[0000.103] I> MB1 (prd-version: 2.6.0.0-t194-41334769-cab45716)
[0000.108] I> Boot-mode: Coldboot
[0000.111] I> Platform: Silicon
[0000.114] I> Chip revision : A02
[0000.117] I> Bootrom patch version : 15 (correctly patched)
[0000.122] I> ATE fuse revision : 0x200
[0000.125] I> Ram repair fuse : 0x0
[0000.128] I> Ram Code : 0x2
[0000.131] I> rst_source: 0x0, rst_level: 0x0
[0000.136] I> Boot-device: SDMMC (instance: 3)
[0000.152] I> sdmmc DDR50 mode
[0000.156] I> Boot chain mechanism: A/B
[0000.159] I> Current Boot-Chain Slot: 0
[0000.163] I> BR-BCT Boot-Chain: 0, status: 0. update flag: 0
[0000.170] W> PROD_CONFIG: device prod data is empty in MB1 BCT.
[0000.177] I> Temperature = 31000
[0000.180] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.185] W> Skipping boost for clk: BPMP_APB
[0000.189] W> Skipping boost for clk: AXI_CBB
[0000.193] W> Skipping boost for clk: AON_CPU_NIC
[0000.197] W> Skipping boost for clk: CAN1
[0000.201] W> Skipping boost for clk: CAN2
[0000.205] I> Boot-device: SDMMC (instance: 3)
[0000.216] I> Sdmmc: HS400 mode enabled
[0000.220] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.227] W> Thermal config not found in BCT
[0000.235] W> MEMIO rail config not found in BCT
[0000.257] I> sdmmc bdev is already initialized
[0000.302] W> Platform config not found in BCT
[0000.336] I> MB1 done
����main enter
SPE VERSION #: R01.00.18 Created: Jan 29 2021 @ 14:18:27
HW Function test
Start Scheduler.
in late init
[0000.345] I> Welcome to MB2(TBoot-BPMP) (version: default.t194-mobile-74494172)
[0000.346] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.346] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.348] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.353] W> device prod register failed
[0000.357] I> gpio framework initialized
[0000.360] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0000.368] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0000.376] I> No valid sdcard_params in mb1_bct
[0000.380] I> Boot_device: SDMMC_BOOT instance: 3
[0000.384] I> sdmmc-3 params source = boot args
[0000.393] I> sdmmc-3 params source = boot args
[0000.394] I> sdmmc bdev is already initialized
[0000.427] I> Found 20 partitions in SDMMC_BOOT (instance 3)
[0000.443] I> Found 44 partitions in SDMMC_USER (instance 3)
[0000.444] I> Active Boot chain : 0
[0000.501] I> Relocating BR-BCT
[0000.502] > DEVICE_PROD: device prod is not initialized.
[0000.528] E> I2C: slave not found in slaves.
[0000.528] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0000.529] E> I2C_DEV: Failed to send register address 0x00000000.
[0000.530] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0000.531] E> eeprom: Failed to read I2C slave device
[0000.534] I> Failed to read CVB eeprom data @ AE
[0000.539] I> Retrying CVB eeprom read @ AC ...
[0000.613] I> Relocating OP-TEE dtb from: 0x6bfff710 to 0x70050000, size: 1008
[0000.614] I> [0] START: 0x80000000, SIZE: 0x2f000000
[0000.615] I> [1] START: 0xaf010000, SIZE: 0x189f0000
[0000.615] I> [2] START: 0xc7b00000, SIZE: 0xc0000
[0000.616] I> [3] START: 0xca000000, SIZE: 0x800000
[0000.616] I> dram_block larger than 80000000
[0000.618] I> [4] START: 0x100000000, SIZE: 0x780000000
[0000.630] I> Setting NS memory ranges to OP-TEE dtb finished.
[0000.644] I> found decompressor handler: lz4
[0001.139] I> EKB detected (length: 0x410) @ VA:0x526ff400
[0001.140] I> Setting EKB blob info to OPTEE dtb finished.
