Mounting for “/” is an extreme difference, and I won’t be covering that. I will be assuming you are backing up “/usr/local” to this partition, and then replacing the original content with that partition. This could easily be “/home”, which is a minor edit. Mounting to “/usr” should be avoided (same issue as replacing “/”).
Your partition is already formatted as ext4, so you can go straight to updating the partition and changing its mount point.
With the partition at its auto mount point of “/media/user/45383464-e6f4-471b-a0a2-6d8348c4a42e”, you could back up directly to this from “/usr/local” like this:
cd /usr/local
sudo -s cp -adpR * /media/user/45383464-e6f4-471b-a0a2-6d8348c4a42e/
Then verify content of “/media/user/45383464-e6f4-471b-a0a2-6d8348c4a42e” looks like it matches “/usr/local”. Be sure to use “ls -AF” in your comparison because you want to see “dot files” (files starting with “.”).
Now umount the existing media mount:
sudo umount /media/user/45383464-e6f4-471b-a0a2-6d8348c4a42e
Test mount to overlay on top of “/usr/local” (the old content will still be there, but will be inaccessible until umount):
sudo mount /dev/mmcblk2p1 /usr/local
See if you see the content just as it used to be, but verify this is mmcblk2p1 via “df -H -T /usr/local”. It should say it is ext4 /dev/mmcblk2p1 mounted on “/usr/local”, and the available space should be based on the SD card partition size.
Assuming that went well, we will add an entry into “/etc/fstab” which makes it possible to mount the SD there, but won’t automatically invoke this, and does not make it mandatory that the card be present for boot. Add the following line to “/etc/fstab” (you are free to add spaces between fields to make a nice “table” if you want):
UUID=45383464-e6f4-471b-a0a2-6d8348c4a42e /usr/local ext4 noauto,nofail,rw,suid,dev,exec,nouser,async 1 2
The first field identifies the source of the mounted data. UUID is specific to that SD card partition. If you use another SD card, then it won’t see this entry as applying to it. You could say “/dev/mmcblk2p1”, but then boot would assume that SD card partition every time regardless of whether or not it is the wrong partition.
The second field is where it will mount.
The third field is just the filesystem type.
The fourth field is interesting. There is normally the key word “defaults”, but I separated it into its multiple options which defaults is an alias for. The “noauto” means the system will not automatically mount this, which is the reverse of what defaults would do. The option “nofail” is quite important here, and also differs from defaults. If there is an attempt to mount this partition, and the mount fails, then the system will continue without blocking on the failure. This means that if the SD card is present, then mount will proceed normally, but if the card is not present, then the system will ignore the missing card and continue.
The next field is just a marker for backup and restore software. It is unlikely to matter, but “1” implies that if a backup operation is attempted, then the SD card partition will be backed up.
The last field is related to the order of filesystem repair should the system be shutdown incorrectly, and then repair is needed. The first repair would always be the system on “/”, and this would be “1”. We are marking the SD card for any repair to occur after “/” by setting it to “2”. Not really something to worry about.
With the SD card not mounted (“sudo umount /media/user/45383464-e6f4-471b-a0a2-6d8348c4a42e”), then you can now test manual mount:
sudo mount /usr/local
sudo umount /usr/local
…notice how you don’t need to label the source anymore.
If you reboot, then you would once more need to “sudo mount /usr/local”. If testing works, then you can edit that fourth field, and remove “noauto”. Each reboot with the SD present should mount there. Each reboot without the SD should proceed normally, but ignore the mount step.
If your SD is mounted, then its content replaces “/usr/local”. If the SD is not mounted, then the original content shows up again.
If you really need more space for “/”, then you could umount “/usr/local”, and the recursively delete “/usr/local/*”. Be very very careful to delete the right content, and to delete only after your SD is verified. Example:
sudo -s
umount /usr/local
cd /usr/local
rm -Rf ./*
cd
mount /usr/local
# Examine content
exit
The same thing could be performed for “/home”. You could split the SD into two partitions, and mount on both. I recommend leaving original “/home” content, and that way if the card is gone, then you have a backed up earlier version of “/home”. Similar for “/usr/local”, but less dangerous to lose the content. If you are now writing to the SD card, then there isn’t much reason to remove the old original eMMC content…you won’t be using more space and so it is ok to leave what is there, it is the SD card which will fill up after this. You could in fact on occasion recursively copy from the SD card as it changes into the original eMMC as a sort of backup system.
If you clone the TX2, then the SD card content will not clone. The eMMC content will clone. Any interest in cloning the SD card is a separate step.
