en: disabling
[ 2.081815] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 4.603093] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 4.747016] usb usb1: usb_suspend_both: status 0
[ 5.222487] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 5.338241] usb0: HOST MAC 12:4d:be:9b:d1:5e
[ 5.338479] usb0: MAC 12:4d:be:9b:d1:5f
[ 5.357805] l4tbr0: port 2(usb0) entered blocking state
[ 5.357811] l4tbr0: port 2(usb0) entered disabled state
[ 5.362794] device usb0 entered promiscuous mode
[ 5.370765] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 5.446921] usb 1-2: new high-speed USB device number 3 using tegra-xusb
[ 5.473156] usb 1-2: New USB device found, idVendor=05e3, idProduct=0610
[ 5.473163] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.473167] usb 1-2: Product: USB2.0 Hub
[ 5.473171] usb 1-2: Manufacturer: GenesysLogic
[ 5.474292] hub 1-2:1.0: USB hub found
[ 5.606938] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 5.626916] usb 1-2: usb_suspend_both: status 0
[ 5.626989] usb usb1: usb_suspend_both: status 0
[ 5.754114] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.754121] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.871021] usb usb2: usb_suspend_both: status -16
[ 5.887038] usb usb2: usb_suspend_both: status -16
[ 5.903019] usb usb2: usb_suspend_both: status -16
[ 5.918999] usb usb2: usb_suspend_both: status -16
[ 5.935040] usb usb2: usb_suspend_both: status -16
[ 5.955060] usb usb2: usb_suspend_both: status -16
[ 5.971076] usb usb2: usb_suspend_both: status -16
[ 5.987024] usb usb2: usb_suspend_both: status -16
[ 6.003035] usb usb2: usb_suspend_both: status -16
[ 6.019046] usb usb2: usb_suspend_both: status -16
[ 6.035044] usb usb2: usb_suspend_both: status -16
[ 6.051017] usb usb2: usb_suspend_both: status -16
[ 6.067151] usb usb2: usb_suspend_both: status -16
[ 6.083136] usb usb2: usb_suspend_both: status -16
[ 6.099101] usb usb2: usb_suspend_both: status -16
[ 6.115015] usb usb2: usb_suspend_both: status -16
[ 6.131034] usb usb2: usb_suspend_both: status -16
[ 6.147187] usb usb2: usb_suspend_both: status -16
[ 6.163065] usb usb2: usb_suspend_both: status -16
[ 6.179036] usb usb2: usb_suspend_both: status -16
[ 6.195058] usb usb2: usb_suspend_both: status -16
[ 6.211141] usb usb2: usb_suspend_both: status -16
[ 6.227094] usb usb2: usb_suspend_both: status -16
[ 6.243261] usb usb2: usb_suspend_both: status -16
[ 6.259071] usb usb2: usb_suspend_both: status -16
[ 6.275054] usb usb2: usb_suspend_both: status -16
[ 6.291026] usb usb2: usb_suspend_both: status -16
[ 6.307021] usb usb2: usb_suspend_both: status -16
[ 6.323042] usb usb2: usb_suspend_both: status -16
[ 6.339030] usb usb2: usb_suspend_both: status -16
[ 6.355038] usb usb2: usb_suspend_both: status -16
[ 6.371092] usb usb2: usb_suspend_both: status -16
[ 6.387095] usb usb2: usb_suspend_both: status -16
[ 6.403038] usb usb2: usb_suspend_both: status -16
[ 6.419017] usb usb2: usb_suspend_both: status -16
[ 6.435031] usb usb2: usb_suspend_both: status -16
[ 6.451082] usb usb2: usb_suspend_both: status -16
[ 6.467038] usb usb2: usb_suspend_both: status -16
[ 6.483089] usb usb2: usb_suspend_both: status -16
[ 6.499054] usb usb2: usb_suspend_both: status -16
[ 6.519055] usb usb2: usb_suspend_both: status -16
[ 6.535070] usb usb2: usb_suspend_both: status -16
[ 6.551066] usb usb2: usb_suspend_both: status -16
[ 6.571031] usb usb2: usb_suspend_both: status -16
[ 6.587019] usb usb2: usb_suspend_both: status -16
[ 6.607138] usb usb2: usb_suspend_both: status -16
[ 6.623225] usb usb2: usb_suspend_both: status -16
[ 6.639090] usb usb2: usb_suspend_both: status -16
[ 6.659048] usb usb2: usb_suspend_both: status -16
[ 6.675060] usb usb2: usb_suspend_both: status -16
[ 6.691016] usb usb2: usb_suspend_both: status -16
[ 6.707051] usb usb2: usb_suspend_both: status -16
[ 6.723048] usb usb2: usb_suspend_both: status -16
[ 6.739029] usb usb2: usb_suspend_both: status -16
[ 6.759199] usb usb2: usb_suspend_both: status -16
[ 6.775148] usb usb2: usb_suspend_both: status -16
[ 6.791003] usb usb2: usb_suspend_both: status -16
[ 6.811157] usb usb2: usb_suspend_both: status -16
[ 6.827097] usb usb2: usb_suspend_both: status -16
[ 6.843271] usb usb2: usb_suspend_both: status -16
[ 6.859199] usb usb2: usb_suspend_both: status -16
[ 6.874998] usb usb2: usb_suspend_both: status -16
[ 6.890996] usb usb2: usb_suspend_both: status -16
[ 6.907005] usb usb2: usb_suspend_both: status -16
[ 6.923125] usb usb2: usb_suspend_both: status -16
[ 6.939295] usb usb2: usb_suspend_both: status -16
[ 6.955030] usb usb2: usb_suspend_both: status -16
[ 6.971035] usb usb2: usb_suspend_both: status -16
[ 6.987012] usb usb2: usb_suspend_both: status -16
[ 7.003066] usb usb2: usb_suspend_both: status -16
[ 7.019036] usb usb2: usb_suspend_both: status -16
[ 7.035050] usb usb2: usb_suspend_both: status -16
[ 7.051053] usb usb2: usb_suspend_both: status -16
[ 7.067042] usb usb2: usb_suspend_both: status -16
[ 7.087029] usb usb2: usb_suspend_both: status -16
[ 7.103018] usb usb2: usb_suspend_both: status -16
[ 7.119080] usb usb2: usb_suspend_both: status -16
[ 7.135088] usb usb2: usb_suspend_both: status -16
[ 7.151083] usb usb2: usb_suspend_both: status -16
[ 7.167065] usb usb2: usb_suspend_both: status -16
[ 7.183089] usb usb2: usb_suspend_both: status -16
[ 7.199068] usb usb2: usb_suspend_both: status -16
[ 7.219059] usb usb2: usb_suspend_both: status -16
[ 7.235048] usb usb2: usb_suspend_both: status -16
[ 7.251081] usb usb2: usb_suspend_both: status -16
[ 7.267134] usb usb2: usb_suspend_both: status -16
[ 7.283156] usb usb2: usb_suspend_both: status -16
[ 7.299023] usb usb2: usb_suspend_both: status -16
[ 7.315031] usb usb2: usb_suspend_both: status -16
[ 7.331081] usb usb2: usb_suspend_both: status -16
[ 7.351019] usb usb2: usb_suspend_both: status -16
[ 7.371051] usb usb2: usb_suspend_both: status -16
[ 7.391034] usb usb2: usb_suspend_both: status -16
[ 7.407066] usb usb2: usb_suspend_both: status -16
[ 7.423032] usb usb2: usb_suspend_both: status -16
[ 7.439022] usb usb2: usb_suspend_both: status -16
[ 7.455151] usb usb2: usb_suspend_both: status -16
[ 7.471160] usb usb2: usb_suspend_both: status -16
[ 7.491084] usb usb2: usb_suspend_both: status -16
[ 7.507173] usb usb2: usb_suspend_both: status -16
[ 7.523019] usb usb2: usb_suspend_both: status -16
[ 7.539028] usb usb2: usb_suspend_both: status -16
[ 7.559074] usb usb2: usb_suspend_both: status -16
[ 7.575060] usb usb2: usb_suspend_both: status -16
[ 7.591101] usb usb2: usb_suspend_both: status -16
[ 7.607190] usb usb2: usb_suspend_both: status -16
[ 7.623090] usb usb2: usb_suspend_both: status -16
[ 7.639066] usb usb2: usb_suspend_both: status -16
[ 7.655065] usb usb2: usb_suspend_both: status -16
[ 7.671082] usb usb2: usb_suspend_both: status -16
[ 7.687019] usb usb2: usb_suspend_both: status -16
[ 7.703036] usb usb2: usb_suspend_both: status -16
[ 7.719215] usb usb2: usb_suspend_both: status -16
[ 7.735227] usb usb2: usb_suspend_both: status -16
[ 7.751074] usb usb2: usb_suspend_both: status -16
[ 7.767295] usb usb2: usb_suspend_both: status -16
[ 7.787140] usb usb2: usb_suspend_both: status -16
[ 7.806997] usb usb2: usb_suspend_both: status -16
[ 7.823059] usb usb2: usb_suspend_both: status -16
[ 7.839066] usb usb2: usb_suspend_both: status -16
[ 7.859128] usb usb2: usb_suspend_both: status -16
[ 7.875063] usb usb2: usb_suspend_both: status -16
[ 7.895001] usb usb2: usb_suspend_both: status -16
[ 7.911578] usb usb2: usb_suspend_both: status -16
[ 7.931095] usb usb2: usb_suspend_both: status -16
[ 7.947090] usb usb2: usb_suspend_both: status -16
[ 7.963294] usb usb2: usb_suspend_both: status -16
[ 7.979110] usb usb2: usb_suspend_both: status -16
[ 7.995077] usb usb2: usb_suspend_both: status -16
[ 8.011410] usb usb2: usb_suspend_both: status -16
[ 8.027231] usb usb2: usb_suspend_both: status -16
[ 8.043234] usb usb2: usb_suspend_both: status -16
[ 8.059175] usb usb2: usb_suspend_both: status -16
[ 8.075084] usb usb2: usb_suspend_both: status -16
[ 8.091046] usb usb2: usb_suspend_both: status -16
[ 8.107153] usb usb2: usb_suspend_both: status -16
[ 8.123108] usb usb2: usb_suspend_both: status -16
[ 8.139020] usb usb2: usb_suspend_both: status -16
[ 8.155100] usb usb2: usb_suspend_both: status -16
[ 8.171068] usb usb2: usb_suspend_both: status -16
[ 8.187022] usb usb2: usb_suspend_both: status -16
[ 8.203027] usb usb2: usb_suspend_both: status -16
[ 8.219022] usb usb2: usb_suspend_both: status -16
[ 8.235020] usb usb2: usb_suspend_both: status -16
