Hello forum members,
I hope this message finds you well. I am currently working on a project that involves receiving signals from an FPGA over Ethernet at 10Gbps, and I am specifically interested in implementing RoCE (RDMA over Converged Ethernet) for this purpose. To achieve this, I am using the ConnectX®-4 Lx EN Card.
This is the code i write for reciving UDP data packet over ethernet using rdma in unreliable datagram connection mode,but everyting the code indefinitly waits for ibv_poll_cq and not able to recive data packet
please help i am stuck.
include <stdlib.h>
include <string.h>
include <stdio.h>
include <errno.h>
include <sys/types.h>
include <netinet/in.h>
include <arpa/inet.h>
include <sys/socket.h>
include <netdb.h>
include <byteswap.h>
include <unistd.h>
include <getopt.h>
include <fcntl.h>
include <rdma/rdma_cma.h>
struct cmatest_node
int id;
struct rdma_cm_id *cma_id;
int connected;
struct ibv_pd *pd;
struct ibv_cq *cq;
struct ibv_mr *mr;
struct ibv_ah *ah;
uint32_t remote_qpn;
uint32_t remote_qkey;
void *mem;
struct cmatest
struct rdma_event_channel *channel;
struct cmatest_node *nodes;
int conn_index;
int connects_left;
struct sockaddr_in6 dst_in;
struct sockaddr *dst_addr;
struct sockaddr_in6 src_in;
struct sockaddr *src_addr;
static struct cmatest test;
static int connections = 1;
static int message_size = 1456;
static int message_count = 10;
static char *dst_addr;
static char *src_addr;
static enum rdma_port_space port_space = RDMA_PS_UDP;
define CHUNK_SIZE (1024 * 1024) ///< (1MB) Size of chunks to devide the main buffer, while writing to a file.
static int create_message(struct cmatest_node *node)
if (!message_size)
message_count = 0;
if (!message_count)
return 0;
node->mem = malloc(message_size + sizeof(struct ibv_grh));
if (!node->mem)
printf(“failed message allocation\n”);
return -1;
node->mr = ibv_reg_mr(node->pd, node->mem, message_size + sizeof(struct ibv_grh),IBV_ACCESS_LOCAL_WRITE);
if (!node->mr)
printf(“failed to reg MR\n”);
goto err;
return 0;
err:
free(node->mem);
return -1;
static int verify_test_params(struct cmatest_node *node)
struct ibv_port_attr port_attr;
int ret;
ret = ibv_query_port(node->cma_id->verbs, node->cma_id->port_num, &port_attr);
if (ret)
return ret;
port_attr.active_mtu =IBV_MTU_4096;
if (message_count && message_size > (1 << (port_attr.active_mtu + 7)))
printf(“mckey: message_size %d is larger than active mtu %d\n”, message_size, 1 <<
(port_attr.active_mtu + 7));
return -EINVAL;
return 0;
static int init_node(struct cmatest_node *node)
struct ibv_qp_init_attr init_qp_attr;
int cqe, ret;
node->pd = ibv_alloc_pd(node->cma_id->verbs);
if (!node->pd)
ret = -ENOMEM;
printf(“mckey: unable to allocate PD\n”);
goto out;
cqe = message_count ? message_count * 2 : 2;
node->cq = ibv_create_cq(node->cma_id->verbs, cqe, node, 0, 0);
if (!node->cq)
ret = -ENOMEM;
printf(“mckey: unable to create CQ\n”);
goto out;
memset(&init_qp_attr, 0, sizeof init_qp_attr);
init_qp_attr.cap.max_send_wr = message_count ? message_count : 1;
init_qp_attr.cap.max_recv_wr = message_count ? message_count : 1;
init_qp_attr.cap.max_send_sge = 1;
init_qp_attr.cap.max_recv_sge = 1;
init_qp_attr.qp_context = node;
init_qp_attr.sq_sig_all = 0;