��NOTICE: BL31: v2.6(release):346877e39
NOTICE: BL31: Built : 12:32:40, Aug 1 2023
I/TC: Physical secure memory base 0xcb040000 size 0xf00000
bpmp: init
bpmp: tag is 128431eec76692047e1ac1ebc0392266
sku_dt_init: not sku 0x00
clk_early initialized
mail_early initialized
fuse initialized
hwwdt initialized
t194_ec_get_ec_list: found 45 ecs
ec initialized
vmon_setup_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
mc initialized
reset initialized
nvhs initialized
uphy_early initialized
emc_early initialized
392 clocks registered
clk initialized
io_dpd initialized
thermal initialized
thermal_mrq initialized
i2c initialized
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
vrmon initialized
regulator initialized
��I/TC:
��avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
suspend initialized
pg_late initialized
pg_mrq_init initialized
strap initialized
nvl initialized
emc initialized
emc_mrq initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy_mrq initialized
uphy initialized
ec_swd_poll_start: 281 reg polling start w period 47 ms
ec_late initialized
hwwdt_late initialized
reset_mrq initialized
ec_mrq initialized
fmon_mrq initialized
clk_mrq initialized
avfs_mrq initialized
mail_mrq initialized
i2c_mrq initialized
tag_mrq initialized
console_mrq initialized
mrq initialized
clk_sync_fmon_post initialized
��I/TC: Non-secure external DT found
��clk_dt_late initialized
noc_late initialized
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
avfs_clk_mach_post initialized
avfs_clk_platform_post initialized
cvc_late initialized
regulator_post initialized
rm initialized
console_late initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
profile initialized
fuse_late initialized
extras_post initialized
bpmp: init complete
entering main console loop
] ��I/TC: OP-TEE version: 3.21 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Aug 1 19:39:56 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
[0001.969] I> Welcome to NVDisp-Init
[0001.969] I> NVDisp-Init version: t194-709c0123
[0001.970] I> CPU-BL Params @ 0xca020000
[0001.970] I> 0) Base:0x00000000 Size:0x00000000
[0001.970] I> 1) Base:0xc8100000 Size:0x00100000
[0001.970] I> 2) Base:0xc9800000 Size:0x00200000
[0001.971] I> 3) Base:0xc8600000 Size:0x00200000
[0001.973] I> 4) Base:0xc8000000 Size:0x00100000
[0001.978] I> 5) Base:0xc7f00000 Size:0x00100000
[0001.982] I> 6) Base:0xc9400000 Size:0x00400000
[0001.987] I> 7) Base:0xc9000000 Size:0x00400000
[0001.991] I> 8) Base:0xc7e00000 Size:0x00100000
[0001.996] I> 9) Base:0xc7d00000 Size:0x00100000
[0002.000] I> 10) Base:0xca800000 Size:0x00800000
[0002.005] I> 11) Base:0x40000000 Size:0x00040000
[0002.009] I> 12) Base:0xc7c00000 Size:0x00100000
[0002.014] I> 13) Base:0x40046000 Size:0x00002000
[0002.018] I> 14) Base:0x40048000 Size:0x00002000
[0002.022] I> 15) Base:0xaf000000 Size:0x00004000
[0002.027] I> 16) Base:0x4004a000 Size:0x00002000
[0002.031] I> 17) Base:0xc7a00000 Size:0x00100000
[0002.036] I> 18) Base:0x4004c000 Size:0x00002000
[0002.040] I> 19) Base:0xc9a00000 Size:0x00600000
[0002.045] I> 20) Base:0x4004e000 Size:0x00002000
[0002.049] I> 21) Base:0xc7bc0000 Size:0x0000c000
[0002.054] I> 22) Base:0x00000000 Size:0x00000000
[0002.058] I> 23) Base:0xc7be0000 Size:0x00020000
[0002.063] I> 24) Base:0xcc000000 Size:0x02000000
[0002.067] I> 25) Base:0x40050000 Size:0x00002000
[0002.072] I> 26) Base:0x40040000 Size:0x00006000
[0002.076] I> 27) Base:0xc8c00000 Size:0x00400000
[0002.080] I> 28) Base:0xc8400000 Size:0x00200000
[0002.085] I> 29) Base:0xc8800000 Size:0x00400000
[0002.089] I> 30) Base:0xc7bd0000 Size:0x00010000
[0002.094] I> 31) Base:0x00000000 Size:0x00000000