[ 8.251080] usb usb2: usb_suspend_both: status -16
[ 8.267064] usb usb2: usb_suspend_both: status -16
[ 8.283027] usb usb2: usb_suspend_both: status -16
[ 8.299100] usb usb2: usb_suspend_both: status -16
[ 8.315095] usb usb2: usb_suspend_both: status -16
[ 8.331043] usb usb2: usb_suspend_both: status -16
[ 8.347018] usb usb2: usb_suspend_both: status -16
[ 8.363082] usb usb2: usb_suspend_both: status -16
[ 8.379087] usb usb2: usb_suspend_both: status -16
[ 8.395051] usb usb2: usb_suspend_both: status -16
[ 8.411060] usb usb2: usb_suspend_both: status -16
[ 8.427094] usb usb2: usb_suspend_both: status -16
[ 8.443357] usb usb2: usb_suspend_both: status -16
[ 8.459103] usb usb2: usb_suspend_both: status -16
[ 8.475059] usb usb2: usb_suspend_both: status -16
[ 8.491047] usb usb2: usb_suspend_both: status -16
[ 8.511058] usb usb2: usb_suspend_both: status -16
[ 8.531036] usb usb2: usb_suspend_both: status -16
[ 8.547006] usb usb2: usb_suspend_both: status -16
[ 8.563026] usb usb2: usb_suspend_both: status -16
[ 8.579035] usb usb2: usb_suspend_both: status -16
[ 8.595027] usb usb2: usb_suspend_both: status -16
[ 8.611008] usb usb2: usb_suspend_both: status -16
[ 8.627010] usb usb2: usb_suspend_both: status -16
[ 8.643020] usb usb2: usb_suspend_both: status -16
[ 8.659017] usb usb2: usb_suspend_both: status -16
[ 8.675003] usb usb2: usb_suspend_both: status -16
[ 8.691015] usb usb2: usb_suspend_both: status -16
[ 8.706986] usb usb2: usb_suspend_both: status -16
[ 8.723041] usb usb2: usb_suspend_both: status -16
[ 8.739003] usb usb2: usb_suspend_both: status -16
[ 8.755003] usb usb2: usb_suspend_both: status -16
[ 8.771071] usb usb2: usb_suspend_both: status -16
[ 8.787037] usb usb2: usb_suspend_both: status -16
[ 8.803045] usb usb2: usb_suspend_both: status -16
[ 8.819034] usb usb2: usb_suspend_both: status -16
[ 8.835009] usb usb2: usb_suspend_both: status -16
[ 8.850995] usb usb2: usb_suspend_both: status -16
[ 8.867051] usb usb2: usb_suspend_both: status -16
[ 8.883001] usb usb2: usb_suspend_both: status -16
[ 8.899006] usb usb2: usb_suspend_both: status -16
[ 8.915014] usb usb2: usb_suspend_both: status -16
[ 8.931026] usb usb2: usb_suspend_both: status -16
[ 8.947020] usb usb2: usb_suspend_both: status -16
[ 8.963015] usb usb2: usb_suspend_both: status -16
[ 8.979065] usb usb2: usb_suspend_both: status -16
[ 8.995043] usb usb2: usb_suspend_both: status -16
[ 9.011071] usb usb2: usb_suspend_both: status -16
[ 9.027025] usb usb2: usb_suspend_both: status -16
[ 9.043021] usb usb2: usb_suspend_both: status -16
[ 9.059020] usb usb2: usb_suspend_both: status -16
[ 9.075058] usb usb2: usb_suspend_both: status -16
[ 9.091099] usb usb2: usb_suspend_both: status -16
[ 9.107040] usb usb2: usb_suspend_both: status -16
[ 9.123921] usb usb2: usb_suspend_both: status -16
[ 9.139089] usb usb2: usb_suspend_both: status -16
[ 9.155040] usb usb2: usb_suspend_both: status -16
[ 9.171056] usb usb2: usb_suspend_both: status -16
[ 9.187179] usb usb2: usb_suspend_both: status -16
[ 9.203146] usb usb2: usb_suspend_both: status -16
[ 9.219049] usb usb2: usb_suspend_both: status -16
[ 9.235048] usb usb2: usb_suspend_both: status -16
[ 9.251116] usb usb2: usb_suspend_both: status -16
[ 9.267005] usb usb2: usb_suspend_both: status -16
[ 9.283101] usb usb2: usb_suspend_both: status -16
[ 9.299057] usb usb2: usb_suspend_both: status -16
[ 9.315044] usb usb2: usb_suspend_both: status -16
[ 9.331106] usb usb2: usb_suspend_both: status -16
[ 9.347148] usb usb2: usb_suspend_both: status -16
[ 9.363091] usb usb2: usb_suspend_both: status -16
[ 9.379091] usb usb2: usb_suspend_both: status -16
[ 9.395053] usb usb2: usb_suspend_both: status -16
[ 9.411087] usb usb2: usb_suspend_both: status -16
[ 9.427121] usb usb2: usb_suspend_both: status -16
[ 9.443087] usb usb2: usb_suspend_both: status -16
[ 9.459033] usb usb2: usb_suspend_both: status -16
[ 9.475089] usb usb2: usb_suspend_both: status -16
[ 9.491072] usb usb2: usb_suspend_both: status -16
[ 9.507037] usb usb2: usb_suspend_both: status -16
[ 9.523060] usb usb2: usb_suspend_both: status -16
[ 9.539069] usb usb2: usb_suspend_both: status -16
[ 9.559079] usb usb2: usb_suspend_both: status -16
[ 9.575081] usb usb2: usb_suspend_both: status -16
[ 9.591052] usb usb2: usb_suspend_both: status -16
[ 9.607042] usb usb2: usb_suspend_both: status -16
[ 9.623032] usb usb2: usb_suspend_both: status -16
[ 9.639033] usb usb2: usb_suspend_both: status -16
[ 9.655035] usb usb2: usb_suspend_both: status -16
[ 9.671028] usb usb2: usb_suspend_both: status -16
[ 9.687053] usb usb2: usb_suspend_both: status -16
[ 9.703046] usb usb2: usb_suspend_both: status -16
[ 9.719034] usb usb2: usb_suspend_both: status -16
[ 9.735033] usb usb2: usb_suspend_both: status -16
[ 9.751034] usb usb2: usb_suspend_both: status -16
[ 9.767015] usb usb2: usb_suspend_both: status -16
[ 9.783043] usb usb2: usb_suspend_both: status -16
[ 9.799043] usb usb2: usb_suspend_both: status -16
[ 9.815029] usb usb2: usb_suspend_both: status -16
[ 9.831048] usb usb2: usb_suspend_both: status -16
[ 9.847351] usb usb2: usb_suspend_both: status -16
[ 9.863020] usb usb2: usb_suspend_both: status -16
[ 9.879110] usb usb2: usb_suspend_both: status -16
[ 9.895151] usb usb2: usb_suspend_both: status -16
[ 9.911083] usb usb2: usb_suspend_both: status -16
[ 9.927106] usb usb2: usb_suspend_both: status -16
[ 9.943090] usb usb2: usb_suspend_both: status -16
[ 9.963073] usb usb2: usb_suspend_both: status -16
[ 9.983040] usb usb2: usb_suspend_both: status -16
[ 9.999058] usb usb2: usb_suspend_both: status -16
[ 10.015049] usb usb2: usb_suspend_both: status -16
[ 10.033122] usb usb2: usb_suspend_both: status -16
[ 10.047090] usb usb2: usb_suspend_both: status -16
[ 10.063216] usb usb2: usb_suspend_both: status -16
[ 10.079022] usb usb2: usb_suspend_both: status -16
[ 10.095160] usb usb2: usb_suspend_both: status -16
[ 10.111190] usb usb2: usb_suspend_both: status -16
[ 10.131156] usb usb2: usb_suspend_both: status -16
[ 10.147006] usb usb2: usb_suspend_both: status -16
[ 10.163036] usb usb2: usb_suspend_both: status -16
[ 10.179029] usb usb2: usb_suspend_both: status -16
[ 10.195213] usb usb2: usb_suspend_both: status -16
[ 10.211140] usb usb2: usb_suspend_both: status -16
[ 10.227050] usb usb2: usb_suspend_both: status -16
[ 10.243029] usb usb2: usb_suspend_both: status -16
[ 10.259054] usb usb2: usb_suspend_both: status -16
[ 10.277023] usb usb2: usb_suspend_both: status -16
[ 10.291072] usb usb2: usb_suspend_both: status -16
[ 10.311039] usb usb2: usb_suspend_both: status -16
[ 10.327178] usb usb2: usb_suspend_both: status -16
[ 10.343073] usb usb2: usb_suspend_both: status -16
[ 10.359041] usb usb2: usb_suspend_both: status -16
[ 10.379092] usb usb2: usb_suspend_both: status -16
[ 10.395036] usb usb2: usb_suspend_both: status -16
[ 10.411183] usb usb2: usb_suspend_both: status -16
[ 10.431030] usb usb2: usb_suspend_both: status -16
[ 10.447020] usb usb2: usb_suspend_both: status -16
[ 10.463021] usb usb2: usb_suspend_both: status -16
[ 10.479396] usb usb2: usb_suspend_both: status -16
[ 10.495055] usb usb2: usb_suspend_both: status -16
[ 10.511023] usb usb2: usb_suspend_both: status -16
[ 10.527310] usb usb2: usb_suspend_both: status -16
[ 10.543045] usb usb2: usb_suspend_both: status -16
[ 10.559027] usb usb2: usb_suspend_both: status -16
[ 10.575082] usb usb2: usb_suspend_both: status -16
[ 10.591069] usb usb2: usb_suspend_both: status -16
[ 10.607057] usb usb2: usb_suspend_both: status -16
[ 10.627048] usb usb2: usb_suspend_both: status -16
[ 10.643018] usb usb2: usb_suspend_both: status -16
[ 10.659133] usb usb2: usb_suspend_both: status -16
[ 10.675061] usb usb2: usb_suspend_both: status -16
[ 10.691071] usb usb2: usb_suspend_both: status -16
[ 10.707150] usb usb2: usb_suspend_both: status -16
[ 10.723077] usb usb2: usb_suspend_both: status -16
[ 10.739060] usb usb2: usb_suspend_both: status -16
[ 10.755131] usb usb2: usb_suspend_both: status -16
[ 10.771073] usb usb2: usb_suspend_both: status -16
[ 10.787079] usb usb2: usb_suspend_both: status -16
[ 10.803072] usb usb2: usb_suspend_both: status -16
[ 10.819219] usb usb2: usb_suspend_both: status -16
[ 10.835084] usb usb2: usb_suspend_both: status -16
[ 10.851078] usb usb2: usb_suspend_both: status -16
[ 10.867043] usb usb2: usb_suspend_both: status -16
[ 10.883072] usb usb2: usb_suspend_both: status -16
[ 10.903081] usb usb2: usb_suspend_both: status -16
[ 10.919074] usb usb2: usb_suspend_both: status -16
[ 10.935082] usb usb2: usb_suspend_both: status -16