init_qp_attr.qp_type = IBV_QPT_UD;
init_qp_attr.send_cq = node->cq;
init_qp_attr.recv_cq = node->cq;
ret = rdma_create_qp(node->cma_id, node->pd, &init_qp_attr);
if (ret)
printf(“mckey: unable to create QP: %d\n”, ret);
goto out;
ret = create_message(node);
if (ret)
printf(“mckey: failed to create messages: %d\n”, ret);
goto out;
out:
return ret;
static int post_recvs(struct cmatest_node *node)
struct ibv_recv_wr recv_wr, *recv_failure;
struct ibv_sge sge;
int i, ret = 0;
if (!message_count)
return 0;
recv_wr.next = NULL;
recv_wr.sg_list = &sge;
recv_wr.num_sge = 1;
recv_wr.wr_id = (uintptr_t) node;
sge.length = message_size + sizeof(struct ibv_grh);
sge.lkey = node->mr->lkey;
sge.addr = (uintptr_t) node->mem;
for (i = 0; i < message_count && !ret; i++ )
ret = ibv_post_recv(node->cma_id->qp, &recv_wr, &recv_failure);
if (ret)
printf(“failed to post receives: %d\n”, ret);
break;
return ret;
static void connect_error(void)
test.connects_left–;
static int addr_handler(struct cmatest_node *node,struct rdma_ud_param *param)
int ret;
ret = verify_test_params(node);
if (ret)
goto err;
ret = init_node(node);
if (ret)
goto err;
ret = post_recvs(node);
if (ret)
goto err;
node->connected = 1;
return 0;
err:
connect_error();
return ret;
static int cma_handler(struct rdma_cm_id *cma_id, struct rdma_cm_event *event)
int ret = 0;
switch (event->event)
case RDMA_CM_EVENT_ADDR_RESOLVED:
ret = addr_handler(cma_id->context,&event->param.ud);
break;
case RDMA_CM_EVENT_ADDR_ERROR:
case RDMA_CM_EVENT_ROUTE_ERROR:
printf(“mckey: event: %s, error: %d\n”, rdma_event_str(event->event), event->status);
connect_error();
ret = event->status;
break;
case RDMA_CM_EVENT_DEVICE_REMOVAL:
/* Cleanup will occur after test completes. */
break;
default:
break;
return ret;
static void destroy_node(struct cmatest_node *node)
if (!node->cma_id)
return;
if (node->ah)
ibv_destroy_ah(node->ah);
if (node->cma_id->qp)
rdma_destroy_qp(node->cma_id);
if (node->cq)
ibv_destroy_cq(node->cq);
if (node->mem)
ibv_dereg_mr(node->mr);
free(node->mem);
if (node->pd)
ibv_dealloc_pd(node->pd);
/* Destroy the RDMA ID after all device resources */
rdma_destroy_id(node->cma_id);
static int alloc_nodes(void)
int ret, i;
test.nodes = malloc(sizeof *test.nodes * connections);
if (!test.nodes)
printf(“mckey: unable to allocate memory for test nodes\n”);
return -ENOMEM;
memset(test.nodes, 0, sizeof *test.nodes * connections);
for (i = 0; i < connections; i++)
test.nodes[i].id = i;
ret = rdma_create_id(test.channel, &test.nodes[i].cma_id, &test.nodes[i], port_space);
if (ret)
goto err;
return 0;
err:
while (–i >= 0)
rdma_destroy_id(test.nodes[i].cma_id);
free(test.nodes);
return ret;
static void destroy_nodes(void)
int i;
destroy_node(&test.nodes[i]);
free(test.nodes);
void read_data_from_memory(struct cmatest_node *node)
// Add your code here to read data from 'node->mem'
int file_descriptor;
ssize_t total_bytes_received = 0;
// Save the buffer to a binary file
file_descriptor = open("data2.bin", O_CREAT | O_WRONLY | O_TRUNC, 0644);
if (file_descriptor < 0)
perror("file creation failed");
exit(EXIT_FAILURE);
ssize_t bytes_written;
ssize_t remaining_bytes = total_bytes_received;
off_t offset = 0;
