Implement CUDA in a standard VC++ project
Hello.
Is there a way to implement CUDA in an existing standard Visual Studio 2010 C++ project? I mean to convert my project to a CUDA project without using a wizard. The project contains a huge amount of source code in a hundreds of files and I cannot move it manually into the new project created with “CUDA project wizard”. All I need is to implement a single group of source files as GPU accelerated with CUDA. Is there any way to do that?
Solution Explorer → Right click on the project’s name → Build Customizations → CUDA x.x → Ok
Prerequisites: having installed CUDA x.x Toolkit (compatible with Visual Studio 2010) – check against release notes, and having installed the Visual Studio Build Customizations
Instructions might differ, but this is a possible start.
Make sure you backup your existing project in case addidng the build customization step breaks something.
So simple! Thank you very much!
