I try to run a server-client communication example. The server sends a string first. After the client received it, the client sent another string back.
I modify the code from GitHub, which only the server sends a string to the client. The codes I run are below:
rmda_socket.hpp:
#pragma once
#include <rdma/rdma_cma.h>
#include <rdma/rdma_verbs.h>
#include <infiniband/verbs.h>
#include <sys/mman.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <arpa/inet.h>
#include <cstring>
#include <cassert>
#include <cstdio>
#include <iostream>
#include <exception>
struct rdma_error : public std::exception {
const char* _what;
rdma_error(const char* what) : _what(what) {}
virtual const char* what() const noexcept override {
return _what;
void print_id(struct rdma_cm_id* id) {
printf("%p\n", id->verbs);
class rdma_socket {
struct rdma_cm_id* _id;
struct rdma_event_channel* _events;
struct ibv_pd* _protect;
rdma_socket()
: _id(nullptr), _events(rdma_create_event_channel()), _protect(nullptr) {}
public:
struct ibv_qp_init_attr _qp_attr;
public:
rdma_socket(enum rdma_port_space type) {
_events = rdma_create_event_channel();
int rcode = rdma_create_id(_events, &_id, nullptr, type);
assert(!rcode);
// non-copyable
rdma_socket(const rdma_socket&) = delete;
rdma_socket& operator=(const rdma_socket&) = delete;
// moveable
rdma_socket(rdma_socket&& s)
: _id(s._id), _events(s._events), _protect(s._protect)
s._id = nullptr;
s._events = nullptr;
s._protect = nullptr;
// dtor
~rdma_socket() {
if(_id)
rdma_destroy_id(_id);
if(_events)
rdma_destroy_event_channel(_events);
if(_protect)
ibv_dealloc_pd(_protect);
void bind() {
this->bind("0.0.0.0", 0);
void bind(const char* address, short port) {
struct sockaddr_in addrin;
addrin.sin_family = AF_INET;
addrin.sin_port = htons(port);
addrin.sin_addr.s_addr = inet_addr(address);
bzero(&addrin.sin_zero, 8);
this->bind((struct sockaddr*) &addrin);
void bind(struct sockaddr* address) {
int rcode = rdma_bind_addr(_id, address);
assert(!rcode);
void listen(int backlog = 16) {
int rcode = rdma_listen(_id, backlog);
assert(!rcode);
rdma_socket accept() {
struct rdma_cm_event* ev;
int rcode = rdma_get_cm_event(_events, &ev);
if(ev->event == RDMA_CM_EVENT_CONNECT_REQUEST) {
// GOOD
else {
// BAD
rdma_socket new_sock;
new_sock._id = ev->id;
new_sock.create_qp();
struct rdma_conn_param params;
bzero(¶ms, sizeof(params));
rcode = rdma_accept(new_sock._id, ¶ms);
rcode = rdma_ack_cm_event(ev); // ack conn request
// rcode = rdma_get_cm_event(_events, &ev);
// rcode = rdma_ack_cm_event(ev); // ack
see(ev);
return new_sock;
void resolve(const char* address, short port) {
this->resolve((struct sockaddr*) &addrin);
void resolve(struct sockaddr* address) {
const int timeout = 100;
int rcode = rdma_resolve_addr(_id, nullptr, address, timeout);
if(ev->event == RDMA_CM_EVENT_ADDR_RESOLVED) {
// GOOD
else if(ev->event == RDMA_CM_EVENT_ADDR_ERROR) {
// BAD
else {
throw rdma_error("Unexpected");
void connect() {
int rcode;
rcode = rdma_resolve_route(_id, timeout);
params.private_data = nullptr;
params.private_data = 0;
params.responder_resources = 8;
params.initiator_depth = 8;
rcode = rdma_connect(_id, ¶ms);
rdma_ack();
// assert(!rcode);
void rdma_ack(){
int rcode;
struct rdma_cm_event *ev;
rcode = rdma_get_cm_event(_events,&ev);
see(ev);
assert(!rcode);
void disconnect() {
int rcode = rdma_disconnect(_id);
assert(!rcode);
void create_qp() {
bzero(&_qp_attr, sizeof(_qp_attr));
_qp_attr.recv_cq = nullptr;