[ 10.951090] usb usb2: usb_suspend_both: status -16
[ 10.971095] usb usb2: usb_suspend_both: status -16
[ 10.987041] usb usb2: usb_suspend_both: status -16
[ 11.007032] usb usb2: usb_suspend_both: status -16
[ 11.023066] usb usb2: usb_suspend_both: status -16
[ 11.039032] usb usb2: usb_suspend_both: status -16
[ 11.055064] usb usb2: usb_suspend_both: status -16
[ 11.071119] usb usb2: usb_suspend_both: status -16
[ 11.087074] usb usb2: usb_suspend_both: status -16
[ 11.107077] usb usb2: usb_suspend_both: status -16
[ 11.123063] usb usb2: usb_suspend_both: status -16
[ 11.143019] usb usb2: usb_suspend_both: status -16
[ 11.163008] usb usb2: usb_suspend_both: status -16
[ 11.179014] usb usb2: usb_suspend_both: status -16
[ 11.195030] usb usb2: usb_suspend_both: status -16
[ 11.211067] usb usb2: usb_suspend_both: status -16
[ 11.227035] usb usb2: usb_suspend_both: status -16
[ 11.243063] usb usb2: usb_suspend_both: status -16
[ 11.259094] usb usb2: usb_suspend_both: status -16
[ 11.275263] usb usb2: usb_suspend_both: status -16
[ 11.291837] usb usb2: usb_suspend_both: status -16
[ 11.307035] usb usb2: usb_suspend_both: status -16
[ 11.323067] usb usb2: usb_suspend_both: status -16
[ 11.339067] usb usb2: usb_suspend_both: status -16
[ 11.355082] usb usb2: usb_suspend_both: status -16
[ 11.371046] usb usb2: usb_suspend_both: status -16
[ 11.387011] usb usb2: usb_suspend_both: status -16
[ 11.403029] usb usb2: usb_suspend_both: status -16
[ 11.419006] usb usb2: usb_suspend_both: status -16
[ 11.435006] usb usb2: usb_suspend_both: status -16
[ 11.451086] usb usb2: usb_suspend_both: status -16
[ 11.467129] usb usb2: usb_suspend_both: status -16
[ 11.483086] usb usb2: usb_suspend_both: status -16
[ 11.499042] usb usb2: usb_suspend_both: status -16
[ 11.515003] usb usb2: usb_suspend_both: status -16
[ 11.531126] usb usb2: usb_suspend_both: status -16
[ 11.547008] usb usb2: usb_suspend_both: status -16
[ 11.563147] usb usb2: usb_suspend_both: status -16
[ 11.579285] usb usb2: usb_suspend_both: status -16
[ 11.595031] usb usb2: usb_suspend_both: status -16
[ 11.611156] usb usb2: usb_suspend_both: status -16
[ 11.627018] usb usb2: usb_suspend_both: status -16
[ 11.643113] usb usb2: usb_suspend_both: status -16
[ 11.659076] usb usb2: usb_suspend_both: status -16
[ 11.675017] usb usb2: usb_suspend_both: status -16
[ 11.691043] usb usb2: usb_suspend_both: status -16
[ 11.707094] usb usb2: usb_suspend_both: status -16
[ 11.723021] usb usb2: usb_suspend_both: status -16
[ 11.739023] usb usb2: usb_suspend_both: status -16
[ 11.755037] usb usb2: usb_suspend_both: status -16
[ 11.771025] usb usb2: usb_suspend_both: status -16
[ 11.787819] usb usb2: usb_suspend_both: status -16
[ 11.803032] usb usb2: usb_suspend_both: status -16
[ 11.819121] usb usb2: usb_suspend_both: status -16
[ 11.835129] usb usb2: usb_suspend_both: status -16
[ 11.851068] usb usb2: usb_suspend_both: status -16
[ 11.867014] usb usb2: usb_suspend_both: status -16
[ 11.883051] usb usb2: usb_suspend_both: status -16
[ 11.899032] usb usb2: usb_suspend_both: status -16
[ 11.915045] usb usb2: usb_suspend_both: status -16
[ 11.931033] usb usb2: usb_suspend_both: status -16
[ 11.947048] usb usb2: usb_suspend_both: status -16
[ 11.963030] usb usb2: usb_suspend_both: status -16
[ 11.979054] usb usb2: usb_suspend_both: status -16
[ 11.995069] usb usb2: usb_suspend_both: status -16
[ 12.011081] usb usb2: usb_suspend_both: status -16
[ 12.027031] usb usb2: usb_suspend_both: status -16
[ 12.043030] usb usb2: usb_suspend_both: status -16
[ 12.059045] usb usb2: usb_suspend_both: status -16
[ 12.075050] usb usb2: usb_suspend_both: status -16
[ 12.091027] usb usb2: usb_suspend_both: status -16
[ 12.107030] usb usb2: usb_suspend_both: status -16
[ 12.123042] usb usb2: usb_suspend_both: status -16
[ 12.139046] usb usb2: usb_suspend_both: status -16
[ 12.155009] usb usb2: usb_suspend_both: status -16
[ 12.171021] usb usb2: usb_suspend_both: status -16
[ 12.187035] usb usb2: usb_suspend_both: status -16
[ 12.203051] usb usb2: usb_suspend_both: status -16
[ 12.219046] usb usb2: usb_suspend_both: status -16
[ 12.235007] usb usb2: usb_suspend_both: status -16
[ 12.251023] usb usb2: usb_suspend_both: status -16
[ 12.267078] usb usb2: usb_suspend_both: status -16
[ 12.283026] usb usb2: usb_suspend_both: status -16
[ 12.299036] usb usb2: usb_suspend_both: status -16
[ 12.315022] usb usb2: usb_suspend_both: status -16
[ 12.331021] usb usb2: usb_suspend_both: status -16
[ 12.347023] usb usb2: usb_suspend_both: status -16
[ 12.363095] usb usb2: usb_suspend_both: status -16
[ 12.379112] usb usb2: usb_suspend_both: status -16
[ 12.395046] usb usb2: usb_suspend_both: status -16
[ 12.411081] usb usb2: usb_suspend_both: status -16
[ 12.427142] usb usb2: usb_suspend_both: status -16
[ 12.443207] usb usb2: usb_suspend_both: status -16
[ 12.459153] usb usb2: usb_suspend_both: status -16
[ 12.475030] usb usb2: usb_suspend_both: status -16
[ 12.491041] usb usb2: usb_suspend_both: status -16
[ 12.507144] usb usb2: usb_suspend_both: status -16
[ 12.523049] usb usb2: usb_suspend_both: status -16
[ 12.539036] usb usb2: usb_suspend_both: status -16
[ 12.555201] usb usb2: usb_suspend_both: status -16
[ 12.571031] usb usb2: usb_suspend_both: status -16
[ 12.587034] usb usb2: usb_suspend_both: status -16
[ 12.603047] usb usb2: usb_suspend_both: status -16
[ 12.619038] usb usb2: usb_suspend_both: status -16
[ 12.635035] usb usb2: usb_suspend_both: status -16
[ 12.651043] usb usb2: usb_suspend_both: status -16
[ 12.667048] usb usb2: usb_suspend_both: status -16
[ 12.683009] usb usb2: usb_suspend_both: status -16
[ 12.699044] usb usb2: usb_suspend_both: status -16
[ 12.715050] usb usb2: usb_suspend_both: status -16
[ 12.731042] usb usb2: usb_suspend_both: status -16
[ 12.747068] usb usb2: usb_suspend_both: status -16
[ 12.763049] usb usb2: usb_suspend_both: status -16
[ 12.779029] usb usb2: usb_suspend_both: status -16
[ 12.795028] usb usb2: usb_suspend_both: status -16
[ 12.811032] usb usb2: usb_suspend_both: status -16
[ 12.827048] usb usb2: usb_suspend_both: status -16
[ 12.843041] usb usb2: usb_suspend_both: status -16
[ 12.859017] usb usb2: usb_suspend_both: status -16
[ 12.875014] usb usb2: usb_suspend_both: status -16
[ 12.891033] usb usb2: usb_suspend_both: status -16
[ 12.907020] usb usb2: usb_suspend_both: status -16
[ 12.923040] usb usb2: usb_suspend_both: status -16
[ 12.939041] usb usb2: usb_suspend_both: status -16
[ 12.955091] usb usb2: usb_suspend_both: status -16
[ 12.971023] usb usb2: usb_suspend_both: status -16
[ 12.987049] usb usb2: usb_suspend_both: status -16
[ 13.003120] usb usb2: usb_suspend_both: status -16
[ 13.019029] usb usb2: usb_suspend_both: status -16
[ 13.035036] usb usb2: usb_suspend_both: status -16
[ 13.051032] usb usb2: usb_suspend_both: status -16
[ 13.067062] usb usb2: usb_suspend_both: status -16
[ 13.083008] usb usb2: usb_suspend_both: status -16
[ 13.098995] usb usb2: usb_suspend_both: status -16
[ 13.115063] usb usb2: usb_suspend_both: status -16
[ 13.131302] usb usb2: usb_suspend_both: status -16
[ 13.147016] usb usb2: usb_suspend_both: status -16
[ 13.163019] usb usb2: usb_suspend_both: status -16
[ 13.179383] usb usb2: usb_suspend_both: status -16
[ 13.195073] usb usb2: usb_suspend_both: status -16
[ 13.211050] usb usb2: usb_suspend_both: status -16
[ 13.227097] usb usb2: usb_suspend_both: status -16
[ 13.243148] usb usb2: usb_suspend_both: status -16
[ 13.259066] usb usb2: usb_suspend_both: status -16
[ 13.275045] usb usb2: usb_suspend_both: status -16
[ 13.291044] usb usb2: usb_suspend_both: status -16
[ 13.307023] usb usb2: usb_suspend_both: status -16
[ 13.323056] usb usb2: usb_suspend_both: status -16
[ 13.339049] usb usb2: usb_suspend_both: status -16
[ 13.355100] usb usb2: usb_suspend_both: status -16
[ 13.371049] usb usb2: usb_suspend_both: status -16
[ 13.387034] usb usb2: usb_suspend_both: status -16
[ 13.403046] usb usb2: usb_suspend_both: status -16
[ 13.419037] usb usb2: usb_suspend_both: status -16
[ 13.435210] usb usb2: usb_suspend_both: status -16
[ 13.451064] usb usb2: usb_suspend_both: status -16
[ 13.467050] usb usb2: usb_suspend_both: status -16
[ 13.483216] usb usb2: usb_suspend_both: status -16
[ 13.500078] usb usb2: usb_suspend_both: status -16
[ 13.515003] usb usb2: usb_suspend_both: status -16
[ 13.531007] usb usb2: usb_suspend_both: status -16
[ 13.547037] usb usb2: usb_suspend_both: status -16
[ 13.563059] usb usb2: usb_suspend_both: status -16
[ 13.579055] usb usb2: usb_suspend_both: status -16