[0002.098] I> 32) Base:0xf8000000 Size:0x08000000
[0002.103] I> 33) Base:0xce000000 Size:0x2a000000
[0002.107] I> 34) Base:0xcb000000 Size:0x01000000
[0002.112] I> 35) Base:0xae000000 Size:0x01000000
[0002.116] I> 36) Base:0xa0000000 Size:0x0e000000
[0002.121] I> 37) Base:0xca000000 Size:0x00800000
[0002.125] I> 38) Base:0x80000000 Size:0x20000000
[0002.130] I> 39) Base:0xb0000000 Size:0x08000000
[0002.134] I> 40) Base:0x00000000 Size:0x00000000
[0002.138] I> 41) Base:0x00000000 Size:0x00000000
[0002.143] I> 42) Base:0xc8200000 Size:0x00200000
[0002.147] I> 43) Base:0x00000000 Size:0x00000000
[0002.152] I> 44) Base:0x00000000 Size:0x00000000
[0002.156] I> 45) Base:0x00000000 Size:0x00000000
[0002.161] GIC-SPI Target CPU: 0
[0002.164] Interrupts Init done
[0002.167] calling constructors
[0002.170] initializing heap
[0002.172] I> Heap: [0xa0960000 ... 0xadf00000]
[0002.176] initializing threads
[0002.179] initializing timers
[0002.182] creating bootstrap completion thread
[0002.186] top of bootstrap2()
[0002.189] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0002.194] initializing platform
[0002.197] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0002.202] W> device prod register failed
[0002.206] I> Bl_dtb @0xadf00000
[0002.209] I> gpio framework initialized
[0002.221] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.227] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.233] I> fixed regulator driver initialized
[0002.250] I> register 'maxim' power off handle
[0002.252] I> virtual i2c enabled
[0002.252] I> registered 'maxim,max20024' pmic
[0002.253] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.253] I> Boot-device: eMMC
[0002.253] I> Boot_device: SDMMC_BOOT instance: 3
[0002.260] I> sdmmc-3 params source = boot args
[0002.263] W> No board IDs available
[0002.265] E> Failed to get board id info!
[0002.269] I> sdmmc bdev is already initialized
[0002.273] I> sdmmc-3 params source = boot args
[0002.280] I> Found 20 partitions in SDMMC_BOOT (instance 3)
[0002.285] I> Found 44 partitions in SDMMC_USER (instance 3)
[0002.309] I> enabling 'vdd-hdmi-5v0' regulator
[0002.316] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.317] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.317] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.318] E> cannot find any other nvdisp nodes
[0002.319] E> no valid display unit config found in dtb
[0002.322] W> display init failed
[0002.323] initializing target
[0002.326] calling apps_init()
[0002.329] starting app kernel_boot_app
[0002.332] I> Kernel type = Normal
Jetson UEFI firmware (version 202210.3-52cefd4 built on 2023-09-14T15:25:24+02:00)
Synchronous Exception at 0x000000085963877C
ASSERT [ArmCpuDxe] /home/test/nvidia-uefi-r35.4.1-updates/edk2/ArmPkg/Library/DefaultExceptionHandlerLib/AArch64/DefaultExceptionHandler.c(333): ((BOOLEAN)(0==1))
Resetting the system in 5 seconds.
����Shutdown state requested 1
Rebooting system ...
[0000.054] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level 2 from HW fuses.
[0000.062] I> MB1 (prd-version: 2.6.0.0-t194-41334769-cab45716)
[0000.068] I> Boot-mode: Coldboot
[0000.071] I> Platform: Silicon
[0000.073] I> Chip revision : A02
[0000.076] I> Bootrom patch version : 15 (correctly patched)
[0000.082] I> ATE fuse revision : 0x200
[0000.085] I> Ram repair fuse : 0x0
[0000.088] I> Ram Code : 0x2
[0000.091] I> rst_source: 0xb, rst_level: 0x1
[0000.095] I> Boot-device: SDMMC (instance: 3)
[0000.112] I> sdmmc DDR50 mode
[0000.115] I> Boot chain mechanism: A/B
[0000.119] I> Current Boot-Chain Slot: 1
[0000.122] I> BR-BCT Boot-Chain: 0, status: 1. update flag: 1
[0000.129] W> PROD_CONFIG: device prod data is empty in MB1 BCT.
