Image Based OTA TX2i
I have several TX2i modules in the field built on BSP 32.2. I would like to update them to BSP 32.7 to use the latest versions of the SDK components. I’m unclear if the TX2i can accept image based OTA updates. In the documentation I see that the TX2 series is listed. However, there is a chart for updating to 32.7 which lists “Original Jetson TX2 module only”. Can I use image based OTA to update a TX2i from BSP 32.2 to 32.7?
Hi a.k,
The Image-based OTA is not support TX2i.
Supported target boards: jetson-tx2-devkit, jetson-agx-xavier-devkit, jetson-xavier-nx-devkit, jetson-xavier-nx-devkit-emmc, jetson-xavier-nx-devkit-tx2-nx.