[ 13.595718] usb usb2: usb_suspend_both: status -16
[ 13.611048] usb usb2: usb_suspend_both: status -16
[ 13.627205] usb usb2: usb_suspend_both: status -16
[ 13.643017] usb usb2: usb_suspend_both: status -16
[ 13.659065] usb usb2: usb_suspend_both: status -16
[ 13.675018] usb usb2: usb_suspend_both: status -16
[ 13.691024] usb usb2: usb_suspend_both: status -16
[ 13.707034] usb usb2: usb_suspend_both: status -16
[ 13.723027] usb usb2: usb_suspend_both: status -16
[ 13.739028] usb usb2: usb_suspend_both: status -16
[ 13.755166] usb usb2: usb_suspend_both: status -16
[ 13.771048] usb usb2: usb_suspend_both: status -16
[ 13.787096] usb usb2: usb_suspend_both: status -16
[ 13.803035] usb usb2: usb_suspend_both: status -16
[ 13.819021] usb usb2: usb_suspend_both: status -16
[ 13.835140] usb usb2: usb_suspend_both: status -16
[ 13.851024] usb usb2: usb_suspend_both: status -16
[ 13.867029] usb usb2: usb_suspend_both: status -16
[ 13.884360] usb usb2: usb_suspend_both: status -16
[ 13.899040] usb usb2: usb_suspend_both: status -16
[ 13.915031] usb usb2: usb_suspend_both: status -16
[ 13.931030] usb usb2: usb_suspend_both: status -16
[ 13.947056] usb usb2: usb_suspend_both: status -16
[ 13.963018] usb usb2: usb_suspend_both: status -16
[ 13.979031] usb usb2: usb_suspend_both: status -16
[ 13.995419] usb usb2: usb_suspend_both: status -16
[ 14.011210] usb usb2: usb_suspend_both: status -16
[ 14.027083] usb usb2: usb_suspend_both: status -16
[ 14.043056] usb usb2: usb_suspend_both: status -16
[ 14.059051] usb usb2: usb_suspend_both: status -16
[ 14.075028] usb usb2: usb_suspend_both: status -16
[ 14.091031] usb usb2: usb_suspend_both: status -16
[ 14.107054] usb usb2: usb_suspend_both: status -16
[ 14.123019] usb usb2: usb_suspend_both: status -16
[ 14.139053] usb usb2: usb_suspend_both: status -16
[ 14.155033] usb usb2: usb_suspend_both: status -16
[ 14.171032] usb usb2: usb_suspend_both: status -16
[ 14.187023] usb usb2: usb_suspend_both: status -16
[ 14.203075] usb usb2: usb_suspend_both: status -16
[ 14.219174] usb usb2: usb_suspend_both: status -16
[ 14.235034] usb usb2: usb_suspend_both: status -16
[ 14.255233] usb usb2: usb_suspend_both: status -16
[ 14.271026] usb usb2: usb_suspend_both: status -16
[ 14.287273] usb usb2: usb_suspend_both: status -16
[ 14.303433] usb usb2: usb_suspend_both: status -16
[ 14.319468] usb usb2: usb_suspend_both: status -16
[ 14.338769] usb usb2: usb_suspend_both: status -16
[ 14.355053] usb usb2: usb_suspend_both: status -16
[ 14.371336] usb usb2: usb_suspend_both: status -16
[ 14.387381] usb usb2: usb_suspend_both: status -16
[ 14.403399] usb usb2: usb_suspend_both: status -16
[ 14.419033] usb usb2: usb_suspend_both: status -16
[ 14.435044] usb usb2: usb_suspend_both: status -16
[ 14.451025] usb usb2: usb_suspend_both: status -16
[ 14.467035] usb usb2: usb_suspend_both: status -16
[ 14.483038] usb usb2: usb_suspend_both: status -16
[ 14.499043] usb usb2: usb_suspend_both: status -16
[ 14.515163] usb usb2: usb_suspend_both: status -16
[ 14.531045] usb usb2: usb_suspend_both: status -16
[ 14.547024] usb usb2: usb_suspend_both: status -16
[ 14.563051] usb usb2: usb_suspend_both: status -16
[ 14.579026] usb usb2: usb_suspend_both: status -16
[ 14.595025] usb usb2: usb_suspend_both: status -16
[ 14.611080] usb usb2: usb_suspend_both: status -16
[ 14.627054] usb usb2: usb_suspend_both: status -16
[ 14.643041] usb usb2: usb_suspend_both: status -16
[ 14.659047] usb usb2: usb_suspend_both: status -16
[ 14.675078] usb usb2: usb_suspend_both: status -16
[ 14.691310] usb usb2: usb_suspend_both: status -16
[ 14.707091] usb usb2: usb_suspend_both: status -16
[ 14.723020] usb usb2: usb_suspend_both: status -16
[ 14.739401] usb usb2: usb_suspend_both: status -16
[ 14.755024] usb usb2: usb_suspend_both: status -16
[ 14.771028] usb usb2: usb_suspend_both: status -16
[ 14.787062] usb usb2: usb_suspend_both: status -16
[ 14.803148] usb usb2: usb_suspend_both: status -16
[ 14.819018] usb usb2: usb_suspend_both: status -16
[ 14.835901] usb usb2: usb_suspend_both: status -16
[ 14.851099] usb usb2: usb_suspend_both: status -16
[ 14.867124] usb usb2: usb_suspend_both: status -16
[ 14.883024] usb usb2: usb_suspend_both: status -16
[ 14.899043] usb usb2: usb_suspend_both: status -16
[ 14.915049] usb usb2: usb_suspend_both: status -16
[ 14.931041] usb usb2: usb_suspend_both: status -16
[ 14.947070] usb usb2: usb_suspend_both: status -16
[ 14.963026] usb usb2: usb_suspend_both: status -16
[ 14.979034] usb usb2: usb_suspend_both: status -16
[ 14.995025] usb usb2: usb_suspend_both: status -16
[ 15.011016] usb usb2: usb_suspend_both: status -16
[ 15.027026] usb usb2: usb_suspend_both: status -16
[ 15.043018] usb usb2: usb_suspend_both: status -16
[ 15.059020] usb usb2: usb_suspend_both: status -16
[ 15.075023] usb usb2: usb_suspend_both: status -16
[ 15.094569] usb usb2: usb_suspend_both: status -16
[ 15.107024] usb usb2: usb_suspend_both: status -16
[ 15.123023] usb usb2: usb_suspend_both: status -16
[ 15.139032] usb usb2: usb_suspend_both: status -16
[ 15.155062] usb usb2: usb_suspend_both: status -16
[ 15.171032] usb usb2: usb_suspend_both: status -16
[ 15.187029] usb usb2: usb_suspend_both: status -16
[ 15.203109] usb usb2: usb_suspend_both: status -16
[ 15.219027] usb usb2: usb_suspend_both: status -16
[ 15.235040] usb usb2: usb_suspend_both: status -16
[ 15.251040] usb usb2: usb_suspend_both: status -16
[ 15.267055] usb usb2: usb_suspend_both: status -16
[ 15.283029] usb usb2: usb_suspend_both: status -16
[ 15.299056] usb usb2: usb_suspend_both: status -16
[ 15.315076] usb usb2: usb_suspend_both: status -16
[ 15.331045] usb usb2: usb_suspend_both: status -16
[ 15.347063] usb usb2: usb_suspend_both: status -16
[ 15.363154] usb usb2: usb_suspend_both: status -16
[ 15.379018] usb usb2: usb_suspend_both: status -16
[ 15.395072] usb usb2: usb_suspend_both: status -16
[ 15.411018] usb usb2: usb_suspend_both: status -16
[ 15.427037] usb usb2: usb_suspend_both: status -16
[ 15.443039] usb usb2: usb_suspend_both: status -16
[ 15.459012] usb usb2: usb_suspend_both: status -16
[ 15.475016] usb usb2: usb_suspend_both: status -16
[ 15.491010] usb usb2: usb_suspend_both: status -16
[ 15.507085] usb usb2: usb_suspend_both: status -16
[ 15.523017] usb usb2: usb_suspend_both: status -16
[ 15.539062] usb usb2: usb_suspend_both: status -16
[ 15.555064] usb usb2: usb_suspend_both: status -16
[ 15.571066] usb usb2: usb_suspend_both: status -16
[ 15.587276] usb usb2: usb_suspend_both: status -16
[ 15.603075] usb usb2: usb_suspend_both: status -16
[ 15.619020] usb usb2: usb_suspend_both: status -16
[ 15.635034] usb usb2: usb_suspend_both: status -16
[ 15.651033] usb usb2: usb_suspend_both: status -16
[ 15.667223] usb usb2: usb_suspend_both: status -16
[ 15.683062] usb usb2: usb_suspend_both: status -16
[ 15.699047] usb usb2: usb_suspend_both: status -16
[ 15.715086] usb usb2: usb_suspend_both: status -16
[ 15.731079] usb usb2: usb_suspend_both: status -16
[ 15.747099] usb usb2: usb_suspend_both: status -16
[ 15.763052] usb usb2: usb_suspend_both: status -16
[ 15.779128] usb usb2: usb_suspend_both: status -16
[ 15.795045] usb usb2: usb_suspend_both: status -16
[ 15.811032] usb usb2: usb_suspend_both: status -16
[ 15.827024] usb usb2: usb_suspend_both: status -16
[ 15.843033] usb usb2: usb_suspend_both: status -16
[ 15.859047] usb usb2: usb_suspend_both: status -16
[ 15.875013] usb usb2: usb_suspend_both: status -16
[ 15.891017] usb usb2: usb_suspend_both: status -16
[ 15.907012] usb usb2: usb_suspend_both: status -16
[ 15.923023] usb usb2: usb_suspend_both: status -16
[ 15.939052] usb usb2: usb_suspend_both: status -16
[ 15.955027] usb usb2: usb_suspend_both: status -16
[ 15.971053] usb usb2: usb_suspend_both: status -16
[ 15.987017] usb usb2: usb_suspend_both: status -16
[ 16.003012] usb usb2: usb_suspend_both: status -16
[ 16.019056] usb usb2: usb_suspend_both: status -16
[ 16.035066] usb usb2: usb_suspend_both: status -16
[ 16.051018] usb usb2: usb_suspend_both: status -16
[ 16.067109] usb usb2: usb_suspend_both: status -16
[ 16.083030] usb usb2: usb_suspend_both: status -16
[ 16.099078] usb usb2: usb_suspend_both: status -16
[ 16.115012] usb usb2: usb_suspend_both: status -16
[ 16.131074] usb usb2: usb_suspend_both: status -16
[ 16.147014] usb usb2: usb_suspend_both: status -16
[ 16.163045] usb usb2: usb_suspend_both: status -16
[ 16.179018] usb usb2: usb_suspend_both: status -16
[ 16.195022] usb usb2: usb_suspend_both: status -16
[ 16.211023] usb usb2: usb_suspend_both: status -16
