I need a simple example
Examples of Deepstream is very complex. I need a simple example use Deepstream to get frame of stream (http://10.86.160.198:8080/) then convert to cv::Mat, use cv::rectangle() and display with cv::imshow(). Thanks.
If you run DeepStream SDK 3.0 on Xavier, you may refer to
[url]https://devtalk.nvidia.com/default/topic/1046315/deepstream-sdk-on-jetson/template-config-file-for-camera-and-rtsp/post/5314984/#5314984[/url]
Users have to refer to the samples and integrate into your usecases. If you need customization, you may contact us to have further cooperation. Thanks.
