I enabled DPU mode on the host server using the doca 3.0.0 bundle. I then built ipsec_security_gw in /opt/mellanox/doca/applications in DPU mode and checked the doca_flow_tune results.
[05:00:09:682898][137887][DOCA][DBG][flow_common.c:303][ipsec_security_gw_init_doca_flow] DOCA Flow Tune Server isn’t supported in this runtime version
I’m getting the following result.
I ran the application by referring to the official document https://docs.nvidia.com/doca/archive/3-0-0/doca+ipsec+security+gateway+application+guide/index.html, but is there anything I need to set up separately in advance?
Or is it not possible to enable doca_flow_tune server in doca 3.0.0?
Hi jacob33
Thank you for posting your query on NVIDIA Community.
I would like to bring to your notice that DOCA Flow Tune Tool is currently supported at Alpha Level. In addition, in order to understand the failure, a complete set of logs along with reproduction steps is needed to triage this issue.
This will require an active support entitlement to debug complex issues.
If there an active entitlement/support contract in place, please do not hesitate to open a support ticket by logging into the ESP Portal and submitting a new case.
For contracts, please reach out to Networking-Contracts@nvidia.com
Thanks,
Namrata.