[0000.135] I> Temperature = 35500
[0000.138] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.142] W> Skipping boost for clk: BPMP_APB
[0000.146] W> Skipping boost for clk: AXI_CBB
[0000.150] W> Skipping boost for clk: AON_CPU_NIC
[0000.155] W> Skipping boost for clk: CAN1
[0000.158] W> Skipping boost for clk: CAN2
[0000.163] I> Boot-device: SDMMC (instance: 3)
[0000.171] I> Sdmmc: HS400 mode enabled
[0000.176] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.182] W> Thermal config not found in BCT
[0000.191] W> MEMIO rail config not found in BCT
[0000.213] I> sdmmc bdev is already initialized
[0000.257] W> Platform config not found in BCT
[0000.291] I> MB1 done
����main enter
HW Function test
Start Scheduler.
in late init
[0000.301] I> Welcome to MB2(TBoot-BPMP) (version: default.t194-mobile-74494172)
[0000.301] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.302] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.303] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.308] W> device prod register failed
[0000.312] I> gpio framework initialized
[0000.316] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0000.323] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0000.331] I> No valid sdcard_params in mb1_bct
[0000.335] I> Boot_device: SDMMC_BOOT instance: 3
[0000.340] I> sdmmc-3 params source = boot args
[0000.349] I> sdmmc-3 params source = boot args
[0000.349] I> sdmmc bdev is already initialized
[0000.382] I> Found 20 partitions in SDMMC_BOOT (instance 3)
[0000.398] I> Found 44 partitions in SDMMC_USER (instance 3)
[0000.399] I> Active Boot chain : 1
[0000.456] I> Relocating BR-BCT
[0000.457] > DEVICE_PROD: device prod is not initialized.
[0000.482] E> I2C: slave not found in slaves.
[0000.483] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0000.484] E> I2C_DEV: Failed to send register address 0x00000000.
[0000.485] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0000.486] E> eeprom: Failed to read I2C slave device
[0000.489] I> Failed to read CVB eeprom data @ AE
[0000.493] I> Retrying CVB eeprom read @ AC ...
[0000.568] I> Relocating OP-TEE dtb from: 0x6bfff710 to 0x70050000, size: 1008
[0000.569] I> [0] START: 0x80000000, SIZE: 0x2f000000
[0000.569] I> [1] START: 0xaf010000, SIZE: 0x189f0000
[0000.570] I> [2] START: 0xc7b00000, SIZE: 0xc0000
[0000.570] I> [3] START: 0xca000000, SIZE: 0x800000
[0000.571] I> dram_block larger than 80000000
[0000.573] I> [4] START: 0x100000000, SIZE: 0x780000000
[0000.584] I> Setting NS memory ranges to OP-TEE dtb finished.
[0000.599] I> found decompressor handler: lz4
[0001.094] I> EKB detected (length: 0x410) @ VA:0x526ff400
[0001.096] I> Setting EKB blob info to OPTEE dtb finished.
bpmp: init
fuse initialized
hwwdt initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
mc initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
vrmon initialized
��I/TC:
aotag initialized
dvs initialized
pm initialized
suspend initialized
pg_late initialized
strap initialized
nvl initialized
emc initialized
emc_mrq initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy initialized
ec_late initialized
ec_mrq initialized
clk_mrq initialized
i2c_mrq initialized
tag_mrq initialized
mrq initialized
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
rm initialized
mc_reg initialized
pg_post initialized
profile initialized
bpmp: init complete
[0001.925] I> Welcome to NVDisp-Init
[0001.925] I> NVDisp-Init version: t194-709c0123
[0001.926] I> CPU-BL Params @ 0xca020000
[0001.926] I> 0) Base:0x00000000 Size:0x00000000
[0001.926] I> 1) Base:0xc8100000 Size:0x00100000
[0001.927] I> 2) Base:0xc9800000 Size:0x00200000
[0001.927] I> 3) Base:0xc8600000 Size:0x00200000
[0001.929] I> 4) Base:0xc8000000 Size:0x00100000
[0001.934] I> 5) Base:0xc7f00000 Size:0x00100000
[0001.938] I> 6) Base:0xc9400000 Size:0x00400000
[0001.943] I> 7) Base:0xc9000000 Size:0x00400000
[0001.947] I> 8) Base:0xc7e00000 Size:0x00100000
[0001.952] I> 9) Base:0xc7d00000 Size:0x00100000
[0001.956] I> 10) Base:0xca800000 Size:0x00800000
[0001.961] I> 11) Base:0x40000000 Size:0x00040000
