Image resize and image rectify publish empty images
When I launch the image resize and rectify nodes:
/right/image_raw has valid image data
/right/image_resize is published with image all 0s
/right/image_rect is published with image all 0s
(if I remove the resize node image rect is still 0s)
I am using a modified version of this launchfile: isaac_ros_dnn_stereo_depth/isaac_ros_ess/launch/isaac_ros_argus_ess.launch.py at main · NVIDIA-ISAAC-ROS/isaac_ros_dnn_stereo_depth · GitHub
import launch
from launch_ros.actions import ComposableNodeContainer
from launch_ros.descriptions import ComposableNode
def generate_launch_description():
    output_width = 480
    output_height = 288
    argus_left_node = ComposableNode(
        name='argus_mono_left',
        package='isaac_ros_argus_camera',
        plugin='nvidia::isaac_ros::argus::ArgusMonoNode',
        parameters=[{
                'mode': 4,
                'camera_id': 1,
                'camera_info_url': 'file:///workspaces/isaac_ros-dev/left_camera.ini',
                'camera_link_frame_name': 'camera_link',
                'optical_frame_name': 'camera_left_link_optical'
        remappings=[
                    ('/left/image_raw', '/left/image_raw'),
                    ('/left/camera_info', '/left/camera_info'),
    argus_right_node = ComposableNode(
        name='argus_mono_right',
        parameters=[{
                'mode': 4,
                'camera_id': 0,
                'camera_info_url': 'file:///workspaces/isaac_ros-dev/right_camera.ini',
                'optical_frame_name': 'camera_right_link_optical'
        remappings=[
                    ('/left/image_raw', '/right/image_raw'),
                    ('/left/camera_info', '/right/camera_info'),
    left_resize_node = ComposableNode(
        name='left_resize_node',
        package='isaac_ros_image_proc',
        plugin='nvidia::isaac_ros::image_proc::ResizeNode',
        parameters=[{
            'output_width': output_width,
            'output_height': output_height,
            'keep_aspect_ratio': True
        remappings=[
            ('camera_info', 'left/camera_info'),
            ('image', 'left/image_raw'),
            ('resize/camera_info', 'left/camera_info_resize'),
            ('resize/image', 'left/image_resize')]
    right_resize_node = ComposableNode(
        name='right_resize_node',
        parameters=[{
        remappings=[
            ('camera_info', 'right/camera_info'),
            ('image', 'right/image_raw'),
            ('resize/camera_info', 'right/camera_info_resize'),
            ('resize/image', 'right/image_resize')]
    left_rectify_node = ComposableNode(
        name='left_rectify_node',
        plugin='nvidia::isaac_ros::image_proc::RectifyNode',
        parameters=[{
        remappings=[
            ('image_raw', 'left/image_resize'),
            ('camera_info', 'left/camera_info_resize'),
            ('image_rect', 'left/image_rect'),
            ('camera_info_rect', 'left/camera_info_rect')
    right_rectify_node = ComposableNode(
        name='right_rectify_node',
        parameters=[{
        remappings=[
            ('image_raw', 'right/image_resize'),
            ('camera_info', 'right/camera_info_resize'),
            ('image_rect', 'right/image_rect'),
            ('camera_info_rect', 'right/camera_info_rect')
    argus_mono_container = ComposableNodeContainer(
            name='argus_mono_container',
            package='rclcpp_components',
            executable='component_container_mt',
            composable_node_descriptions=[argus_left_node, argus_right_node, left_resize_node, right_resize_node, left_rectify_node, right_rectify_node],
            namespace='',
            output='screen',
            arguments=['--ros-args', '--log-level', 'info'],
    return launch.LaunchDescription([argus_mono_container])
What is wrong? I attach execution logs
launch_camera_logs.txt (83.5 KB)
Hi @eloi3
Have you checked if your Argus camera is streaming?
The issue may be related to your camera and not to the Image rectify package. Check our Isaac ROS Argus camera troubleshooting guide to determine if your camera is functioning correctly.
https://nvidia-isaac-ros.github.io/repositories_and_packages/isaac_ros_argus_camera/isaac_ros_argus_camera/index.html#troubleshooting
Let me know, or please share your log to better understand the reason for these empty messages.
Best,
Raffaello
Hi @Raffaello
Camera is working properly and I have streamed it using argus successfully and run other packages on the output like camera calibration. If I check:
/left/image_raw, output from argus is OK
/left/camera_info output from argus is OK (loads ini file correctly and publishes to topic)
/right/image_raw, output from argus is OK
/right/camera_info output from argus is OK (loads ini file correctly and publishes to topic)
From the resize/rectify nodes:
/left/camera_info_rect is OK
/left/camera_info_resize is OK
/right/camera_info_rect is OK
/right/camera_info_resize is OK
/left/image_resize is a black image full of 0
/left/image_rect is a black image full of 0
/right/image_resize is a black image full of 0
/right/image_rect is a black image full of 0
The log is attached in the original message.
Given left/image_raw is correct and left/camera_info too, what could be the reason for rectify node to output an image full of 0s?
Thank you
Update: After launching this exact launchfile a lot of times, some times one of the rectify nodes outputs correct output on /left/image_rect while the /right/image_rect is still outputing 0s. What could be the cause of this behavior?
@Raffaello Actually right/image_resize and left/image_resize are good.
Only right/image_rect and /left/image_rect are failing
(From top to bottom: left/image_resize, left/image_rect, right/image_resize, right/image_rect)
I am seeing something similar.