// Write the buffer to the file in chunks
while (remaining_bytes > 0)
ssize_t chunk_size = (remaining_bytes < CHUNK_SIZE) ? remaining_bytes : CHUNK_SIZE;
bytes_written = pwrite(file_descriptor, node->mem + offset, chunk_size, offset);
if (bytes_written < 0)
perror("file write failed");
exit(EXIT_FAILURE);
remaining_bytes -= bytes_written;
offset += bytes_written;
// Close the file after writing
close(file_descriptor);
static int poll_cqs(void)
struct ibv_wc wc[8];
int done, i, ret;
if (!test.nodes[i].connected)
continue;
for (done = 0; done < message_count; done += ret)
ret = ibv_poll_cq(test.nodes[i].cq, 8, wc);
if (ret < 0)
printf("mckey: failed polling CQ: %d\n", ret);
return ret;
// Read data from memory after data transfer is complete
// Assuming each node has its own data buffer (node->mem)
read_data_from_memory(&test.nodes[i]);
return 0;
static int connect_events(void)
struct rdma_cm_event *event;
int ret = 0;
while (test.connects_left && !ret)
ret = rdma_get_cm_event(test.channel, &event);
if (!ret)
ret = cma_handler(event->id, event);
rdma_ack_cm_event(event);
return ret;
static int get_addr(char *dst, struct sockaddr *addr,int local)
struct addrinfo *res;
int ret;
struct addrinfo hints = {
.ai_family = AF_INET,
//ret = getaddrinfo(dst, NULL, NULL, &res);
if(local)
ret = getaddrinfo(dst, “4660”, &hints, &res);
else
ret = getaddrinfo(dst, “22136”, &hints, &res);
if (ret)
printf(“getaddrinfo failed - invalid hostname or IP address\n”);
return ret;
memcpy(addr, res->ai_addr, res->ai_addrlen);
freeaddrinfo(res);
return ret;
static int run(void)
int i, ret;
printf(“mckey: starting server\n”);
if (src_addr)
ret = get_addr(src_addr, (struct sockaddr *) &test.src_in,1);
if (ret)
return ret;
ret = get_addr(dst_addr, (struct sockaddr *) &test.dst_in,0);
if (ret)
return ret;
printf(“mckey: joining\n”);
if (src_addr)
ret = rdma_bind_addr(test.nodes[i].cma_id, test.src_addr);
if (ret)
printf(“mckey: addr bind failure: %d\n”, ret);
connect_error();
return ret;
ret = rdma_resolve_addr(test.nodes[i].cma_id, test.src_addr, test.dst_addr, 2000);
if (ret)
printf("mckey: resolve addr failure: %d\n", ret);
connect_error();
return ret;
ret = connect_events();
if (ret)
goto out;
- Pause to give SM chance to configure switches. We don’t want to
- handle reliability issue in this simple test program.
sleep(3);
if (message_count)
printf(“receiving data transfers\n”);
ret = poll_cqs();
if (ret)
goto out;
printf(“data transfers complete\n”);
out:
return ret;
int main(int argc, char **argv)
int op, ret;
while ((op = getopt(argc, argv, “m:b:”)) != -1) {
switch (op) {
case ‘m’:
dst_addr = optarg;
break;
case 'b':
src_addr = optarg;
test.src_addr = (struct sockaddr *) &test.src_in;
break;
default:
printf("usage: %s\n", argv[0]);
printf("\t-m dest_address\n");
printf("\t-b bind_address\n");
exit(1);
test.dst_addr = (struct sockaddr *) &test.dst_in;
test.connects_left = connections;
test.channel = rdma_create_event_channel();
if (!test.channel)
printf(“failed to create event channel\n”);
exit(1);
if (alloc_nodes())
exit(1);
ret = run();
printf(“test complete\n”);
destroy_nodes();
rdma_destroy_event_channel(test.channel);
printf(“return status %d\n”, ret);
return ret;
