Image normalization in deepstream pipeline
• Hardware Platform (Jetson / GPU) Jetson AGX Orin
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.1
• TensorRT Version 8.5.1.1
I have a question about the image processing in the deepstream pipeline.
In image normalization in deepstream pipeline, as far as I understood,
Image input for PGIE = (Read image - offsets) * net-scale-factor
is how it works.
But I wonder if the read image is divided by 255 as default or not.
Since the model normalization is usually done after division by 255.
The net-scale-factor is the factor of dividing. You also can add some log in our demo code for normalization, it’s open source.
sources\libs\nvdsinfer\nvdsinfer_context_impl.cpp
NvDsInferStatus InferPreprocessor::transform()
