Hi NV team
I am using custom carrier board
How to identify Orin module by command?
or other way not in physical marking
ex:
Orin 64GB
Orin 32GB
Orin 64GB Dev version
Hi NV team
ex:
Orin 64GB
Orin 32GB
Here are some suggestions for the common issues:
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
Installation guide of deep learning frameworks on Jetson:
Startup deep learning tutorial:
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
Hi Carolyuu
Sorry ,I didn’t write clearly
I just want to check what kind of module is ,when system is running
cat /etc/nv_boot_control.conf
Orin 64GB would have 0005
32GB → 0004
old 32GB devkit module → 0000