[0001.965] I> 12) Base:0xc7c00000 Size:0x00100000
[0001.970] I> 13) Base:0x40046000 Size:0x00002000
[0001.974] I> 14) Base:0x40048000 Size:0x00002000
[0001.978] I> 15) Base:0xaf000000 Size:0x00004000
[0001.983] I> 16) Base:0x4004a000 Size:0x00002000
[0001.987] I> 17) Base:0xc7a00000 Size:0x00100000
[0001.992] I> 18) Base:0x4004c000 Size:0x00002000
[0001.996] I> 19) Base:0xc9a00000 Size:0x00600000
[0002.001] I> 20) Base:0x4004e000 Size:0x00002000
[0002.005] I> 21) Base:0xc7bc0000 Size:0x0000c000
[0002.010] I> 22) Base:0x00000000 Size:0x00000000
[0002.014] I> 23) Base:0xc7be0000 Size:0x00020000
[0002.019] I> 24) Base:0xcc000000 Size:0x02000000
[0002.023] I> 25) Base:0x40050000 Size:0x00002000
[0002.028] I> 26) Base:0x40040000 Size:0x00006000
[0002.032] I> 27) Base:0xc8c00000 Size:0x00400000
[0002.036] I> 28) Base:0xc8400000 Size:0x00200000
[0002.041] I> 29) Base:0xc8800000 Size:0x00400000
[0002.045] I> 30) Base:0xc7bd0000 Size:0x00010000
[0002.050] I> 31) Base:0x00000000 Size:0x00000000
[0002.054] I> 32) Base:0xf8000000 Size:0x08000000
[0002.059] I> 33) Base:0xce000000 Size:0x2a000000
[0002.063] I> 34) Base:0xcb000000 Size:0x01000000
[0002.068] I> 35) Base:0xae000000 Size:0x01000000
[0002.072] I> 36) Base:0xa0000000 Size:0x0e000000
[0002.077] I> 37) Base:0xca000000 Size:0x00800000
[0002.081] I> 38) Base:0x80000000 Size:0x20000000
[0002.086] I> 39) Base:0xb0000000 Size:0x08000000
[0002.090] I> 40) Base:0x00000000 Size:0x00000000
[0002.094] I> 41) Base:0x00000000 Size:0x00000000
[0002.099] I> 42) Base:0xc8200000 Size:0x00200000
[0002.103] I> 43) Base:0x00000000 Size:0x00000000
[0002.108] I> 44) Base:0x00000000 Size:0x00000000
[0002.112] I> 45) Base:0x00000000 Size:0x00000000
[0002.117] GIC-SPI Target CPU: 0
[0002.120] Interrupts Init done
[0002.123] calling constructors
[0002.126] initializing heap
[0002.128] I> Heap: [0xa0960000 ... 0xadf00000]
[0002.132] initializing threads
[0002.135] initializing timers
[0002.138] creating bootstrap completion thread
[0002.142] top of bootstrap2()
[0002.145] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0002.150] initializing platform
[0002.153] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0002.158] W> device prod register failed
[0002.162] I> Bl_dtb @0xadf00000
[0002.165] I> gpio framework initialized
[0002.177] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.182] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.187] I> fixed regulator driver initialized
[0002.203] I> register 'maxim' power off handle
[0002.205] I> virtual i2c enabled
[0002.206] I> registered 'maxim,max20024' pmic
[0002.206] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.207] I> Boot-device: eMMC
[0002.209] I> Boot_device: SDMMC_BOOT instance: 3
[0002.216] I> sdmmc-3 params source = boot args
[0002.219] W> No board IDs available
[0002.221] E> Failed to get board id info!
[0002.225] I> sdmmc bdev is already initialized
[0002.229] I> sdmmc-3 params source = boot args
[0002.236] I> Found 20 partitions in SDMMC_BOOT (instance 3)
[0002.241] I> Found 44 partitions in SDMMC_USER (instance 3)
[0002.263] I> enabling 'vdd-hdmi-5v0' regulator
[0002.270] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.271] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.271] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.272] E> cannot find any other nvdisp nodes
[0002.273] E> no valid display unit config found in dtb
[0002.278] W> display init failed
[0002.279] initializing target
[0002.282] calling apps_init()
[0002.285] starting app kernel_boot_app
[0002.288] I> Kernel type = Normal
[0000.096] I> Boot-device: SDMMC (instance: 3)
[0000.119] I> Current Boot-Chain Slot: 0
[0000.122] E> Error, current slot 0 fails: sr_bl: 0x4d14ef1, sr_br: 0x0
[0000.129] I> Reset to recovery mode
Xaveir or Xavier NX?
My board is a custom carrier board or a devkit?
How did you compile the UEFI binary and how did you flash the board?
Did you make any modifications to the UEFI source code?
Are both bootloader (UEFI) and rootfs 35.4.1?
i fixed by reflash into emmc in next day
i didn’t know logic behind of this
xavier agx devkit with 2TB nvme ssd