_qp_attr.send_cq = nullptr;
_qp_attr.srq = nullptr;
_qp_attr.qp_context = NULL;
_qp_attr.qp_type = IBV_QPT_RC;
_qp_attr.cap.max_send_wr = 8;
_qp_attr.cap.max_recv_wr = 8;
_qp_attr.cap.max_send_sge = 8;
_qp_attr.cap.max_recv_sge = 8;
_qp_attr.cap.max_inline_data = 8;
_protect = ibv_alloc_pd(_id->verbs);
int rcode = rdma_create_qp(_id, _protect, &_qp_attr);
assert(!rcode);
sockaddr get_peer_addr() {
return *rdma_get_peer_addr(_id);
sockaddr get_local_addr() {
return *rdma_get_local_addr(_id);
void post_recv(void * addr, size_t length, struct ibv_mr* mr = nullptr, void * user_data = nullptr) {
if(mr == nullptr)
mr = ibv_reg_mr(_protect, addr, length, IBV_ACCESS_REMOTE_WRITE | IBV_ACCESS_LOCAL_WRITE);
if(user_data == nullptr)
user_data = addr;
int rcode = rdma_post_recv(_id, user_data, addr, length, mr);
assert(!rcode);
void post_send(void * addr, size_t length, struct ibv_mr* mr = nullptr, void * user_data = nullptr) {
if(mr == nullptr)
user_data = addr;
int rcode = rdma_post_send(_id, user_data, addr, length, mr, 0);
assert(!rcode);
struct ibv_wc recv_comp() {
struct ibv_wc wc;
int rcode = rdma_get_recv_comp(_id, &wc);
return wc;
struct ibv_wc send_comp() {
struct ibv_wc wc;
int rcode = rdma_get_send_comp(_id, &wc);
return wc;
void see(struct rdma_cm_event *event){
switch (event->event) {
case RDMA_CM_EVENT_ADDR_RESOLVED:
// Address resolution completed successfully
std::cout << "Address resolution completed successfully" << std::endl;
break;
case RDMA_CM_EVENT_ROUTE_RESOLVED:
// Route resolution completed successfully
std::cout << "Route resolution completed successfully" << std::endl;
break;
case RDMA_CM_EVENT_CONNECT_REQUEST:
// Received a connection request from a remote peer
std::cout << "Received a connection request from a remote peer" << std::endl;
break;
case RDMA_CM_EVENT_ESTABLISHED:
// Connection has been established
std::cout << "Connection has been established" << std::endl;
break;
case RDMA_CM_EVENT_DISCONNECTED:
// Connection has been disconnected
std::cout << "Connection has been disconnected" << std::endl;
break;
default:
// Other events ...
break;
server.cpp:
#include "rdma_socket.hpp"
#include <unistd.h>
int main(int argc, char* argv[]) {
rdma_socket server(RDMA_PS_TCP);
server.bind("12.7.14.35", 8000);
server.listen();
rdma_socket rclient = server.accept();
char* data = new char[4096];
char* datax = new char[4096];
std::memcpy(data, "Hello World!", 13);
// std::memcpy(datax, "Hello World!", 13);
rclient.post_send(data, 4096);
std::cout << "yyy" << std::endl;
struct ibv_wc wc = rclient.send_comp();
std::cout << "xxx" << std::endl;
rclient.post_recv(datax, 4096);
printf("zzz\n");
wc = rclient.recv_comp();
printf("%s\n", reinterpret_cast<char*>(wc.wr_id));
return 0;
client.cpp:
#include <unistd.h>
rdma_socket client(RDMA_PS_TCP);
client.resolve("12.7.14.35", 8000);
client.create_qp();
char* mem = new char[4096];
client.post_recv(mem, 4096);
client.connect();
struct ibv_wc wc = client.recv_comp();
std::memcpy(data, "Hello serve!", 13);
printf("ttt\n");
sleep(1);
printf("rrr\n");
wc = client.send_comp();
printf("xxx\n");
return 0;
I run the code. The client’s output shows below:
^C
[lifei@g14r2n15 rdma]$ ./client
Hello World!
ttt
rrr
mlx5: g14r2n15: got completion with error:
00000000 00000000 00000000 00000000
00000000 00008716 0a005df8 000013d2
xxx
the server is stuck and the output shows below:
yyy
How can I fix it?
And I want to debug these codes, but I can stick them with gdb. How can I debug?