[ 16.227019] usb usb2: usb_suspend_both: status -16
[ 16.243031] usb usb2: usb_suspend_both: status -16
[ 16.259013] usb usb2: usb_suspend_both: status -16
[ 16.275026] usb usb2: usb_suspend_both: status -16
[ 16.291047] usb usb2: usb_suspend_both: status -16
[ 16.306998] usb usb2: usb_suspend_both: status -16
[ 16.322997] usb usb2: usb_suspend_both: status -16
[ 16.338994] usb usb2: usb_suspend_both: status -16
[ 16.355005] usb usb2: usb_suspend_both: status -16
[ 16.371008] usb usb2: usb_suspend_both: status -16
[ 16.387038] usb usb2: usb_suspend_both: status -16
[ 16.403053] usb usb2: usb_suspend_both: status -16
[ 16.419000] usb usb2: usb_suspend_both: status -16
[ 16.435015] usb usb2: usb_suspend_both: status -16
[ 16.451014] usb usb2: usb_suspend_both: status -16
[ 16.467020] usb usb2: usb_suspend_both: status -16
[ 16.483028] usb usb2: usb_suspend_both: status -16
[ 16.499005] usb usb2: usb_suspend_both: status -16
[ 16.515019] usb usb2: usb_suspend_both: status -16
[ 16.531007] usb usb2: usb_suspend_both: status -16
[ 16.547031] usb usb2: usb_suspend_both: status -16
[ 16.563016] usb usb2: usb_suspend_both: status -16
[ 16.579021] usb usb2: usb_suspend_both: status -16
[ 16.595004] usb usb2: usb_suspend_both: status -16
[ 16.611015] usb usb2: usb_suspend_both: status -16
[ 16.627025] usb usb2: usb_suspend_both: status -16
[ 16.643007] usb usb2: usb_suspend_both: status -16
[ 16.659003] usb usb2: usb_suspend_both: status -16
[ 16.675026] usb usb2: usb_suspend_both: status -16
[ 16.691026] usb usb2: usb_suspend_both: status -16
[ 16.707025] usb usb2: usb_suspend_both: status -16
[ 16.723045] usb usb2: usb_suspend_both: status -16
[ 16.739025] usb usb2: usb_suspend_both: status -16
[ 16.755014] usb usb2: usb_suspend_both: status -16
[ 16.771027] usb usb2: usb_suspend_both: status -16
[ 16.787055] usb usb2: usb_suspend_both: status -16
[ 16.803095] usb usb2: usb_suspend_both: status -16
[ 16.819097] usb usb2: usb_suspend_both: status -16
[ 16.835040] usb usb2: usb_suspend_both: status -16
[ 16.851019] usb usb2: usb_suspend_both: status -16
[ 16.867036] usb usb2: usb_suspend_both: status -16
[ 16.883051] usb usb2: usb_suspend_both: status -16
[ 16.899012] usb usb2: usb_suspend_both: status -16
[ 16.915040] usb usb2: usb_suspend_both: status -16
[ 16.931052] usb usb2: usb_suspend_both: status -16
[ 16.947044] usb usb2: usb_suspend_both: status -16
[ 16.963029] usb usb2: usb_suspend_both: status -16
[ 16.979023] usb usb2: usb_suspend_both: status -16
[ 16.995022] usb usb2: usb_suspend_both: status -16
[ 17.011040] usb usb2: usb_suspend_both: status -16
[ 17.027022] usb usb2: usb_suspend_both: status -16
[ 17.043088] usb usb2: usb_suspend_both: status -16
[ 17.059045] usb usb2: usb_suspend_both: status -16
[ 17.075022] usb usb2: usb_suspend_both: status -16
[ 17.091012] usb usb2: usb_suspend_both: status -16
[ 17.107018] usb usb2: usb_suspend_both: status -16
[ 17.123020] usb usb2: usb_suspend_both: status -16
[ 17.139022] usb usb2: usb_suspend_both: status -16
[ 17.155042] usb usb2: usb_suspend_both: status -16
[ 17.171034] usb usb2: usb_suspend_both: status -16
[ 17.187031] usb usb2: usb_suspend_both: status -16
[ 17.203034] usb usb2: usb_suspend_both: status -16
[ 17.219051] usb usb2: usb_suspend_both: status -16
[ 17.235046] usb usb2: usb_suspend_both: status -16
[ 17.251047] usb usb2: usb_suspend_both: status -16
[ 17.267035] usb usb2: usb_suspend_both: status -16
[ 17.283038] usb usb2: usb_suspend_both: status -16
[ 17.299011] usb usb2: usb_suspend_both: status -16
[ 17.315015] usb usb2: usb_suspend_both: status -16
[ 17.331031] usb usb2: usb_suspend_both: status -16
[ 17.347039] usb usb2: usb_suspend_both: status -16
[ 17.363038] usb usb2: usb_suspend_both: status -16
[ 17.379053] usb usb2: usb_suspend_both: status -16
[ 17.395046] usb usb2: usb_suspend_both: status -16
[ 17.411113] usb usb2: usb_suspend_both: status -16
[ 17.427063] usb usb2: usb_suspend_both: status -16
[ 17.443048] usb usb2: usb_suspend_both: status -16
[ 17.459079] usb usb2: usb_suspend_both: status -16
[ 17.475032] usb usb2: usb_suspend_both: status -16
[ 17.491037] usb usb2: usb_suspend_both: status -16
[ 17.507013] usb usb2: usb_suspend_both: status -16
[ 17.523008] usb usb2: usb_suspend_both: status -16
[ 17.539047] usb usb2: usb_suspend_both: status -16
[ 17.555052] usb usb2: usb_suspend_both: status -16
[ 17.571006] usb usb2: usb_suspend_both: status -16
[ 17.587011] usb usb2: usb_suspend_both: status -16
[ 17.603053] usb usb2: usb_suspend_both: status -16
[ 17.619039] usb usb2: usb_suspend_both: status -16
[ 17.635055] usb usb2: usb_suspend_both: status -16
[ 17.651025] usb usb2: usb_suspend_both: status -16
[ 17.667040] usb usb2: usb_suspend_both: status -16
[ 17.683043] usb usb2: usb_suspend_both: status -16
[ 17.699049] usb usb2: usb_suspend_both: status -16
[ 17.715031] usb usb2: usb_suspend_both: status -16
[ 17.731014] usb usb2: usb_suspend_both: status -16
[ 17.747022] usb usb2: usb_suspend_both: status -16
[ 17.763025] usb usb2: usb_suspend_both: status -16
[ 17.779069] usb usb2: usb_suspend_both: status -16
[ 17.795053] usb usb2: usb_suspend_both: status -16
[ 17.811036] usb usb2: usb_suspend_both: status -16
[ 17.827018] usb usb2: usb_suspend_both: status -16
[ 17.843016] usb usb2: usb_suspend_both: status -16
[ 17.859013] usb usb2: usb_suspend_both: status -16
[ 17.875043] usb usb2: usb_suspend_both: status -16
[ 17.891039] usb usb2: usb_suspend_both: status -16
[ 17.907035] usb usb2: usb_suspend_both: status -16
[ 17.923028] usb usb2: usb_suspend_both: status -16
[ 17.939046] usb usb2: usb_suspend_both: status -16
[ 17.955025] usb usb2: usb_suspend_both: status -16
[ 17.971028] usb usb2: usb_suspend_both: status -16
[ 17.987031] usb usb2: usb_suspend_both: status -16
[ 18.003021] usb usb2: usb_suspend_both: status -16
[ 18.019030] usb usb2: usb_suspend_both: status -16
[ 18.035109] usb usb2: usb_suspend_both: status -16
[ 18.051102] usb usb2: usb_suspend_both: status -16
[ 18.067040] usb usb2: usb_suspend_both: status -16
[ 18.083017] usb usb2: usb_suspend_both: status -16
[ 18.099032] usb usb2: usb_suspend_both: status -16
[ 18.115025] usb usb2: usb_suspend_both: status -16
[ 18.131074] usb usb2: usb_suspend_both: status -16
[ 18.147074] usb usb2: usb_suspend_both: status -16
[ 18.163045] usb usb2: usb_suspend_both: status -16
[ 18.179052] usb usb2: usb_suspend_both: status -16
[ 18.195042] usb usb2: usb_suspend_both: status -16
[ 18.211052] usb usb2: usb_suspend_both: status -16
[ 18.227043] usb usb2: usb_suspend_both: status -16
[ 18.243050] usb usb2: usb_suspend_both: status -16
[ 18.259055] usb usb2: usb_suspend_both: status -16
[ 18.275011] usb usb2: usb_suspend_both: status -16
[ 18.291010] usb usb2: usb_suspend_both: status -16
[ 18.307035] usb usb2: usb_suspend_both: status -16
[ 18.323014] usb usb2: usb_suspend_both: status -16
[ 18.339072] usb usb2: usb_suspend_both: status -16
[ 18.355064] usb usb2: usb_suspend_both: status -16
[ 18.371089] usb usb2: usb_suspend_both: status -16
[ 18.391009] usb usb2: usb_suspend_both: status -16
[ 18.406995] usb usb2: usb_suspend_both: status -16
[ 18.423108] usb usb2: usb_suspend_both: status -16
[ 18.439055] usb usb2: usb_suspend_both: status -16
[ 18.455010] usb usb2: usb_suspend_both: status -16
[ 18.471034] usb usb2: usb_suspend_both: status -16
[ 18.487026] usb usb2: usb_suspend_both: status -16
[ 18.507013] usb usb2: usb_suspend_both: status -16
[ 18.523014] usb usb2: usb_suspend_both: status -16
[ 18.539001] usb usb2: usb_suspend_both: status -16
[ 18.555030] usb usb2: usb_suspend_both: status -16
[ 18.571061] usb usb2: usb_suspend_both: status -16
[ 18.587070] usb usb2: usb_suspend_both: status -16
[ 18.603075] usb usb2: usb_suspend_both: status -16
[ 18.619081] usb usb2: usb_suspend_both: status -16
[ 18.635088] usb usb2: usb_suspend_both: status -16
[ 18.651012] usb usb2: usb_suspend_both: status -16
[ 18.667083] usb usb2: usb_suspend_both: status -16
[ 18.683081] usb usb2: usb_suspend_both: status -16
[ 18.699007] usb usb2: usb_suspend_both: status -16
[ 18.715045] usb usb2: usb_suspend_both: status -16
[ 18.731029] usb usb2: usb_suspend_both: status -16
[ 18.747001] usb usb2: usb_suspend_both: status -16
[ 18.763000] usb usb2: usb_suspend_both: status -16
[ 18.779025] usb usb2: usb_suspend_both: status -16
[ 18.795037] usb usb2: usb_suspend_both: status -16
[ 18.811190] usb usb2: usb_suspend_both: status -16
[ 18.827069] usb usb2: usb_suspend_both: status -16
[ 18.843055] usb usb2: usb_suspend_both: status -16
