Hello!
I am trying to create a image classification data set following this tutorial GitHub - dusty-nv/jetson-inference: Hello AI World guide to deploying deep-learning inference networks and deep vision primitives with TensorRT and NVIDIA Jetson.
I am stuck at the image classification dataset part of this tutorial. Could anyone help if the dataset creation is to be done at the host pc or at the jetson??
I am getting the following error while trying to do it from the workstation:
I am getting this error:
Training image folder:
folder does not exist
I am using digits on docker. So I copied my dataset to /opt/mnist folder as specified here :https://github.com/NVIDIA/nvidia-docker/wiki/DIGITS
Thanks in advance.
Hi spandybull, the training dataset should be on the host.
Are you using MNIST dataset? What does the folder structure look like under /opt/mnist? You may need to point DIGITS to the training folder with the images.
Hello Dusty_nv,
Thank you for your reply.
Works fine now after establishing connection between groups like baseball → /opt/datasets/imagenet/ilsvrc12/n02799071
However ended up with a different error while creating image segmentation model
ERROR: Check failed: status == CUDNN_STATUS_SUCCESS (8 vs. 0) CUDNN_STATUS_EXECUTION_FAILED, device 0
caffe log:
0222 15:38:28.999123 240 cudnn_dropout_layer.cpp:26] Check failed: status == CUDNN_STATUS_SUCCESS (8 vs. 0) CUDNN_STATUS_EXECUTION_FAILED, device 0
*** Check failure stack trace: ***
@ 0x7fcf4509c5cd google::LogMessage::Fail()
@ 0x7fcf4509e433 google::LogMessage::SendToLog()
@ 0x7fcf4509c15b google::LogMessage::Flush()
@ 0x7fcf4509ee1e google::LogMessageFatal::~LogMessageFatal()
@ 0x7fcf45d22ccd caffe::CuDNNDropoutLayer<>::LayerSetUp()
@ 0x7fcf45f20302 caffe::Net::Init()
@ 0x7fcf45f21d5e caffe::Net::Net()
@ 0x7fcf45ee6caf caffe::Solver::InitTrainNet()
@ 0x7fcf45ee7234 caffe::Solver::Init()
@ 0x7fcf45ee76ca caffe::Solver::Solver()
@ 0x7fcf45e377b6 caffe::Creator_SGDSolver()
@ 0x4194d6 caffe::SolverRegistry::CreateSolver()
@ 0x4120c5 train()
@ 0x40c9e0 main
@ 0x7fcf4365f830 __libc_start_main
@ 0x40d509 _start
@ (nil) (unknown)
Please provide your suggestion.
Thank you in advance.
I’m not familiar with that error - what network and dataset are you using for image segmentation? Are you able to train other network models with the setup?
OK, that network and dataset are for image recognition - not segmentation. Is that the type of dataset and model you created in DIGITS?
If you are unable to train with any model, there must be a configuration error somewhere. Do you have a GPU in your training PC?
Yeah! I am sorry. Its image recognition. Yes. Name of the dataset- ImageNet-ILSVRC12-subset. The issue is while creating a model using standard googlenet network.
I am training on my PC with GeForce RTX 2080 Ti/PCIe/SSE2.
Hi spandybull,
Are you running DIGITS from within ngc container or using system wide install of DIGITS?
It seems that you are approaching image classification with standard googlenet network. Are you using the default dataset or trying to train the model on a custom dataset?
you should be using the below sequence to procure the dataset, as it seems to me and then map docker folder with -v parameter.
Did you try purging the gpu driver and reinstalling it again with corresponding packages including cudnn?
wget --no-check-certificate https://nvidia.box.com/shared/static/gzr5iewf5aouhc5exhp3higw6lzhcysj.gz -O ilsvrc12_urls.tar.gz
$ tar -xzvf ilsvrc12_urls.tar.gz
$ wget https://rawgit.com/dusty-nv/jetson-inference/master/tools/imagenet-download.py
$ python imagenet-download.py ilsvrc12_urls.txt . --jobs 100 --retry 3 --sleep 0
Yes. I tried it in the same sequence.
I reinstalled the Cudnn package but still having issues.
Are you able to run cuDNN samples? Likewise, can you try running any caffe test?
Im using NVIDIA 1080 GTX GPU, CUDA 10.0, Tensorflow-GPU=1.14.0, CUDAnn 7.4.2, TensorRT 5.1.5.0.
Im getting an Error using nvidia image classification dataset: https://github.com/tensorflow/tensorrt/blob/master/tftrt/examples/image-classification/image_classification.py#L203
File “image_classification.py”, line 760, in
target_duration=args.target_duration)
File “image_classification.py”, line 203, in run
results[‘99th_percentile’] = np.percentile(iter_times, q=99, interpolation=‘lower’) * 1000
IndexError: cannot do a non-empty take from an empty axes.
A video walkthrough of natively installing NVIDIA DIGITS on Ubuntu 18.04 LTS is available here:
https://cudaeducation.com/nvidiadigits/
It includes installing NVCaffe, cuDNN etc. Once I got NVIDIA DIGITS installed properly on my system, I was able to follow the tutorial for image classification here: GitHub - dusty-nv/jetson-inference: Hello AI World guide to deploying deep-learning inference networks and deep vision primitives with TensorRT and NVIDIA Jetson. · GitHub
Hope this helps!
-Cuda Education
cudaeducation.com
