For full passthrough virtualization … i could see the hypervisor needs to implement MMIO filtering for NVSwithc in fabric manager manual for other requiremnts.
Please let me know how to implement it ?
Hi @booyeonjeong , although DGX A100 doesn’t support virtualization, I understand you’re asking more generically about HGX A100 based systems. Your best path would be to contact the NVIDIA Solutions Architect (SA) or Field Application Engineer (FAE) that you’ve been working with directly, so we can help you.
ScottE
I’m unable to find anything about MMIO filtering, which is necessary if you want as much isolation as possible. Is this only possible with certain hypervisors? Additional info is needed.
As ScottEllis mentioned, It would be better to contact your system supplier … then NVIDIA FAE can help how to block disabled NVLink connection on each GPU and Switch in full passthrough virtualization.