[ 18.859039] usb usb2: usb_suspend_both: status -16
[ 18.875035] usb usb2: usb_suspend_both: status -16
[ 18.891114] usb usb2: usb_suspend_both: status -16
[ 18.907096] usb usb2: usb_suspend_both: status -16
[ 18.923081] usb usb2: usb_suspend_both: status -16
[ 18.939170] usb usb2: usb_suspend_both: status -16
[ 18.955135] usb usb2: usb_suspend_both: status -16
[ 18.971164] usb usb2: usb_suspend_both: status -16
[ 18.987192] usb usb2: usb_suspend_both: status -16
[ 19.003238] usb usb2: usb_suspend_both: status -16
[ 19.019142] usb usb2: usb_suspend_both: status -16
[ 19.035273] usb usb2: usb_suspend_both: status -16
[ 19.051233] usb usb2: usb_suspend_both: status -16
[ 19.067337] usb usb2: usb_suspend_both: status -16
[ 19.083590] usb usb2: usb_suspend_both: status -16
[ 19.099207] usb usb2: usb_suspend_both: status -16
[ 19.115080] usb usb2: usb_suspend_both: status -16
[ 19.131022] usb usb2: usb_suspend_both: status -16
[ 19.147019] usb usb2: usb_suspend_both: status -16
[ 19.163071] usb usb2: usb_suspend_both: status -16
[ 19.179034] usb usb2: usb_suspend_both: status -16
[ 19.195072] usb usb2: usb_suspend_both: status -16
[ 19.211031] usb usb2: usb_suspend_both: status -16
[ 19.227012] usb usb2: usb_suspend_both: status -16
[ 19.247140] usb usb2: usb_suspend_both: status -16
[ 19.263086] usb usb2: usb_suspend_both: status -16
[ 19.279080] usb usb2: usb_suspend_both: status -16
[ 19.295057] usb usb2: usb_suspend_both: status -16
[ 19.311115] usb usb2: usb_suspend_both: status -16
[ 19.327040] usb usb2: usb_suspend_both: status -16
[ 19.347134] usb usb2: usb_suspend_both: status -16
[ 19.363017] usb usb2: usb_suspend_both: status -16
[ 19.379075] usb usb2: usb_suspend_both: status -16
[ 19.395012] usb usb2: usb_suspend_both: status -16
[ 19.411048] usb usb2: usb_suspend_both: status -16
[ 19.427095] usb usb2: usb_suspend_both: status -16
[ 19.443031] usb usb2: usb_suspend_both: status -16
[ 19.459060] usb usb2: usb_suspend_both: status -16
[ 19.475067] usb usb2: usb_suspend_both: status -16
[ 19.491071] usb usb2: usb_suspend_both: status -16
[ 19.507052] usb usb2: usb_suspend_both: status -16
[ 19.523050] usb usb2: usb_suspend_both: status -16
[ 19.543035] usb usb2: usb_suspend_both: status -16
[ 19.563024] usb usb2: usb_suspend_both: status -16
[ 19.583044] usb usb2: usb_suspend_both: status -16
[ 19.599023] usb usb2: usb_suspend_both: status -16
[ 19.615019] usb usb2: usb_suspend_both: status -16
[ 19.631029] usb usb2: usb_suspend_both: status -16
[ 19.647046] usb usb2: usb_suspend_both: status -16
[ 19.663001] usb usb2: usb_suspend_both: status -16
[ 19.683017] usb usb2: usb_suspend_both: status -16
[ 19.699079] usb usb2: usb_suspend_both: status -16
[ 19.715040] usb usb2: usb_suspend_both: status -16
[ 19.731033] usb usb2: usb_suspend_both: status -16
[ 19.747027] usb usb2: usb_suspend_both: status -16
[ 19.763120] usb usb2: usb_suspend_both: status -16
[ 19.779073] usb usb2: usb_suspend_both: status -16
[ 19.795128] usb usb2: usb_suspend_both: status -16
[ 19.811099] usb usb2: usb_suspend_both: status -16
[ 19.827074] usb usb2: usb_suspend_both: status -16
[ 19.843121] usb usb2: usb_suspend_both: status -16
[ 19.859054] usb usb2: usb_suspend_both: status -16
[ 19.875022] usb usb2: usb_suspend_both: status -16
[ 19.891039] usb usb2: usb_suspend_both: status -16
[ 19.907036] usb usb2: usb_suspend_both: status -16
[ 19.923030] usb usb2: usb_suspend_both: status -16
[ 19.939036] usb usb2: usb_suspend_both: status -16
[ 19.955032] usb usb2: usb_suspend_both: status -16
[ 19.971038] usb usb2: usb_suspend_both: status -16
[ 19.987028] usb usb2: usb_suspend_both: status -16
[ 20.003030] usb usb2: usb_suspend_both: status -16
[ 20.019028] usb usb2: usb_suspend_both: status -16
[ 20.035024] usb usb2: usb_suspend_both: status -16
[ 20.051069] usb usb2: usb_suspend_both: status -16
[ 20.067083] usb usb2: usb_suspend_both: status -16
[ 20.083100] usb usb2: usb_suspend_both: status -16
[ 20.099029] usb usb2: usb_suspend_both: status -16
[ 20.115027] usb usb2: usb_suspend_both: status -16
[ 20.131020] usb usb2: usb_suspend_both: status -16
[ 20.147047] usb usb2: usb_suspend_both: status -16
[ 20.163043] usb usb2: usb_suspend_both: status -16
[ 20.179019] usb usb2: usb_suspend_both: status -16
[ 20.195038] usb usb2: usb_suspend_both: status -16
[ 20.211008] usb usb2: usb_suspend_both: status -16
[ 20.227033] usb usb2: usb_suspend_both: status -16
[ 20.243035] usb usb2: usb_suspend_both: status -16
[ 20.259009] usb usb2: usb_suspend_both: status -16
[ 20.275019] usb usb2: usb_suspend_both: status -16
[ 20.291046] usb usb2: usb_suspend_both: status -16
[ 20.307029] usb usb2: usb_suspend_both: status -16
[ 20.323087] usb usb2: usb_suspend_both: status -16
[ 20.339079] usb usb2: usb_suspend_both: status -16
[ 20.355105] usb usb2: usb_suspend_both: status -16
[ 20.371086] usb usb2: usb_suspend_both: status -16
[ 20.387081] usb usb2: usb_suspend_both: status -16
[ 20.403085] usb usb2: usb_suspend_both: status -16
[ 20.419092] usb usb2: usb_suspend_both: status -16
[ 20.435075] usb usb2: usb_suspend_both: status -16
[ 20.451102] usb usb2: usb_suspend_both: status -16
[ 20.467131] usb usb2: usb_suspend_both: status -16
[ 20.483022] usb usb2: usb_suspend_both: status -16
[ 20.499109] usb usb2: usb_suspend_both: status -16
[ 20.515061] usb usb2: usb_suspend_both: status -16
[ 20.531058] usb usb2: usb_suspend_both: status -16
[ 20.547116] usb usb2: usb_suspend_both: status -16
[ 20.563120] usb usb2: usb_suspend_both: status -16
[ 20.579129] usb usb2: usb_suspend_both: status -16
[ 20.595115] usb usb2: usb_suspend_both: status -16
[ 20.611027] usb usb2: usb_suspend_both: status -16
[ 20.627029] usb usb2: usb_suspend_both: status -16
[ 20.643160] usb usb2: usb_suspend_both: status -16
[ 20.659877] usb usb2: usb_suspend_both: status -16
[ 20.675023] usb usb2: usb_suspend_both: status -16
[ 20.691076] usb usb2: usb_suspend_both: status -16
[ 20.707040] usb usb2: usb_suspend_both: status -16
[ 20.723216] usb usb2: usb_suspend_both: status -16
[ 20.739067] usb usb2: usb_suspend_both: status -16
[ 20.755387] usb usb2: usb_suspend_both: status -16
[ 20.771022] usb usb2: usb_suspend_both: status -16
[ 20.787065] usb usb2: usb_suspend_both: status -16
[ 20.803136] usb usb2: usb_suspend_both: status -16
[ 20.819065] usb usb2: usb_suspend_both: status -16
[ 20.835063] usb usb2: usb_suspend_both: status -16
[ 20.855188] usb usb2: usb_suspend_both: status -16
[ 20.871808] usb usb2: usb_suspend_both: status -16
[ 20.887069] usb usb2: usb_suspend_both: status -16
[ 20.903076] usb usb2: usb_suspend_both: status -16
[ 20.920108] usb usb2: usb_suspend_both: status -16
[ 20.936202] usb usb2: usb_suspend_both: status -16
[ 20.952612] usb usb2: usb_suspend_both: status -16
[ 20.971177] usb usb2: usb_suspend_both: status -16
[ 20.988203] usb usb2: usb_suspend_both: status -16
[ 21.003574] usb usb2: usb_suspend_both: status -16
[ 21.019998] usb usb2: usb_suspend_both: status -16
[ 21.035458] usb usb2: usb_suspend_both: status -16
[ 21.051428] usb usb2: usb_suspend_both: status -16
[ 21.067411] usb usb2: usb_suspend_both: status -16
[ 21.083441] usb usb2: usb_suspend_both: status -16
[ 21.099445] usb usb2: usb_suspend_both: status -16
[ 21.115565] usb usb2: usb_suspend_both: status -16
[ 21.131525] usb usb2: usb_suspend_both: status -16
[ 21.147979] usb usb2: usb_suspend_both: status -16
[ 21.168411] usb usb2: usb_suspend_both: status -16
[ 21.187169] usb usb2: usb_suspend_both: status -16
[ 21.203451] usb usb2: usb_suspend_both: status -16
[ 21.219796] usb usb2: usb_suspend_both: status -16
[ 21.240407] usb usb2: usb_suspend_both: status -16
[ 21.255009] usb usb2: usb_suspend_both: status -16
[ 21.271332] usb usb2: usb_suspend_both: status -16
[ 21.287134] usb usb2: usb_suspend_both: status -16
[ 21.303136] usb usb2: usb_suspend_both: status -16
[ 21.324325] usb usb2: usb_suspend_both: status -16
[ 21.339356] usb usb2: usb_suspend_both: status -16
[ 21.355550] usb usb2: usb_suspend_both: status -16
[ 21.371459] usb usb2: usb_suspend_both: status -16
[ 21.387536] usb usb2: usb_suspend_both: status -16
[ 21.403524] usb usb2: usb_suspend_both: status -16
[ 21.423548] usb usb2: usb_suspend_both: status -16
[ 21.439451] usb usb2: usb_suspend_both: status -16
[ 21.455456] usb usb2: usb_suspend_both: status -16
[ 21.471452] usb usb2: usb_suspend_both: status -16
[ 21.487455] usb usb2: usb_suspend_both: status -16
[ 21.503446] usb usb2: usb_suspend_both: status -16
[ 21.519442] usb usb2: usb_suspend_both: status -16
