Hi there!
I just got a Jetson Nano (flashed using the jetson-nano-jp451-sd-card-image file), and installed MXNet 1.7.0 by using the ‘autoinstall_mxnet.sh’ script.
I was getting the error "Illegal instruction (core dumped)” when importing MXNet, but I fixed it by adding
export OPENBLAS_CORETYPE=ARMV8
to my .bashrc file, as mentioned in this discussion.
However, when running pip list, I can see the mxnet 1.7.0 entry…shouldn’t it be mxnet-cu102, or something similar?
Then, I needed to install GluonCV. I cloned the repo and tried the installation script:
git clone https://github.com/dmlc/gluon-cv
cd gluon-cv && python setup.py install --user
I got some dependencies error when it comes to the matplotlib installation:
Searching for matplotlib
Reading https://pypi.org/simple/matplotlib/
Downloading
Best match: matplotlib 3.4.2
Processing matplotlib-3.4.2.tar.gz
Writing /tmp/easy_install-g5zib6k8/matplotlib-3.4.2/setup.cfg
Running matplotlib-3.4.2/setup.py -q bdist_egg --dist-dir /tmp/easy_install-g5zib6k8/matplotlib-3.4.2/egg-dist-tmp-g0hdz3xh
error: Setup script exited with
Beginning with Matplotlib 3.4, Python 3.7 or above is required.
You are using Python 3.6.9.
but gluoncv seemed to be installed normally, and I installed matplotlib later.
The problem is that now I’m trying to run some example object detection code, and I’m getting the error:
MXNet Error: Build with USE_OPENCV=1 for image io
Didn’t the autoinstall_mxnet.sh enable that? Can I fix it, or should I flash the card back and reinstall everything following the manual procedure in post #8?
