I tried “image-based OTA update” on AGX Industrial model with my base version (R32-6)…
And the OTA tool is comes from (L4T_32.7.2_Jetpack4.7)
It can’t work.
After updated the full-system, the AGX industrial couldn’t boot successfully.
Got following error messages:
Rebooting system …
[0000.025] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 1.5.1.7-t194-41334769-98030a79)
[0000.039] I> Boot-mode: Coldboot
[0000.042] I> Chip revision : A02P
[0000.045] I> Bootrom patch version : 15 (correctly patched)
[0000.050] I> ATE fuse revision : 0x200
[0000.053] I> Ram repair fuse : 0x0
[0000.057] I> Ram Code : 0x1
[0000.059] I> rst_source : 0xb
[0000.062] I> rst_level : 0x1
[0000.065] I> Boot-device: QSPI
[0000.068] I> Qspi flash params source = brbct
[0000.072] I> Qspi using bpmp-dma
[0000.075] I> Qspi clock source : pllp
[0000.079] I> QSPI Flash Size = 64 MB
[0000.082] I> Qspi initialized successfully
[0000.086] I> Active Boot chain : 1
[0000.089] I> Boot-device: QSPI
[0000.092] I> Qspi flash params source = brbct
[0000.098] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.104] I> Temperature = 47000
[0000.107] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.111] W> Skipping boost for clk: BPMP_APB
[0000.115] W> Skipping boost for clk: AXI_CBB
[0000.119] W> Skipping boost for clk: AON_CPU_NIC
[0000.124] W> Skipping boost for clk: CAN1
[0000.127] W> Skipping boost for clk: CAN2
[0000.132] I> Boot-device: QSPI
[0000.134] I> Boot-device: QSPI
[0000.137] I> Qspi flash params source = mb1bct
[0000.141] I> Qspi using bpmp-dma
[0000.144] I> Qspi clock source : pllc_out0
[0000.148] I> Qspi reinitialized
[0000.151] I> Qspi flash params source = mb1bct
[0000.156] E> Blockdev open: exit error
[0000.160] E> LOADER: Invalid value partition size 0.
[0000.165] E> LOADER: Failed to get storage info for binary 2 from loader.
[0000.171] E> LOADER: Failed to get info for binary 2 from loader.
[0000.177] C> LOADER: Could not read binary 2.
[0000.181] E> Blockdev open: exit error
[0000.184] E> LOADER: Invalid value partition size 0.
[0000.189] E> LOADER: Failed to get storage info for binary 52 from loader.
[0000.195] E> LOADER: Failed to get info for binary 52 from loader.
[0000.201] C> LOADER: Could not read binary 52.
[0000.205] E> Task 40 failed (err: 0x1f1d0202)
[0000.209] E> Top caller module: CARVEOUT, error module: LOADER, reason: 0x02, aux_info: 0x02
[0000.217] I> MB1(1.5.1.7-t194-41334769-98030a79) BIT boot status dump :
000000000001111111111011111111111111111110010000000000000000000000000000000000000000000000000000000000000000000000000000000000001
1011000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
According to the link “OTA Updates on AGX Industrial model?”, it seems that AGX Xavier industrial is not support Image-based OTA.
Does the AGX Xavier industrial support OTA now ?
If the answer is “Yes”, how do I fix the problem?