[ 21.535516] usb usb2: usb_suspend_both: status -16
[ 21.551536] usb usb2: usb_suspend_both: status -16
[ 21.568016] usb usb2: usb_suspend_both: status -16
[ 21.584209] usb usb2: usb_suspend_both: status -16
[ 21.599992] usb usb2: usb_suspend_both: status -16
[ 21.616045] usb usb2: usb_suspend_both: status -16
[ 21.632022] usb usb2: usb_suspend_both: status -16
[ 21.647526] usb usb2: usb_suspend_both: status -16
[ 21.663990] usb usb2: usb_suspend_both: status -16
[ 21.679979] usb usb2: usb_suspend_both: status -16
[ 21.695984] usb usb2: usb_suspend_both: status -16
[ 21.711998] usb usb2: usb_suspend_both: status -16
[ 21.732016] usb usb2: usb_suspend_both: status -16
[ 21.748030] usb usb2: usb_suspend_both: status -16
[ 21.763535] usb usb2: usb_suspend_both: status -16
[ 21.779226] usb usb2: usb_suspend_both: status -16
[ 21.795270] usb usb2: usb_suspend_both: status -16
[ 21.811513] usb usb2: usb_suspend_both: status -16
[ 21.827555] usb usb2: usb_suspend_both: status -16
[ 21.843530] usb usb2: usb_suspend_both: status -16
[ 21.859983] usb usb2: usb_suspend_both: status -16
[ 21.875922] usb usb2: usb_suspend_both: status -16
[ 21.892004] usb usb2: usb_suspend_both: status -16
[ 21.907986] usb usb2: usb_suspend_both: status -16
[ 21.924007] usb usb2: usb_suspend_both: status -16
[ 21.940000] usb usb2: usb_suspend_both: status -16
[ 21.955972] usb usb2: usb_suspend_both: status -16
[ 21.972224] usb usb2: usb_suspend_both: status -16
[ 21.987086] usb usb2: usb_suspend_both: status -16
[ 22.003151] usb usb2: usb_suspend_both: status -16
[ 22.019277] usb usb2: usb_suspend_both: status -16
[ 22.035547] usb usb2: usb_suspend_both: status -16
[ 22.055610] usb usb2: usb_suspend_both: status -16
[ 22.071445] usb usb2: usb_suspend_both: status -16
[ 22.087447] usb usb2: usb_suspend_both: status -16
[ 22.103525] usb usb2: usb_suspend_both: status -16
[ 22.120004] usb usb2: usb_suspend_both: status -16
[ 22.136001] usb usb2: usb_suspend_both: status -16
[ 22.151541] usb usb2: usb_suspend_both: status -16
[ 22.168314] usb usb2: usb_suspend_both: status -16
[ 22.183030] usb usb2: usb_suspend_both: status -16
[ 22.199030] usb usb2: usb_suspend_both: status -16
[ 22.215093] usb usb2: usb_suspend_both: status -16
[ 22.231111] usb usb2: usb_suspend_both: status -16
[ 22.247208] usb usb2: usb_suspend_both: status -16
[ 22.263230] usb usb2: usb_suspend_both: status -16
[ 22.279194] usb usb2: usb_suspend_both: status -16
[ 22.299344] usb usb2: usb_suspend_both: status -16
[ 22.315482] usb usb2: usb_suspend_both: status -16
[ 22.331315] usb usb2: usb_suspend_both: status -16
[ 22.348184] usb usb2: usb_suspend_both: status -16
[ 22.363461] usb usb2: usb_suspend_both: status -16
[ 22.379958] usb usb2: usb_suspend_both: status -16
[ 22.397126] usb usb2: usb_suspend_both: status -16
[ 22.411585] usb usb2: usb_suspend_both: status -16
[ 22.427555] usb usb2: usb_suspend_both: status -16
[ 22.443543] usb usb2: usb_suspend_both: status -16
[ 22.459463] usb usb2: usb_suspend_both: status -16
[ 22.475511] usb usb2: usb_suspend_both: status -16
[ 22.491666] usb usb2: usb_suspend_both: status -16
[ 22.507456] usb usb2: usb_suspend_both: status -16
[ 22.523447] usb usb2: usb_suspend_both: status -16
[ 22.539441] usb usb2: usb_suspend_both: status -16
[ 22.555437] usb usb2: usb_suspend_both: status -16
[ 22.571504] usb usb2: usb_suspend_both: status -16
[ 22.587536] usb usb2: usb_suspend_both: status -16
[ 22.604199] usb usb2: usb_suspend_both: status -16
[ 22.620214] usb usb2: usb_suspend_both: status -16
[ 22.635437] usb usb2: usb_suspend_both: status -16
[ 22.652174] usb usb2: usb_suspend_both: status -16
[ 22.667985] usb usb2: usb_suspend_both: status -16
[ 22.683971] usb usb2: usb_suspend_both: status -16
[ 22.700025] usb usb2: usb_suspend_both: status -16
[ 22.716053] usb usb2: usb_suspend_both: status -16
[ 22.731993] usb usb2: usb_suspend_both: status -16
[ 22.747508] usb usb2: usb_suspend_both: status -16
[ 22.764002] usb usb2: usb_suspend_both: status -16
[ 22.780002] usb usb2: usb_suspend_both: status -16
[ 22.796014] usb usb2: usb_suspend_both: status -16
[ 22.811517] usb usb2: usb_suspend_both: status -16
[ 22.828190] usb usb2: usb_suspend_both: status -16
[ 22.843917] usb usb2: usb_suspend_both: status -16
[ 22.859941] usb usb2: usb_suspend_both: status -16
[ 22.876097] usb usb2: usb_suspend_both: status -16
[ 22.892021] usb usb2: usb_suspend_both: status -16
[ 22.912002] usb usb2: usb_suspend_both: status -16
[ 22.927928] usb usb2: usb_suspend_both: status -16
[ 22.943456] usb usb2: usb_suspend_both: status -16
[ 22.959448] usb usb2: usb_suspend_both: status -16
[ 22.975462] usb usb2: usb_suspend_both: status -16
[ 22.991449] usb usb2: usb_suspend_both: status -16
[ 23.007434] usb usb2: usb_suspend_both: status -16
[ 23.023884] usb usb2: usb_suspend_both: status -16
[ 23.039984] usb usb2: usb_suspend_both: status -16
[ 23.055511] usb usb2: usb_suspend_both: status -16
[ 23.071971] usb usb2: usb_suspend_both: status -16
[ 23.087978] usb usb2: usb_suspend_both: status -16
[ 23.103167] usb usb2: usb_suspend_both: status -16
[ 23.119807] usb usb2: usb_suspend_both: status -16
[ 23.136004] usb usb2: usb_suspend_both: status -16
[ 23.151946] usb usb2: usb_suspend_both: status -16
[ 23.168023] usb usb2: usb_suspend_both: status -16
[ 23.183656] usb usb2: usb_suspend_both: status -16
[ 23.200458] usb usb2: usb_suspend_both: status -16
[ 23.215434] usb usb2: usb_suspend_both: status -16
[ 23.231323] usb usb2: usb_suspend_both: status -16
[ 23.247800] usb usb2: usb_suspend_both: status -16
[ 23.263720] usb usb2: usb_suspend_both: status -16
[ 23.279532] usb usb2: usb_suspend_both: status -16
[ 23.295517] usb usb2: usb_suspend_both: status -16
[ 23.312007] usb usb2: usb_suspend_both: status -16
[ 23.331614] usb usb2: usb_suspend_both: status -16
[ 23.351555] usb usb2: usb_suspend_both: status -16
[ 23.368016] usb usb2: usb_suspend_both: status -16
[ 23.387903] usb usb2: usb_suspend_both: status -16
[ 23.403447] usb usb2: usb_suspend_both: status -16
[ 23.419184] usb usb2: usb_suspend_both: status -16
[ 23.435461] usb usb2: usb_suspend_both: status -16
[ 23.452021] usb usb2: usb_suspend_both: status -16
[ 23.467387] usb usb2: usb_suspend_both: status -16
[ 23.483930] usb usb2: usb_suspend_both: status -16
[ 23.499505] usb usb2: usb_suspend_both: status -16
[ 23.515459] usb usb2: usb_suspend_both: status -16
[ 23.531461] usb usb2: usb_suspend_both: status -16
[ 23.547452] usb usb2: usb_suspend_both: status -16
[ 23.563524] usb usb2: usb_suspend_both: status -16
[ 23.579833] usb usb2: usb_suspend_both: status -16
[ 23.599104] usb usb2: usb_suspend_both: status -16
[ 23.615655] usb usb2: usb_suspend_both: status -16
[ 23.631483] usb usb2: usb_suspend_both: status -16
[ 23.647474] usb usb2: usb_suspend_both: status -16
[ 23.664023] usb usb2: usb_suspend_both: status -16
[ 23.679999] usb usb2: usb_suspend_both: status -16
[ 23.695441] usb usb2: usb_suspend_both: status -16
[ 23.712150] usb usb2: usb_suspend_both: status -16
[ 23.728014] usb usb2: usb_suspend_both: status -16
[ 23.743818] usb usb2: usb_suspend_both: status -16
[ 23.759986] usb usb2: usb_suspend_both: status -16
[ 23.775452] usb usb2: usb_suspend_both: status -16
[ 23.792190] usb usb2: usb_suspend_both: status -16
[ 23.807877] usb usb2: usb_suspend_both: status -16
[ 23.824009] usb usb2: usb_suspend_both: status -16
[ 23.839987] usb usb2: usb_suspend_both: status -16
[ 23.855971] usb usb2: usb_suspend_both: status -16
[ 23.871516] usb usb2: usb_suspend_both: status -16
[ 23.887514] usb usb2: usb_suspend_both: status -16
[ 23.903502] usb usb2: usb_suspend_both: status -16
[ 23.919966] usb usb2: usb_suspend_both: status -16
[ 23.935905] usb usb2: usb_suspend_both: status -16
[ 23.951982] usb usb2: usb_suspend_both: status -16
[ 23.968217] usb usb2: usb_suspend_both: status -16
[ 23.983948] usb usb2: usb_suspend_both: status -16
[ 23.999517] usb usb2: usb_suspend_both: status -16
[ 24.016232] usb usb2: usb_suspend_both: status -16
[ 24.031945] usb usb2: usb_suspend_both: status -16
[ 24.048174] usb usb2: usb_suspend_both: status -16
[ 24.063988] usb usb2: usb_suspend_both: status -16
[ 24.079996] usb usb2: usb_suspend_both: status -16
[ 24.096013] usb usb2: usb_suspend_both: status -16
[ 24.111996] usb usb2: usb_suspend_both: status -16
[ 24.128012] usb usb2: usb_suspend_both: status -16
[ 24.143989] usb usb2: usb_suspend_both: status -16
[ 24.159999] usb usb2: usb_suspend_both: status -16
[ 24.175521] usb usb2: usb_suspend_both: status -16
