VIC Configuration failed image scale factor exceeds 16, use GPU for Transformation
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version Deepstream 6.2
• JetPack Version (valid for Jetson only) jetpack 5.1.1
• TensorRT Version 8.5.2
• Issue Type( questions, new requirements, bugs) questions
using a pipeline with primary detector(nvinfer) which network resolution is 1x3x960x1280 and use secondary classifier(nvinfer) whicn network resolution is
1x3x64x64.
I know deepstream on jeton only support scale factor with 1/16. But I change my post process forcing the ObjectMeta output of detector(nvinfer) is gcd of 16. It still report this error to interupt my pipline.
Please set “scaling-compute-hw=1” in your SGIE gst-nvinfer configuration file. There is no such limitation with GPU scaling.
BTW, can you post your SGIE gst-nvinfer configuration file here?
gpu-id=0
net-scale-factor=0.003921568627
force-implicit-batch-dim=1
classifier-async-mode=0
batch-size=1
model-color-format=0
#infer-dims=3;64;64
model-engine-file=train5-x-224-best-1225.onnx_fp16_1x3x64x64_orin.engine
labelfile-path=label.txt
onnx-file=cls-train2-1222-best.onnx
network-mode=2
network-type=1
num-detected-classes=2
process-mode=2
scaling-compute-hw=2
interval=0
output-blob-names=output0
parse-classifier-func-name=NvDsInferClassiferParseCustomSoftmax
custom-lib-path=libnvds_infercustomparser.so
classifier-threshold=0.000000
input-object-min-width=16
input-object-min-height=16
this is my sgie config. but still gets wrong. im using jetson orin with jp5.1.1
This bug is fixed in DeepStream 6.3. Please upgrade to the latest DeepStream version.
OK. thx
