I want to config xavier spi as a slave device,how should I config it?
1.how should I config the pins?
as a slave device,the MISO pin,should I config it as slave out?
2.how should I config the dts
3.how do I debug it,any tools?
  1. You can configure the PINS by jetson-io
  2. Reference to this to modify as slave mode. How to set to spi slave mode - #11 by ShaneCCC
  3. You can verify by spide_test utility.
It is ok now,thank you