[ 24.192072] usb usb2: usb_suspend_both: status -16
[ 24.207936] usb usb2: usb_suspend_both: status -16
[ 24.223507] usb usb2: usb_suspend_both: status -16
[ 24.240204] usb usb2: usb_suspend_both: status -16
[ 24.255985] usb usb2: usb_suspend_both: status -16
[ 24.272144] usb usb2: usb_suspend_both: status -16
[ 24.288017] usb usb2: usb_suspend_both: status -16
[ 24.303534] usb usb2: usb_suspend_both: status -16
[ 24.319760] usb usb2: usb_suspend_both: status -16
[ 24.335201] usb usb2: usb_suspend_both: status -16
[ 24.352044] usb usb2: usb_suspend_both: status -16
[ 24.367737] usb usb2: usb_suspend_both: status -16
[ 24.384517] usb usb2: usb_suspend_both: status -16
[ 24.403222] usb usb2: usb_suspend_both: status -16
[ 24.423701] usb usb2: usb_suspend_both: status -16
[ 24.443619] usb usb2: usb_suspend_both: status -16
[ 24.459471] usb usb2: usb_suspend_both: status -16
[ 24.475867] usb usb2: usb_suspend_both: status -16
[ 24.492247] usb usb2: usb_suspend_both: status -16
[ 24.507583] usb usb2: usb_suspend_both: status -16
[ 24.523555] usb usb2: usb_suspend_both: status -16
[ 24.539652] usb usb2: usb_suspend_both: status -16
[ 24.555522] usb usb2: usb_suspend_both: status -16
[ 24.572253] usb usb2: usb_suspend_both: status -16
[ 24.587538] usb usb2: usb_suspend_both: status -16
[ 24.603598] usb usb2: usb_suspend_both: status -16
[ 24.619575] usb usb2: usb_suspend_both: status -16
[ 24.635533] usb usb2: usb_suspend_both: status -16
[ 24.651459] usb usb2: usb_suspend_both: status -16
[ 24.667428] usb usb2: usb_suspend_both: status -16
[ 24.683366] usb usb2: usb_suspend_both: status -16
[ 24.699364] usb usb2: usb_suspend_both: status -16
[ 24.715362] usb usb2: usb_suspend_both: status -16
[ 24.732008] usb usb2: usb_suspend_both: status -16
[ 24.747366] usb usb2: usb_suspend_both: status -16
[ 24.763365] usb usb2: usb_suspend_both: status -16
[ 24.780095] usb usb2: usb_suspend_both: status -16
[ 24.795181] usb usb2: usb_suspend_both: status -16
[ 24.811686] usb usb2: usb_suspend_both: status -16
[ 24.827494] usb usb2: usb_suspend_both: status -16
[ 24.843481] usb usb2: usb_suspend_both: status -16
[ 24.859524] usb usb2: usb_suspend_both: status -16
[ 24.875462] usb usb2: usb_suspend_both: status -16
[ 24.891555] usb usb2: usb_suspend_both: status -16
[ 24.907387] usb usb2: usb_suspend_both: status -16
[ 24.924039] usb usb2: usb_suspend_both: status -16
[ 24.940095] usb usb2: usb_suspend_both: status -16
[ 24.955554] usb usb2: usb_suspend_both: status -16
[ 24.971384] usb usb2: usb_suspend_both: status -16
[ 24.987392] usb usb2: usb_suspend_both: status -16
[ 25.003387] usb usb2: usb_suspend_both: status -16
[ 25.019389] usb usb2: usb_suspend_both: status -16
[ 25.035540] usb usb2: usb_suspend_both: status -16
[ 25.051576] usb usb2: usb_suspend_both: status -16
[ 25.067697] usb usb2: usb_suspend_both: status -16
[ 25.083935] usb usb2: usb_suspend_both: status -16
[ 25.099444] usb usb2: usb_suspend_both: status -16
[ 25.115560] usb usb2: usb_suspend_both: status -16
[ 25.132011] usb usb2: usb_suspend_both: status -16
[ 25.147549] usb usb2: usb_suspend_both: status -16
[ 25.164021] usb usb2: usb_suspend_both: status -16
[ 25.180157] usb usb2: usb_suspend_both: status -16
[ 25.195989] usb usb2: usb_suspend_both: status -16
[ 25.211985] usb usb2: usb_suspend_both: status -16
[ 25.227996] usb usb2: usb_suspend_both: status -16
[ 25.243513] usb usb2: usb_suspend_both: status -16
[ 25.259556] usb usb2: usb_suspend_both: status -16
[ 25.275502] usb usb2: usb_suspend_both: status -16
[ 25.292023] usb usb2: usb_suspend_both: status -16
[ 25.307537] usb usb2: usb_suspend_both: status -16
[ 25.323276] usb usb2: usb_suspend_both: status -16
[ 25.339044] usb usb2: usb_suspend_both: status -16
[ 25.359439] usb usb2: usb_suspend_both: status -16
[ 25.375166] usb usb2: usb_suspend_both: status -16
[ 25.391486] usb usb2: usb_suspend_both: status -16
[ 25.407516] usb usb2: usb_suspend_both: status -16
[ 25.423513] usb usb2: usb_suspend_both: status -16
[ 25.439997] usb usb2: usb_suspend_both: status -16
[ 25.456000] usb usb2: usb_suspend_both: status -16
[ 25.472017] usb usb2: usb_suspend_both: status -16
[ 25.487753] usb usb2: usb_suspend_both: status -16
[ 25.503606] usb usb2: usb_suspend_both: status -16
[ 25.519379] usb usb2: usb_suspend_both: status -16
[ 25.535424] usb usb2: usb_suspend_both: status -16
[ 25.551434] usb usb2: usb_suspend_both: status -16
[ 25.567641] usb usb2: usb_suspend_both: status -16
[ 25.583773] usb usb2: usb_suspend_both: status -16
[ 25.599336] usb usb2: usb_suspend_both: status -16
[ 25.615553] usb usb2: usb_suspend_both: status -16
[ 25.631562] usb usb2: usb_suspend_both: status -16
[ 25.647507] usb usb2: usb_suspend_both: status -16
[ 25.663457] usb usb2: usb_suspend_both: status -16
[ 25.679708] usb usb2: usb_suspend_both: status -16
[ 25.695467] usb usb2: usb_suspend_both: status -16
[ 25.711432] usb usb2: usb_suspend_both: status -16
[ 25.728031] usb usb2: usb_suspend_both: status -16
[ 25.743649] usb usb2: usb_suspend_both: status -16
[ 25.759594] usb usb2: usb_suspend_both: status -16
[ 25.775659] usb usb2: usb_suspend_both: status -16
[ 25.791654] usb usb2: usb_suspend_both: status -16
[ 25.807651] usb usb2: usb_suspend_both: status -16
[ 25.823653] usb usb2: usb_suspend_both: status -16
[ 25.839536] usb usb2: usb_suspend_both: status -16
[ 25.856297] usb usb2: usb_suspend_both: status -16
[ 25.871661] usb usb2: usb_suspend_both: status -16
[ 25.887514] usb usb2: usb_suspend_both: status -16
[ 25.904053] usb usb2: usb_suspend_both: status -16
[ 25.919538] usb usb2: usb_suspend_both: status -16
[ 25.935560] usb usb2: usb_suspend_both: status -16
[ 25.956108] usb usb2: usb_suspend_both: status -16
[ 25.971648] usb usb2: usb_suspend_both: status -16
[ 25.987802] usb usb2: usb_suspend_both: status -16
[ 26.003265] usb usb2: usb_suspend_both: status -16
[ 26.019599] usb usb2: usb_suspend_both: status -16
[ 26.035858] usb usb2: usb_suspend_both: status -16
[ 26.051232] usb usb2: usb_suspend_both: status -16
[ 26.067296] usb usb2: usb_suspend_both: status -16
[ 26.083624] usb usb2: usb_suspend_both: status -16
[ 26.099592] usb usb2: usb_suspend_both: status -16
[ 26.115736] usb usb2: usb_suspend_both: status -16
[ 26.131671] usb usb2: usb_suspend_both: status -16
[ 26.147664] usb usb2: usb_suspend_both: status -16
[ 26.163664] usb usb2: usb_suspend_both: status -16
[ 26.179546] usb usb2: usb_suspend_both: status -16
[ 26.195571] usb usb2: usb_suspend_both: status -16
[ 26.211645] usb usb2: usb_suspend_both: status -16
[ 26.227568] usb usb2: usb_suspend_both: status -16
[ 26.244302] usb usb2: usb_suspend_both: status -16
[ 26.259518] usb usb2: usb_suspend_both: status -16
[ 26.275710] usb usb2: usb_suspend_both: status -16
[ 26.296265] usb usb2: usb_suspend_both: status -16
[ 26.311654] usb usb2: usb_suspend_both: status -16
[ 26.327659] usb usb2: usb_suspend_both: status -16
[ 26.343496] usb usb2: usb_suspend_both: status -16
[ 26.359578] usb usb2: usb_suspend_both: status -16
[ 26.375568] usb usb2: usb_suspend_both: status -16
[ 26.392109] usb usb2: usb_suspend_both: status -16
[ 26.408086] usb usb2: usb_suspend_both: status -16
[ 26.423560] usb usb2: usb_suspend_both: status -16
[ 26.440385] usb usb2: usb_suspend_both: status -16
[ 26.455549] usb usb2: usb_suspend_both: status -16
[ 26.471563] usb usb2: usb_suspend_both: status -16
[ 26.487645] usb usb2: usb_suspend_both: status -16
[ 26.503529] usb usb2: usb_suspend_both: status -16
[ 26.522411] usb usb2: usb_suspend_both: status -16
[ 26.524757] usb usb2-port1: config error
[ 26.972873] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 27.002785] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620
[ 27.002856] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 27.003459] usb 2-1: Product: USB3.0 Hub
[ 27.003479] usb 2-1: Manufacturer: GenesysLogic
[ 27.007027] hub 2-1:1.0: USB hub found
[ 31.232829] usb 2-1-port4: Cannot enable. Maybe the USB cable is bad?
[ 35.252391] usb 2-1-port4: Cannot enable. Maybe the USB cable is bad?
[ 35.259722] usb 2-1-port4: attempt power cycle
[ 39.592686] usb 2-1-port4: Cannot enable. Maybe the USB cable is bad?
[ 43.612528] usb 2-1-port4: Cannot enable. Maybe the USB cable is bad?
[ 43.620307] usb 2-1-port4: unable to enumerate USB device
[ 43.682972] usb 2-1: usb_suspend_both: status 0
[ 43.683356] usb usb2: usb_suspend_both: status 0
[ 43.683420] tegra-xusb 70090000.xusb: entering ELPG
[ 43.688552] tegra-xusb 70090000.xusb: entering ELPG done
