FWIW, I used this script but had to add export LD_LIBRARY_PATH=/usr/local/lib/python3.6/dist-packages/mxnet:$LD_LIBRARY_PATH to the end of ~/.profile to be able to import mxnet. I have a TX2 with a fresh install of Jetpack 4.4. I hope this info helps someone.