When I set up the NITROS pipeline ArgusMonoNode => RectifyNode => AprilTagNode the output of RectifyNode often appears as black (all 0’s), but on some runs it appears fine, and on one run I saw mostly 0’s but with a weird stretched image in one region:
The simpler pipeline ArgusMonoNode => AprilTagNode works just fine.
I have a Jetson Orin Nano 8GB Dev Kit, and I’m running JetPack 6.0 and Isaac ROS.
Here is my launch file:
from launch import LaunchDescription
from launch_ros.substitutions import FindPackageShare
from launch.substitutions import PathJoinSubstitution
from launch.actions import OpaqueFunction
def launch_setup(context):
    camera_info = PathJoinSubstitution([FindPackageShare('isaac_rpi_bringup'), 'config', 'rpi_1280x720.yaml'])
    camera_node = ComposableNode(
        name='isaac_camera',
        parameters=[{
            'camera_id': 0,
            'mode': 4,  # See list above
            'camera_info_url': f"file://{camera_info.perform(context)}",
            'optical_frame_name': 'rpi_camera',
        remappings=[
            ('left/image_raw', 'image_raw'),
            ('left/camera_info', 'camera_info'),
        name='isaac_rectify',
        parameters=[{
            'output_width': 1280,
            'output_height': 720,
    apriltag_node = ComposableNode(
        name='isaac_apriltag',
        package='isaac_ros_apriltag',
        plugin='nvidia::isaac_ros::apriltag::AprilTagNode',
        parameters=[{
            'size': 0.1,
            'max_tags': 64,
            'tile_size': 4,
        remappings=[
            ('image', 'image_rect'),
            ('camera_info', 'camera_info_rect'),
    nitros_container = ComposableNodeContainer(
        name='nitros_container',
        composable_node_descriptions=[camera_node, rectify_node, apriltag_node],
        namespace='',
        output='screen',
        # arguments=['--ros-args', '--log-level', 'isaac_rectify:=debug']
    return [nitros_container]
    launch_description = LaunchDescription()
    launch_description.add_action(OpaqueFunction(function=launch_setup))
    return launch_description
Here is my camera calibration file:
image_width: 1280
image_height: 720
camera_name: rpi_camera
camera_matrix:
  rows: 3
  cols: 3
  data: [786.0494 ,   0.     , 688.41104,
           0.     , 784.37525, 461.97678,
           0.     ,   0.     ,   1.     ]
distortion_model: plumb_bob
distortion_coefficients:
  rows: 1
  cols: 5
  data: [-0.315841, 0.089443, -0.000093, -0.000332, 0.000000]
rectification_matrix:
  rows: 3
  cols: 3
  data: [1., 0., 0.,
         0., 1., 0.,
         0., 0., 1.]
projection_matrix:
  rows: 3
  cols: 4
  data: [593.72913,   0.     , 709.64563,   0.     ,
           0.     , 708.18652, 477.11753,   0.     ,
           0.     ,   0.     ,   1.     ,   0.     ]
Having the same issues on my end. Would love to diagnose this problem. It seems to occur randomly.
I am also experiencing this issue intermittently when trying to rectify images from 4x IMX296 cameras.
Hi all. Just checking back in and this issue seems to be fixed on the main Isaac branches forJP6.2.
I am having the same issue as others mentioned in this post. When using an upstream ArgusMonoNode with RectifyNode, the rectified image is sometimes just a black image - works maybe 50% of the time. I have a ResizeNode before the RectifyNode, but the output of that always works.
I am up-to-date with the latest isaac ros docker image (3.2 Update 11) and L4T (36.4.4):
admin@dt-desktop:/workspaces/isaac_ros-dev$ apt-cache policy ros-humble-isaac-ros-image-proc ros-humble-isaac-ros-image-proc: Installed: 3.2.10-0jammy Candidate: 3.2.10-0jammy Version table: *** 3.2.10-0jammy 500 500 https://isaac.download.nvidia.com/isaac-ros/release-3 jammy/release-3.0 arm64 Packages 100 /var/lib/dpkg/status
I’ve observed that when I feed the RectifyNode with an upstream sensor_msgs/msg/Image from gscam2, it always works.
@Calvin-InDro Did this fully resolve for you? What isaac_ros version and L4T are you using?
@Raffaello Do you have any insight on this issue?
Thanks all,
@vpanchal1
How many streams are you manipulating simultaneously?
Tested on Isaac ROS v3.2 update 12 and L4T 36.4.3
Hi Calvin,
I am working with two ArgusMonoNodes, but I’ve also tried with just one and I see the same behaviour.
I also just tested on L4T 36.4.3, and got the same results.
I haven’t tried update 12 yet, but the diff on isaac_ros_common is the same as update 11. I assume that means there is no difference, but please correct me if I am wrong. My docker container is using the following cached docker image:
nvcr.io/nvidia/isaac/ros:aarch64-ros2_humble_77e6a678c2058abf96bedcb8f7dd4330
Thanks,
@vpanchal1 I would try update 11 at least, as issues with the isaac_ros_argus_camera were addressed: Release Notes — isaac_ros_docs documentation
Yes, I am on Update 11 - Issues still persist. Do you know if your docker container is using the latest cached image from Isaac ROS Dev Base | NVIDIA NGC?
When you enter the container does it say the following?:
Found pre-built base image: nvcr.io/nvidia/isaac/ros:aarch64-ros2_humble_77e6a678c2058abf96bedcb8f7dd4330
